Reply 33820 of 40042, by Skanque
devius wrote on 2020-05-07, 16:29:
Skanque wrote on 2020-05-07, 14:21:
STB Velocity 128 PCI RIVA TNT 1997 […]
Nice crappy glued on stock TO-220 cooler there 😆
You know stb.. only the highest quality is good enough.. the caps is also hovering 5mm off the board
Reply 33821 of 40042, by Katmai500
Big Pink wrote on 2020-04-04, 14:21:
My devotion to period-correctness led me to spot this Pentium 3 SL48S "1000G" on the Bay of E. Datecoded Week 18 of 2000 (first week of May)! An early production run for OEMS?
Even better. It's a boxed retail CPU. Produced in May 2000 is pretty early. Only 2 months after the March paper launch. Very very nice!
Reply 33822 of 40042, by BloodyCactus
oops posted in wrong thread;
Picked up a Roland A-880 with manual, so I can replace my MPU 104 + MPU 105 now.
Skimming the manual... battery backup.. uhoh.
yep.. there it is but its retention clip looks to be soldered to the motherboard. uuuugh. damn. Thats a job for the weekend.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 33823 of 40042, by MMaximus
imi wrote on 2020-05-06, 13:48:
got a few sound cards :3 […]
Guillemot Maxi Studio ISIS, seems complete
Be very careful with the external rack: you can't "hot plug" it. Always plug or unplug the rack when the computer is turned off
Reply 33825 of 40042, by pan069
Not very exciting, but from experience, low quality IDE cables suck. I was happy to find high quality brand new ones locally for not too much. I tried IDE cables out of China before (although these are also made in China) and they fell apart just by looking at them. The shitty Chinese cables were a slightly darker gray then the ones I always used before.
Are these cables keyed, you ask? No they're not... 😀
Reply 33826 of 40042, by imi
MMaximus wrote on 2020-05-07, 22:56:
thank you, I wouldn't have tried... but plugging and unplugging audio devices from the rack should be fine, no?
Reply 33827 of 40042, by Horun
Did not buy it but this is the first 8bit ISA slot only, 286 I have seen. Most all 286 have a few 16bit slots but not this one.
Reply 33828 of 40042, by darry
Horun wrote on 2020-05-08, 01:42:
31MHz CPU, that sounds so very standard .
EDIT : 12 MHz according to https://stason.org/TULARC/pc/motherboards/H/H … 86-HED-919.html
Reply 33829 of 40042, by darry
Received my supposedly refurbished Dell U2412M from newegg.ca. It arrived naked in its cardboard box with no screen protection and loose cables. As a bonus the cardboard struts inside had failed so the screen was rubbing against the inside of the of the box and the power cable . Maybe that's what caused the half centimeter scratch close to the middle of the screen, or maybe it was already there as part of the "refurbishing" process .
The monitor was advertised as refurbished, without a grade . I am not a happy camper .
1.94 MiB
https://www.newegg.ca/dell-u2412m-24-uxga/p/N … N82E16824260702
EDIT : I will contact their customer service tomorrow .
EDIT : There is 1 other small blemish, but the one in the photo is simply not acceptable to me .
Reply 33831 of 40042, by darry
kolderman wrote on 2020-05-08, 03:55:
This happened to me once. I only buy screens new now, or for dirt cheap prices if it's retro monitors.
The worst of it is that I paid 40$ shipping on it, so it would presumably cost the same to ship back . I would be surprised if the yrefunded any of the shipping costs. So that means, in the best of circumstances, I'm going to be out 80$ with no monitor .
I've been spoiled by dellrefurbished.ca . Their stuff is accurately graded and I've had no bad surprises with the 4 laptops I've purchased from them so far . Oh, and they know how to pack .
I was actually expecting something similar from newegg.ca . Oh and I forgot to mention, there actually was bubble wrap in one corner of the box. They just never bothered to wrap the screen in it .
Reply 33832 of 40042, by austinham
darry wrote on 2020-05-08, 04:31:
The worst of it is that I paid 40$ shipping on it, so it would presumably cost the same to ship back . I would be surprised if t […]
Send it postage due or COD. If they don’t file a charge back.
Reply 33833 of 40042, by yawetaG
imi wrote on 2020-05-08, 00:12:
...when it's off, yes. Otherwise you run the risk of damaging internal components because of voltage spikes caused by parasitic noise. Also be sure to turn down all the volume pots/sliders before switching it on or off (for the same reason).
The loud *POP* people get when they turn on their amplifier? A potential killer of the device itself and especially any connected devices (it can especially blow speakers). Always turn on devices in outgoing order, with the volume off or at its lowest, and use the same order when opening the volume.
Reply 33834 of 40042, by bjwil1991
brownk wrote on 2020-05-07, 23:37:
I second this.
I third this.
Reply 33835 of 40042, by Cyrix200+
maverick85 wrote on 2020-05-07, 17:04:
Cyrix200+ wrote on 2017-01-11, 17:28:
An Aureal Vortex 2.
Hi, do you have the manual for this card. I'm trying to connect the dvd to the card so i can have clean sound via S/PDIF
No I don't have a manual I'm afraid. But I guess you could find it on Google maybe? It's not really rare or old 😀
1982 to 2001
Reply 33836 of 40042, by appiah4
yawetaG wrote on 2020-05-08, 05:39:
I have learned this the hard way with my 1978 Scott Amp/Tuner. It required extensive repairs afterwards.
People who clean the house LOVE to leave the volume dials at max for some reason....
Reply 33837 of 40042, by darry
austinham wrote on 2020-05-08, 04:44:
They will pay for return shipping . I said would prefer a replacement if possible. They will refund me if not possible . Considering the monitor was loose in box, face against cardboard, with loose cables inside and cardboard support structure had failed , it could be due to bad packing combined with rough handling .
This might be shipping damage, but I can't say for sure .
I also find it hard to believe that something as glaring would pass any quality control if it had been present before shipping .
Anyway, newegg.ca seems to be handling this in a fantastic manner so far .
Reply 33838 of 40042, by chrismeyer6
Well I'm glad it's being resolved satisfactory so far. But it just seems so weird for Newegg I've been using them since 04/05 and I've never had any issues with how they package and ship things even refurbished items. I really hope they fully resolve this for you.
Reply 33839 of 40042, by dionb
So, I bought myself a pile of "new in box industrial cards" this week. Arrived today, exactly as pictured in the ad, just with one extra card outside of a box:
186.7 KiB
I started unpacking them, leaving the motherboard for last. And had a bit of an anticlimax 🙁
198.85 KiB
No PCMCIA NIC and - much worse - no motherboard 🙁 🙁
However some nice surprises in the rest:
- The second sound card looks like the least crap ALS100 card I've come across - thick PCB, solid caps and a sensible-looking layout. Also LS-212 OPL3 1:1 clone.
- The IDE card has a BIOS, which is unusual for AT IDE, and supports not two but four floppy drives. Not sure how I would use that, but nice nonetheless.
- That extra card was a NOS Adaptec AHA-1542 - about the most standard, usable ISA SCSI card out there 😀
- I'd expected the true 'industrial' cards all to be data acquisition cards. One of them is (full of NEC D71055 parallel I/O chips), the other three (two in the big box!) are all battery-backed RAM disks.
Of course "battery backed" means nasty leaky NiCd, but fortunately there was only some frosting around the negative poll. Snipped them off before they could do any harm. Whats left is a 128kB SRAM board, configurable as floppy drive, and a 1024kB EPROM board (or 192kB SRAM, depending on whether you use 16 27512 EPROMs or 6 62256 SRAMs) which is bootable as option ROM. Nothing that an XT-IDE couldn't already do, but nice nonetheless. It also contains detailed instructions on how to install DOS onto the ROMs and a bunch of tools:
MAKEDISK.EXE - that makes ROM images out of a list of files.
RAMDRV.SYS - SRAM device driver for DOS
INITRAM.EX - format utility for the SRAM disk
Not at all sure what I'll be doing with this stuff, but will definitely be ordering some chips to try it out.
Oh, and bottom-right another parcel arrived: a Deschutes P2-400 and a Katmai P3-600, the fastest 100MHz FSB Katmai CPU. My MS-6168 utterly refuses any Coppermine CPUs (even though its dying twin from same revision happily accepts CuMine and even Tualatin), so might as well give it the fastest CPU it will allow.
The Tyan box wasn't empty though. Apart from some crap coax cables (TV/radio style) that went straight into the bin, and the Tyan S1590 manual and driver disk, it also had some reciepts from 1996 (3 years older than the box!) and a pile of prints of IBM 486 pinout & specification:
142.1 KiB
In 1996 in NL 256k of cache cost DFL 90 (about EUR 62 allowing for inflation), an IBM DX4-100 cost DFL 179 (EUR 125 now) and its motherboard DFL 269 (EUR 185 now). Will see if those IBM 486 specs are easily available online, if not will scan & preserve of course 😉
Edit: yep, found 10x 62256 SRAMs surprisingly cheaply and 16x 29C512 EEPROMs (for more flexibility if I want to re-use in 486 motherboards later) somewhat less so.
Edit2: found the IBM pinout document too: http://datasheets.chipdb.org/IBM/x86/486/40024.PDF - so no need to scan my papers.
