Reply 33240 of 53165, by derSammler
I never had a single RAM chip failing on any of my hardware since 1996. Maybe I'm just lucky. 😉
If I ever had bad RAM, it was already bad when I got it. ESD damage most likely, as people tend to touch that stuff without any care.
Reply 33241 of 53165, by wiretap
Always underclock the RAM and GPU to test as well. If it still occurs, it is likely a bad chip, broken solder joint, or bent legs on chips.
The easiest quick fix (not long term) is to soak under the GPU BGA chip with liquid flux and reflow with a hot air pencil using a BGA/socket style square tip. If that doesn't solve it, replace the RAM since it should be pretty cheap.
My Github
Circuit Board Repair Manuals
Reply 33242 of 53165, by mpe
Bought Mach32 Graphics Wonder ISA VGA.
I plan to challenge my soldering skills and upgrade it to 2MB. I hope it is just a matter of adding 8 DIP sockets and no other components are necessary. Anyone has successfully done this?
406.98 KiB
Blog|NexGen 586|S4
Reply 33243 of 53165, by Cyrix200+
mpe wrote on 2020-04-03, 13:25:
You might need another BIOS image also? You could try and find an owner of a 2MB card.
1982 to 2001
Reply 33244 of 53165, by imi
nice ^^
also timing, I bought a Mach32 Ultra Pro VLB just two days ago ^^
Reply 33245 of 53165, by Benetton93
It's april now, and that means - it's time for mine retro hardware (or rather motherboards) pickup report.
And since we're living in difficult times (because COVID-19), i'm mostly staying at home, and i was able to test all of them.
Without further ado, let's go.
Socket 5 - BCM Advanced Research SQ588
First S5 mobo in my collection. Never heard of this company before (and no wonder why - they're mostly making industrial things as far as i understood).
Also it's awesome that they still have BIOS updates and manual on their site.
Socket 7 - A-Trend ATC-2000
Very useful mobo for me since it's only 430HX in my collection that can support Pentium MMX processors.
Socket 7 - ZIDA 5DXP
430FX mobos are getting kinda rare nowadays.
Also there's fancy WinBIOS.
Socket 7 - FIC PT-2003
Socket 7 - Chaintech 5TDM2
Socket 7 - ZIDA TX98
Another S7 mobo that was somewhat hard to find. No wonder though - i heard a lot of good things about that mobo.
Socket 7 - ZIDA TX100-3D
Unlike TX98, i heard a lot of bad things about that motherboard, but i can understand that - there's no L2-cache whatsoever.
Socket 7 - PC Chips (Elpina) M539
Welp. This is quite a rare occasion - i was looking for that PC Chips motherboard. Mostly because chipset (ALi M1521 Alladin III if i'm not mistaken).
Socket 7 - Chaintech 5SDA
Interesting mobo for me (because one-chip 5598 chipset with built-in video).
Super Socket 7 - Chaintech 5AGM2
Instead of DIN5 connector there's couple of PS/2 ones.
Super Socket 7 - Lucky Star 5MVP3
Super Socket 7 - Lucky Star 5MVP4
Another interesting pickup for me - SS7 mobo without AGP (because there's built-in video in the chipset, Trident CyberBlade i think).
Slot 1 - ABIT BF6
Quite nice late Slot 1 mobo.
Slot 1/Socket 370 - ECS Elitegroup P6BAT-B
Another ECS slotket mobo in my collection. This time it's in AT format, and... i feel some disturbance in the force...
...Why this mobo looks and feels like it was made by PC Chips? ("golden" AT PSU and keyboard connectors, V1.3 in the upper left corner)
Socket 370 - Gigabyte GA-6VXC7-4X
I want to finish my pickups report with a slightly changed quote from TES IV: Oblivion - Stay safe, citizens. These are dark times.
Stay healthy, guys. 😀
My retro PCs:
ZIDA 5STX, PMMX-166, S3 ViRGE/DX, 3Dfx Voodoo 1, Creative CT4830
AOpen AX-34U, P3-1133, GF 3 Ti200, Aureal Vortex 2
Allround 815EPT, P3-800, ASUS V7700TIvx/32M, Creative SB0220 (my first PC from 2001)
ASUS P3B-F for tests
IBM ThinkPad R31
Reply 33248 of 53165, by pentiumspeed
I have same heatsink, they are the best for socket 462 with four hole mounting. Not all motherboard have these holes.
But there are clip on heatsinks with copper forged in the base.
Great Northern aka Canada.
Reply 33249 of 53165, by assasincz
wiretap wrote on 2020-04-03, 12:48:
I think I will try tommorow if pinching the GPU from bottom and from top reveals anything and eventually I will try and bake it in the oven. I revived a dead AWE32 card that way and it works fine a year later so why not try it? I have neither any equipment for resoldering surface mounted components, not the still to do it anyway...
Reply 33250 of 53165, by dionb
Today was a good day 😀
Three parcels:
#1 and 2:
238.13 KiB
Micronics 80486 ASIC EISA 50MHz and a CT2290 SB16. The motherboard is slightly less pristine than promised, the battery has clearly been removed - and not a moment too soon, there's nasty green residue on the nearest two components, though in such small volumes I'm not hugely concerned:
169.2 KiB
Hope to get round to firing this beast up tomorrow. And the CT2290 - well, probably the nicest SB16 - non-PnP, real OPL3, low self-noise and as few MIDI bugs as you're going to find on a SB16. It's a freebie from a friend I recently gave a dual Opteron server board. Do ut des 😉
#3:
104.42 KiB
This one is completely new and unused - an Acer Accufeel 6316 6312TW-4U with Acer Black switches - basically what you get if you put the top parts of an Alps clicky switch over a rubber membrane (similar idea to the IBM Model M, but far lighter). Looking forward to typing with this for a while, if only because it's ISO and I far prefer that to ANSI (or big-ass enter monstrosities).
Reply 33251 of 53165, by vetz
After years of searching I finally got hold of the ASUS C-PKND cpu card for my P65UP5 board. It came fully boxed, just missing the brackets.
1.76 MiB
1.86 MiB
1.9 MiB
Reply 33252 of 53165, by H3nrik V!
vetz wrote on 2020-04-03, 21:14:
After years of searching I finally got hold of the ASUS C-PKND cpu card for my P65UP5 board. It came fully boxed, just missing t […]
Circled that one on eBay .. Glad to see it in the hands of a collector 😀
Reply 33253 of 53165, by badmojo
dionb wrote on 2020-04-03, 20:53:
... and a CT2290 SB16.
Great card! The only complaint I have with this card is the proximity of the black CD-IN header to the wavetable header - it fouls a DB. Nice UAT Creative! Easy fixed though you can just yank the black plastic shroud off and still use both headers.
Reply 33254 of 53165, by dionb
badmojo wrote on 2020-04-03, 21:23:
Yep, sometimes you really wonder if anyone at Creative cared about quality during the SB16 era. Taken together the models after the original 1730 look like bunch of unfinished prototypes. Probably all the engineers did care, but the marketing department told them to shut up and deliver...
In any event I'm not worried about the header, I only have one DB and no way am I using it on any buggy SB16.
Reply 33255 of 53165, by appiah4
I also have a CT2290 SB16 and a Dreablaster S2 fits fine onto it. It's one of the least buggy SB16s, and to be fair I use an ES1868 instead of that in my 6x86 PC these days, I didn't run into any severe MIDI bugs while I used it.
Reply 33257 of 53165, by luckybob
@VETZ
Awesome! I saw that listing come and go. If I had the funds, I would have snagged it first. the P65UP8 is probably my favorite dual cpu board I have.
@nhattu1986
very nice! Those cpu coolers are hands down, the best coolers you can get for that socket. Only practical way to get colder cpu temperatures would be to go chilled water.
Reply 33258 of 53165, by pentiumspeed
appiah4 wrote on 2020-04-03, 10:20:
derSammler wrote on 2020-04-03, 09:36:
while RAM chips are normally quite reliable.
Not in my experience.
True. Years ago, I had a PCI Tnesg ET4000w32i/p with one bit bad outside of typical memory requirement on windows 98se. I had extremely long bookmarks in firefox. One day I happened to scroll all the way toward bottom and was greeted with band of artifacts across whole width of monitor. I eventually replaced all the vram on this card and problem disappeared.
Cheers,
Reply 33259 of 53165, by Horun
Today was a good day :) […]
#3:
This one is completely new and unused - an Acer Accufeel 6316 with Acer Black switches - basically what you get if you put the top parts of an Alps clicky switch over a rubber membrane (similar idea to the IBM Model M, but far lighter). Looking forward to typing with this for a while, if only because it's ISO and I far prefer that to ANSI (or big-ass enter monstrosities).
What year was this made ? Does it work with both XT and AT ? I saw one for sale stating it did but no picture of a switch to change modes. Just curious if I passed on a good deal...
