Reply 33040 of 53165, by Horun
LewisRaz wrote on 2020-03-17, 20:29:
Well my new 486 Arrived today. […]
Completely gutted.
PC was packed alright, not amazing but would not have expected this amount of damage after I opened it.
It has taken one hell of a shunt to bend thick steel like that!!!
The floppy drive is a right off.
The HDD/floppy cage will need some bending to make it fit again.
The case is cracked and that bend underneath it seems very difficult to correct.
Several jumpers on the motherboard have taken such a hit that they fell to pieces.
The CPU was hit so hard it took the fan off of the heatsink(4 screws!!) and the CPU had even started to lift from the socket.
The soundcard was hit and broke some superficial plastic from the ISA slot.
It took me a while to come to terms with it and slowly take it apart and assess each part.
Somehow, after replacing the broken jumpers, bending pins back and crossing my fingers.. It actually boots.
Once I am over my dissapointment of this damage I will share the insides as there is actually some nice parts inside.
WOW they must have dropped it off the delivery truck. Good to hear the board works.
Reply 33041 of 53165, by pewpewpew
Almoststew1990 wrote on 2020-03-17, 23:36:
I bought an AGP 7600GS today which hopefully will bridge the gap between my GeForce 3 ti 200 and more modern PCIE cards, and used for games in the 2003 to 2005 range with a Pentium 4 or something.
That sounds right to me. I use a 7600GS on ASUS P4P800SE 3.00GHz .
Reply 33042 of 53165, by dionb
Just received this beauty today:
165.69 KiB
Looks pristine, but untested by last owner due to not being able to find a suitable CPU. That's not going to be easy, but challenge accepted 😀
(that's a Socket 413...)
Reply 33043 of 53165, by jaZz_KCS
dionb wrote on 2020-03-18, 13:20:
Just received this beauty today: 15845370400300.jpg […]
Mmh, PCIX.
What are your plans for the machine?
Reply 33044 of 53165, by dionb
jaZz_KCS wrote on 2020-03-18, 13:41:
Mmh, PCIX.
No PCI-X, that's just regular 64b 5V PCI.
Plans? Get it working, that would be cool enough. Run Win2kRC2 because I can- then install something else because no software for the platform 😜
Reply 33045 of 53165, by EvieSigma
When I try to Google for it I can't even find a Socket 413. Is this a non-x86 board or something?
Reply 33047 of 53165, by dionb
EvieSigma wrote on 2020-03-18, 14:11:
Yes. It's a Digital AlphaPC 164LX board, and it accepts AXP21164PC CPUs (400 or 533MHz).
They're not expensive, but very rarely come up for sale. Last one was one on CPU-world for USD 15 last Autumn.
derSammler wrote on 2020-03-18, 14:19:
It's called Socket FT1, or BGA413.
Er no, this is definitely for PGA CPUs, not BGA. Also about 14 years older.
Reply 33048 of 53165, by EvieSigma
dionb wrote on 2020-03-18, 14:26:
Yes. It's a Digital AlphaPC 164LX board, and it accepts AXP21164PC CPUs (400 or 533MHz). […]
I had a feeling it was Alpha. Alpha hardware is still somehow in regular business use so finding it on the secondary market isn't the easiest.
Reply 33050 of 53165, by texterted
Today's project.
A Radeon 9500 vanilla. It has the L shaped memory chip arrangement on the card.
These can, often times, be soft-modded with the Omega drivers, into a full fat 9700 with all the pipelines unlocked.
This was a success with this card and of course, I removed the stock cooler and that bloody die shim! I had to soak that yellow thermal cement they used in WD40 for quite a while before I could remove the shite. WTF?
Anyway, stuck on one of those cheap Chinesium vga coolers on there. They work a treat and are inexpensive. A vast improvement over stock. I'll stick some ram-sinks on if postie ever brings them.
159.26 KiB
90.39 KiB
Cheers
Ted
98se/W2K :- Asus A8v Dlx. A-64 3500+, 512 mb ddr, Radeon 9800 Pro, SB Live.
XP Pro:- Asus P5 Q SE Plus, C2D E8400, 4 Gig DDR2, Radeon HD4870, SB Audigy 2ZS.
Reply 33051 of 53165, by LewisRaz
Cleaned up the new case today. Not too bad now! Going to have to glue the 3.5" drive cover in as the plastic catch has snapped. Need to get a spare floppy out of the loft too. This system happily recognises my IDE-CF with 1gb card in so thats a bonus.
Also attached some of the internals that came with the machine.
    269.59 KiB
    375.56 KiB
    607.09 KiB
    437.84 KiB
    480.41 KiB
My retro pc youtube channel
Twitter
Reply 33052 of 53165, by piatd
Munx wrote on 2020-03-16, 08:32:
The flea markets I go to will be closed for a couple weeks due to the outbreak, but this weekend I still managed to get a few go […]
The flea markets I go to will be closed for a couple weeks due to the outbreak, but this weekend I still managed to get a few good items that will keep me entertained during that time:
Looks like the younger cousin of an Inwin S500. Is this an actual Inwin case or a clone?
Reply 33053 of 53165, by Horun
wiretap wrote on 2020-03-18, 18:12:
CT1350B for $9 shipped. […]
Wow good price ! Hope it works
Reply 33054 of 53165, by Horun
LewisRaz wrote on 2020-03-18, 22:29:
Nice ! Good looking case. I have one of those 30pin to 72pin adapters from back the 90's.
Reply 33055 of 53165, by Munx
piatd wrote on 2020-03-19, 00:59:
Don't know, I could not find any markings on or in the case.
My builds!
The Underdog - The budget K6
Reply 33059 of 53165, by imi
liqmat wrote on 2020-03-19, 15:07:
imi wrote on 2020-03-19, 12:21:
got some cpu trays... 🙁
Good lord man, I hope you're not split on whether to contact the seller for a refund.
I see what you did there x3
but yeah I already messaged the seller.
I only paid 4€ including shipping for both, that paper envelope was not enough evidently... I didn't expect them to be this brittle either.
