Reply 33600 of 40044, by Horun
Horun wrote on 2020-04-26, 16:36:
Local guy has an old Compaq P4 tower for $15, has bad/missing HD but otherwise works/boots. Includes original keyboard and ms mouse. Told em I was interested so will go meet somewhere later today.
EDIT: Not a Compaq, actually not a bad little machine. Will post specs later after I clean it up a bit...
So it was advertised as a late 90's Compaq for $15. Ended up being an Enlight case, 300watt psu (w/good +3.3 / +5v combined !), an Intel D865PCD AGP board w/2.93 P4 & 512Mb ddr, GV-R7064T AGP card, PCI modem, one 16x CDrom, one BenQ 1650 DVDrom. (The 16x cdrom has a door open issue, bad belt probably). Everything dated 2004. Only needs an HD and need to match up a front slot cover (or put the bad rom back in). Well am actually glad it was not Compaq since they had all the original driver/software cd's including the one for the motherboard.
Edit: the more more I play with it the better I like it. Makes a great early 2000's gaming computer for BF1942, Heroes, etc
    225.54 KiB
    43.69 KiB
    73.72 KiB
    205.99 KiB
    230.14 KiB
Reply 33601 of 40044, by imi
boxpressed wrote on 2020-04-26, 23:16:
I bought this NOS ASUS MediaBus VGA/Audio card without even owning a MediaBus motherboard. It's just so strange that I had to have it for my collection: S3 Vision868 and Creative Vibra16 (and OPL3) on the same card. Maybe one day I'll build a system around it.
ooooooo nice!
I have several mediabus boards even used to have one back in the day in my pentium system, but no card x3
this also seems like the best combo out there at a quick glance.
...got an alert for the aureal from ebay and quickly took the chance because I was looking for one for months already and I got outbid at every chance x3
also took the opportunity to pick up a few other cards from the same seller who turned out to be a fellow vogons member ^^
716.72 KiB
Reply 33602 of 40044, by Artex
LOVE this! Nice score!
Click [here] to see my collection of retro bliss!
Click [here] to see my "I just gotta have it"' list!
Reply 33603 of 40044, by seanneko
I got an Intergraph TD-310 today.
The seller simply just had it listed as "old 1997 computer" with no details and just a few poor photos. The case is very unassuming, so I almost ignored it thinking it was some generic OEM Celeron or something. But in the corner of one of the photos, I saw what looked like part of a socket 8 socket, so I thought it was worth a gamble to see what the deal was.
Turns out it doesn't just have one socket 8, but dual socket 8. It's a proper workstation with full SCSI, stainless steel chassis, etc. And interestingly, only one of the CPUs is removable. I guess they thought you'd never want to upgrade the primary CPU...
Sadly the proprietary PSU blew up and I can't see anything obviously wrong with it, so I'll have to wire up an ATX PSU to find out if it works or not.
Reply 33604 of 40044, by bjwil1991
Wow, man. That is one amazing machine. The PSU issue might be only bad caps. I can look and see if there are any proprietary PSUs available, but I won't post the links since it's considered advertising and frowned upon by the moderators and admins of this site.
Reply 33605 of 40044, by H3nrik V!
seanneko wrote on 2020-04-27, 06:02:
I got an Intergraph TD-310 today. […]
Now that's cool! What about cooling of that primary CPU? As far as I can see, the tabs for holding the heat sink clips are narrower than on a socketed one?
Reply 33606 of 40044, by bjwil1991
They look about the same to me, though. The lighting doesn't distribute well.
Reply 33607 of 40044, by seanneko
The PSU had a blown fuse, so I replaced it hoping that's all the problem was. But then when I plugged it in I got several huge sparks around the area with the power regulators. I've looked it over pretty closely and I can't even see anything that looks damaged/burnt. Cosmetically it looks perfect...
Reply 33608 of 40044, by seanneko
H3nrik V! wrote on 2020-04-27, 06:11:
It has a fairly large passive heatsink which attaches to the black clips. The metal piece with two rivets in it is a duct which directs air from the vents on the front of the case down to the CPU heatsink. There's no duct for the secondary CPU, so I imagine they expect you to install one with active cooling.
There are two big exhaust fans attached to the side of the PSU. These are the only fans in the entire system.
Reply 33609 of 40044, by bofh.fromhell
dionb wrote on 2020-04-23, 20:58:
H3nrik V! wrote on 2020-04-23, 20:16:
appiah4 wrote on 2020-04-23, 18:59:
I really want a dual Socket 370 one day, even if it is a Mendocino only board I can run dual Celeron 533s on. I want to run Windows 2000 on it..
Even better .. You can run 366's clocked at 550 😉 I'll try updating my BP6 with 400's hoping they'll scale up to 600 .. I've bought 4 of them, hoping ..
Had a few back in the day, never got over 83MHz FSB with them. Then again, I was plain unlucky, my 366 didn't want to go over 500MHz no matter what I did either, and to add insult to injury when I got my hands on a 300A later it wouldn't even do 450MHz - and that was despite using nice boards with full voltage and per-MHz FSB control. Fortunately had better luck with K6-2 and P3 - ran my P3-700 at 933MHz for a few years on the same board I couldn't get the C366 past 500MHz.
After I refurbished my BP6 a while ago I set out to get me some good overclocking chips.
Found that all the 300A's I got worked fine at 450MHz with stock voltage.
Even found one that would do 600MHz at 2.3v (!).
366's were a different story tho, ended up getting 10+ of them before I had a pair that would work at 550MHz with only a slight increase in voltage (2.1v).
Luckily a German reseller dumped tons of these chips on ebay for around 1€ each.
Reply 33610 of 40044, by dionb
Wow, any Intergraph machine is interesting, but a dual PPro is fantastic.
Is it just me, or does this case look almost idential to a Sun Sparcstation Ultra 5? I'd be willing to wager it's a Mitac OEM design as well.
Reply 33611 of 40044, by Tiido
Salient wrote on 2020-04-26, 13:16:
I doubt I can do anything with it related to DOS gaming though. Or would it be MT-32 compatible with a few tricks?
Sample ROMs are completely different and there's few other differences so it will unfortunately never be MT32 compatible even though it uses exact same core chips.
Reply 33612 of 40044, by Lennart
Tiido wrote on 2020-04-27, 12:09:
A couple of the old Sierra adventure games had patches for the Roland D series. You can download them here: Roland D series drivers/patches for Sierra games
Reply 33613 of 40044, by Cloudschatze
I'm not sure if Sierra just never tested it, or what, but their D-10/20 support is mostly unusable. I don't want to spoil the surprise, but these synthesizers lack a specific function (present in both the MT-32/variants and D-110) that precludes proper soundtrack playback.
Reply 33614 of 40044, by darry
Dell 2007FPB arrived . It's the S-IPS variant, made in 2009, and has 50000 odd hours on the clock .
For a total of 105 Canadian dollars including shipping, I would call it a good deal .
Reply 33615 of 40044, by SodaSuccubus
How has shipping and parcels arriving been for you fellow Vogoners?
Mail systems are backed up to hell here in Canada due to Covid-19 and everyone seems to be a bit paranoid as to weather things are gonna arrive or not.
Had a bit of free coin and picked up a few 486 items, including a nice Lucky-Star 5x86 Combo. Allready bought a Cirrus Logic for my existing VLB board, but i thought i'd pickup a PCI mobo while at it.
495.11 KiB
I know the 'bay is probably the worst place to get good deals on 486, but sometimes one sees something cool and caves ;-;
Reply 33616 of 40044, by LewisRaz
SodaSuccubus wrote on 2020-04-27, 20:02:
How has shipping and parcels arriving been for you fellow Vogoners? Mail systems are backed up to hell here in Canada due to C […]
My best deals have actually been on the 'bay... Just patience and hope... The "local pickup only" ones are the best. And the big piles of junk where you spot a gem..
Postage here (south east UK) has been relatively good. Couriers have been amazing and royal mail only about a day later than normal.
My retro pc youtube channel
Reply 33617 of 40044, by imi
local postal service is working just fine 😀
some more stuff that recently came out of quarantine ^^
Hercules Game Theater XP complete and in box 😀
390.43 KiB
335.35 KiB
this pretty old but well equpped Enermax EG701AX-VH 600W PSU
has all the bells and whistles, and both a beefy 5V and more than adequate 12V rail for the time.
354.92 KiB
DELL Inspirion 7500
"desktop replacement" from 1999... I don't know the exact specs yet, can't really read into the model numbers, will have to see when I try it out.
I stumbled on this luckily on ebay for a low buy-it-now price just after it was listed when I was looking around randomly and just clicked instantly as dozens of people had it open already apparently x3
it has a Super LS drive, so I expect a higher spec at least.
162.71 KiB
140.1 KiB
Reply 33618 of 40044, by Artex
imi wrote on 2020-04-27, 20:54:
Awesome!!! Nice score!
Reply 33619 of 40044, by imi
thank you :3
this will go nicely with my Hercules ProphetView 920DVI... going to have to make a build around that with a Hercules 9800Pro ^^ gotta get some Hercules speakers too. any other suggestions? x3
