Reply 33780 of 40043, by H3nrik V!
darry wrote on 2020-05-06, 00:43:
According to http://www.os2museum.com/wp/486-overdrive/ […]
jheronimus wrote on 2020-05-06, 00:30:
Deksor wrote on 2020-05-05, 23:43:
Oh among them is the most useless overdrive ever : the DX2 overdrive 😁
What would you say about an Overdrive SX-20 then? 😀
"The lowest end model was an OPD486SX-20, a 40 MHz clock-doubled model."
Talk about brain-dead branding .
Well, the original Overdrives were named after what they were supposed to replace, as I understand it. I.e. the ODP486-SX20 was supposed to replace an SX20. But AFAIK all overdrives were DX/DX2/DX4. But yeah, bad branding. Maybe that's why they changed it along the way .. 🤣
John has written an iteresting article on the subject:
http://www.cpushack.com/UpgradeProcessors.htm … tel486overdrive
Edit: All of which is confirmed in the article from os2museum.com
Reply 33781 of 40043, by Daniël Oosterhuis
Today's arrival is a Philips PCA750AF soundcard. Philips had some interesting cards, like an AMD InterWave-based GUS PnP Clone, and this card, which uses a YMF719E-S chip. Got this one for €5 from a Dutch techsite's classifieds section, which I thought was a great price for a legit Yamaha card. Tried it out with Unisound on my latest Socket 7 system, and yeah, sounds like it should under Wolfenstein 3D and Doom! A nice one for the collection.
vHVPRVN.jpg?1
hGyUcgf.jpg?1
Reply 33782 of 40043, by Deksor
Well this one fits into a LIF 169 pin socket, which is useful when your motherboard has a soldered 486SX and a 487 upgrade socket. The DX2 overdrive on the other hand is exactly the same as a normal LIF168 DX2.
alternative
Reply 33783 of 40043, by Bancho
I had a nice system turn up today. I don't normally buy full systems, but this looked in great conditions and the parts looked to be really good also.
Its a Dan Mini Tower Intel 486 DX2 66mhz built in '94
Intel 486 DX2 66mhz
20mb ram (8x30pin Simm Modules)
Asus isa-486sv2 Rev 3.10 VLB motherboard (battery removed, no apparent damage)
Sound Blaster 16 CT-2830 SB16IDE (Genuine OPL3 onboard)
Promise VLB IDE Controller with 4mb cache
345MB Hard Disk
Cirrus Logic AcuMos ISA VGA Board
Serial/Parallel Card
Logitech Mouse Controller
Panasonic CD-Rom
Case is in lovely condition for its age. I've always liked these upside down towers. Bezel on the CD-ROM is yellowed so will try and sort that out.
I will upgrade the VGA Card to a Cirrus Logic VLB one i have and maybe fit a larger hard disk (1 or 2.1 gig)
Reply 33784 of 40043, by mpe
Deksor wrote on 2020-05-06, 11:34:
Depends if the DX2 overdrive is ODP or ODPR.
It isn't exactly the same. It doesn't have test scan signals, different cpu id. I also believe that UP# pin is always driven low on overdrive chips even on ODPR.
Also overdrive chips are always write-through. Ordinary DX2 chips have write-back cache in certain sspecs.
Blog|NexGen 586|S4
Reply 33786 of 40043, by liqmat
Bancho wrote on 2020-05-06, 12:53:
I had a nice system turn up today. I don't normally buy full systems, but this looked in great conditions and the parts looked t […]
Intel 486 DX2 66mhz
345MB Hard Disk
Panasonic CD-Rom
Very nice. Now you just need to put Microsoft Bob on Dan.
Reply 33787 of 40043, by imi
nice 😁
I'm still always looking out for those inverted AT cases, but they always get crazy expensive.
got a few sound cards :3
Terratec Maestro 16/95 Ver. 1.0 (16/96)
in box with tiny speakers and all goodies, partly still sealed, I think this one is actually new.
525.83 KiB
499.28 KiB
Terratec Base-1, I already had one of these, but got it for the wavetable board, Terratec WT64
412.07 KiB
míro Sound PCM1 Pro... after missing out on the one in a scrap lot I now got one with manuals :3
323.93 KiB
Guillemot Maxi Studio ISIS, seems complete
535.13 KiB
Reply 33788 of 40043, by austinham
imi wrote on 2020-05-06, 13:48:
nice :D I'm still always looking out for those inverted AT cases, but they always get crazy expensive. ... […]
nice 😁
just flip a case upside down?
Reply 33790 of 40043, by pentiumspeed
Back in the day, one of local pc stores that I worked at and many stores around used those fat and short towers with those plastic rails, these were specially made so drives is not loose when installed.
Cheers,
Great Northern aka Canada.
Reply 33792 of 40043, by ShovelKnight
https://i.imgur.com/dlDAEYTl.jpg https://i.imgur.com/4vtZo45l.jpg […]
This is my favourite Baby AT case style, I hope one day I will find one nearby without having to pay 100€ for shipping.
Reply 33794 of 40043, by Cyrix200+
<snip>
Looks like it came from the same factory as this case, only a bit later 😀
1982 to 2001
Reply 33796 of 40043, by Intel486dx33
Cyrix200+ wrote on 2020-05-06, 14:57:
Looks like it came from the same factory as this case, only a bit later :) […]
<snip>
I had one of those back in 1990’s
I never used it however because I did not have the hard drive rails.
I regret sending it to the recyclers.
Nice case.
Reply 33797 of 40043, by APFSDS
I got a auzentech prelude and forte a couple of weeks and just got around to using them. The forte needs a heat sink because the rev.1 cards like to kill themselves.
uc?export=download&id=1ZsJC5uSru3IZlzauMkfrKxNLOVYrWsNP
Reply 33798 of 40043, by Cyrix200+
imi wrote on 2020-05-06, 15:00:
^ that's the exact case I want ^^
My dad's 386SX 16MHz came in this case. That's the machine I gamed on for a loooong time 😀
I was very happy when I finally found this case again. I have two now...
1982 to 2001
