Reply 33500 of 40045, by bjwil1991
1.2MB FDD, 4x 32MB SIMM-72 60ns FPM RAM for both of my 486 machines, Cirrus Logic CL-GD5429-86QC QFP video chip for my Packard Bell (upgrading from the 5428 for better DOS performance), 512Kb SRAM 32-pin PDIP (2 packs of 5 chips), and C64 PLA replacement.
47.33 KiB
Reply 33501 of 40045, by imi
1 stick of 32MB FPM for $40? 😮 oh good 4... I was a bit shocked there x3
Nexxen wrote on 2020-04-20, 23:42:
I know that this message is old but so are our beloved retro rigs. I have been trying to find the pinout for this HT12888A chip […]
alexanrs wrote on 2015-05-20, 14:02:
Yesterday I got a new Dallas DS12887a RTC for my P-133. It originally had a VIA82887-based HT12888a. Even though I've read in se […]
Yesterday I got a new Dallas DS12887a RTC for my P-133. It originally had a VIA82887-based HT12888a. Even though I've read in several places that they are not 100% compatible, the PC works fine with it. And yes, I knew I could try modding the original RTC adding an external battery... and I actually tried that a while ago, but I was a bit careless then and broke one of the battery pins, so I had no choice but to replace it.
(original link deleted)
I also got this Media Magic Audio16c ISA sound card. Apparently, this is a very close clone of the OPTi 82c929a-based Turtle Beach Monte Carlo... I even used the Monte Carlo's drivers successfully. My only gripe with this card are the crystals: this one has taller crystals than the ones in Monte Carlo, so it interferes somewhat when mounting a WT daughterboard. Might replace them in the future. Also getting this thing going was a bit finicky... I had to assign IRQs, DMAs and port adresses manually in my Compaq's BIOS. This thing needs 3 IRQs (one for SBPro, one for WSS and one for MPU401, and the driver craps out if you try using the same one between two of them)!
This board impressed me: Media Magic apparently copied Turtle Beach very well. The Line Out is cleaner than my YMF719-s cheap card (which wasn't bad in the first place), WSS doesn't give me weird crashes in Warcraft II and SBPro mode doesn't sound as... harsh? Anyway, does anyone know how to switch from SBPro mode to WSS mode from the command line? Unlike the YMF719, this doesn't switch automatically. Also, I had issues using he SBPro part in IRQ5, as this worked in pure DOS but the Windows drivers did not work correctly with it, IRQ7 is trouble-free. Also, does anyone know why this board needs a separate IRQ for the MPU401?
I have been trying to find the pinout for this HT12888A chip to no avail. Can you confirm that you haven't had any issues over time using the DS12887A?
That would be awesome.
Tomorrow I'll try to do the battery trick by dremeling to the battery pins, hoping it'll work.
that poster has been last active over three years ago ^^ better make a new thread.
Reply 33502 of 40045, by Nexxen
imi wrote on 2020-04-21, 00:08:
I have the same motherboard and need to know if it did work for him. Alas I don't know if the mobo model o rtc model are good as thread title.
What title do you suggest, PcChips M530 or Houston Time HT12888A?
Nothing else in the world smells like that.
I love the smell of burnt components in the morning.
Reply 33503 of 40045, by Nexxen
Tomorrow I'll start a thread as I have found a solution to my problem.
The plastic cap pops off and you find a VIA VT82885N chip with a battery soldered to the VCC pins.
Reply 33504 of 40045, by boxpressed
Didn't really need one of these, but it was cheap. And beige.
I thought I might use it to switch between my 98SE and XP HDDs for my Athlon XP/KT133A build. But probably a lot easier to open the case and just move the IDE cable and Molex power connectors.
1.22 MiB
Reply 33505 of 40045, by cyclone3d
boxpressed wrote on 2020-04-21, 02:45:
I tried drive docks back in the day. When they work they are fine but they tend to be super flaky.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 33506 of 40045, by sunaiac
bjwil1991 wrote on 2020-04-21, 00:05:
What kind of gain do you expect from that ?
It's on a PB450 ?
Because mine is abysmal, even with a DX4-100 OD it's basically just above a standard DX2-66 performance 🙁
R9 3900X, X470 Taichi, 32GB 3600CL15, 5700XT AE, Marantz PM7005
FX-57/X1950XTX/Audigy 2ZS | Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
i7 980X/R9 290X/X-Fi titanium | Ppro 200 1M | Voodoo 3 2000 | AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 33507 of 40045, by imi
cyclone3d wrote on 2020-04-21, 04:15:
I used them a lot in the early days and never had any issues ^^
Reply 33508 of 40045, by Daniël Oosterhuis
Got two Goldstar Prime ISA I/O cards, paid €5 for each. One's a Prime 2C, the other just a P2. The P2C has the jumper settings silkscreened on the back, but the P2 does not. All the pictures I can find of this P2 (AIO-200G) have them unpopulated, and I can't find any resources about them. I figure I might need to experiment with this card and figure out what jumper does what. Most I really care about is the ability to turn off the Gameport, in case I put it in a system with a Gameport-equipped soundcard. I mainly bought them for my upcoming 386DX40 build, one for the system and one as a spare (that I might use in a different system, maybe if I ever dabble with a 286), so the P2C is likely going in the 386.
I also gave the P2C some fresh caps. Why? Well, I had three Panasonic 25V, 10uF caps spare from a Mouser order (polarized despite the lack of a clear marking on the cap itself), and this one had two 16V, 10uF caps. Yeah, it's completely pointless, but it's a few-minutes job with my desolder station, and hey, fresh caps make me happy, so there's that 😜
bAdMSDt.jpg?1
Reply 33509 of 40045, by gex85
imi wrote on 2020-04-20, 17:06:
don't think this needs any words :3
I was watching this auction as well... initially the card was listed with the "Buy now" option enabled for only 30€, I was tempted to buy it but didn't do it because I didn't have any real use for the card... 😄
1992 - i486DX2-66 // 1997 - P1-233 MMX // 1998 - P2-350 // 2000 - P3-650 // 2001 - Athlon 1400 // 2003 - Athlon XP 3200+ // 2008 - Xeon E5450 // 2015 - Xeon E3-1240v5
Reply 33510 of 40045, by imi
why'd you have to tell me this x3 I'd have bought it straight away... it's a pity the ebay alert system isn't useful at all, I often get emails about new things a day after I've already found them myself x3
edit: 🤣... just after I posted this I got an email from ebay about a new listing... with buy it now...
I now finally have a Vortex 2 😁
Reply 33511 of 40045, by dionb
Just a single card today - but an interesting one. Top in this picture is the AudioExcel AV310 I already had, below the new acquisition.
225.94 KiB
CMI8330 cards are always welcome - I like their SBPro2+SB16 support and bug-free MIDI (and can forgive iffy FM). But take a look under the MIDI/gameport connector. Every other AV310 I know has those pads unpopulated. This one has stuff there with "3D Surround" silkscreened on it. Interesting 😀
Reply 33512 of 40045, by appiah4
dionb wrote on 2020-04-21, 22:09:
I also happen to have one of these cards (Zoltrix Audio Plus 6400 3D PnP V.5 AV310 - quite a mouthful indeed), but I never thought much of it because its OPL3 Synth is considered to be particularly subpar. I should certainly try it out sometime!
Reply 33513 of 40045, by brostenen
My SixyClone board arrived the other day. It took me some time to take a decent picture, as my camera does not like the board for some reason. I must say that I am impressed. High quality and feel like better quality than the original. And it looks so sweet with the black and gold and white letters. I am deeply impressed by this board, and I think it is well worth the money. As I have done my 500-Desktop machine already (I really thought it would take me a whole year), then this will be my new 2020 project. To make a complete and as new as possible Commodore64. Ready for the next 30 to 40 years of use.
164.07 KiB
Reply 33514 of 40045, by dionb
appiah4 wrote on 2020-04-22, 08:57:
I also happen to have one of these cards (Zoltrix Audio Plus 6400 3D PnP V.5 AV310 - quite a mouthful indeed), but I never thoug […]
OPL isn't great, but it's far from the worst, I'd say closer to CQM than AD/OPTi nastiness.
OPL aside I really like this though - good SB16 compatiblity (no, no ADPCM, but unless you're a Duke Nukem 2 fan, that's not too relevant), SBPro2 compatibility, but also WSS support and bug-free MPU401 MIDI. Oh, and digital in/out.
Reply 33515 of 40045, by Caluser2000
Haven't got anything new lately but I have reorganized all my computer stuff. Glad I did it because now it is far far easier to locate stuff when I want it.
Reply 33516 of 40045, by mpe
Bought finally genuine 12ns SRAM chips for my experiments. Just 8kx8, but still -12 😀
One of my system will get 64k L2 cache....
586.74 KiB
Blog|NexGen 586|S4
Reply 33518 of 40045, by LewisRaz
Nothing exciting, but something very helpful.
I am slowly trying to convert all of my retro PCs to have CF on these PCI brackets as the easy access to transfer files is a gamechanger.
    211.76 KiB
My retro pc youtube channel
Reply 33519 of 40045, by wirerogue
i've been playing musical cases lately with my p4 3.0, 5950 ultra build.
first, i had it in an antec slk1600 but, cooling wasn't very good and i needed a home for my p4 1.9, geforce4 ti4600 build.
then i moved it to an antec slk2650 which has a little better cooling due to 120mm case fan but, the case was black and still a little on the small side for this much heat.
i think this will be it's new permanent home.
nos antec sx1000ii in oem packaging.
907.16 KiB
737.86 KiB
530.19 KiB
1.5 MiB
