Reply 34060 of 40042, by yawetaG
liqmat wrote on 2020-05-19, 20:06:
cyclone3d wrote on 2020-05-19, 15:34:
No.. wasn't trying to be selfish. Just didn't want the Vogons thread to come up on a Google search or something and then have so […]
No.. wasn't trying to be selfish. Just didn't want the Vogons thread to come up on a Google search or something and then have somebody not on Vogons snag it and then we never see it again... as it is something that a few of us have been searching for for a while now.
In any case, the seller finally got back to me and is supposed to be getting me a shipping quote.
Once I get it, I'll post and put up the software on vogonsdrivers and a few other places.
This is definitely for posterity and I was just kinda freaking out that some rando would buy it to have in their collection and then not actually make a copy of the software and upload it for others.
I've also never used a shipping proxy service other than for yahoo japan auctions so wasn't sure where to look.
Didn't mean to start any drama... sheesh!
I've known you for awhile man and I knew what your intentions were. Seemed very clear to me. The petty drama that goes on here gets really tiring. I still have a bitter taste in my mouth after what happened with my Pentium Pro photos thread (user complaints... whatever). I basically just deal with Qbix or Stiletto at this point and I suggest you do the same. I do my hardware giveaways and photos elsewhere now because of it.
So...going by your thread there, it would basically be against the rules to first post pictures of an item, and later mention you want to get rid of an item? That's bordering on ludicrous. 😖
Reply 34062 of 40042, by CMB75
My totally overpriced Voodoo5 5500 AGP arrived today. Box and contents are in good shape … well, except for the fans - the next little side project will be replacing the extremely noisy stock cooling solution in a non destructive and reversible way.
Already feeling a little anxiety thinking about the ice cooling spray procedure to remove the heat sinks.
For initial testing the GF6200 (passive cooled) and the Diamond Monster 3D II had to go… hooray - we have liftoff - the card works (you can never be sure with stuff from the bay 😉).
Reply 34063 of 40042, by Skanque
CMB75 wrote on 2020-05-20, 08:17:
Congratulations with a very nice box and card. Before you remove the fans, why not try to oil them? Sewing machine oil does wonders for old ball-bearing fans!
Reply 34064 of 40042, by CMB75
Skanque wrote on 2020-05-20, 11:01:
I tried silicone spray and it didn't do that much. But thanks for the hint I will try sewing machine oil.
Reply 34065 of 40042, by austinham
wirerogue wrote on 2020-05-20, 04:51:
austinham wrote on 2020-05-19, 16:25:
nabbed this up for a good price.
6800 ultra hooray!!!
Believe it or not its a GT on a ultra PCB from Asus. But I intend to flash it to a ultra.
Reply 34066 of 40042, by cyclone3d
Ok... so here is what all the "secrecy" was about. Was not cheap at all .. in fact I may be insane for paying as much as I did but I just had to get it for posterity's sake and pretty sure I would never see it pop up again and we need the files on those disks as a community since most of them were nowhere to be found.
Behold - The Developer Kit for Sound Blaster Series (original version):
179.31 KiB
256.35 KiB
Now I just have to wait for it to get here and hope that the disks are still good. This was an unused kit so I am feeling pretty good about it.
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 34067 of 40042, by liqmat
cyclone3d wrote on 2020-05-20, 17:21:
Ok... so here is what all the "secrecy" was about. Was not cheap at all .. in fact I may be insane for paying as much as I did b […]
Dude, that is just pure awesome. Congrats!
If you do have trouble with the disks the ole shake & blow has worked for me for many years. Never give up! I even managed to manipulate data off a warped 5¼" disk with great patience.
Reply 34068 of 40042, by austinham
If the disks don't work in a normal FDD try putting them in a LS120 drive if you have one, they tend to read disks better. Or try running scandisk in a loop.
Ether way hopefully they work and they get put to use 😉
Reply 34069 of 40042, by cyclone3d
austinham wrote on 2020-05-20, 17:44:
I do have a laptop with an LS120.
When reading old 3.5" disks, I have about 3 different floppy drives I use as some disks work in some drives and not others.
Hope these don't have a problem at all. I haven't run across many old used disks that I wasn't able to get to read at least good enough to copy all the files off of. I have had a few that I wasn't able to make an image off of but was still able to copy all the files off.
I'm going to be a nervous wreck until they get here... heh.
Yamaha YMF7x4 Guide
Reply 34070 of 40042, by liqmat
Do yourself a favor though. Make sure you write protect them first so they keep their original last access date and image them with WinImage using the IMA format so it images the correct image size of the disk. Makes it easy to see what size the original disk was at a glance for others.
Reply 34071 of 40042, by austinham
liqmat wrote on 2020-05-20, 18:01:
Good idea.
Reply 34072 of 40042, by TheMobRules
When imaging floppies I make sure to do it from DOS, since it doesn't have the urge to modify the boot sector unnecessarily as Win9x does when accessing floppies. Of course, the write protection is always a good measure.
My imaging tool of choice is DSKIMAGE by M. Brutman. Very simple, but effective, and generates an untouched image, which is not always the case with WinImage (I have seen cases where WinImage writes its metadata to the first sector, though it may be possible to avoid that with some setting).
Reply 34073 of 40042, by bjwil1991
I use dskimage to backup my diskettes into images and in case they stop working one day, I can copy the image to a newly formatted diskette and be done with it. I wish I could copy my Lemmings IBM diskette, but it's copy protected (volume label is all jibberish).
Reply 34074 of 40042, by liqmat
TheMobRules wrote on 2020-05-20, 18:31:
I'm well aware and why I said write protect it. I just find WinImage very convenient and effective. Personal choice.
Reply 34075 of 40042, by bjwil1991
I agree. I use WinImage for archiving my diskettes and making new ones with drivers and stuff for controller cards, video, sound, etc.
Reply 34076 of 40042, by imi
thank you for your service :3
Reply 34077 of 40042, by xjas
Amazing find Cyclone3D! Glad you were able to snag it.
ddrescue on Linux can pull off some miracles reading "barely working" disks if all else fails. If you just run it with the defaults it does a good enough job, but it's incredibly powerful if you really dig in to the settings. You can, for example, have it log the results of previous attempts, so it knows where the "bad" bits are and you can try more advanced scraping methods on those sectors over multiple iterations. Another great tool to have in the drawer.
I've had FAR better experiences with "old" 3.5" disks (especially DS/DD ones) than newer ones made after the prices bottomed out. I think it's more to do with build quality than media density... Anything made after 1999 or so is hopeless trash. Hopefully those will still be OK.
Reply 34078 of 40042, by Deksor
@cyclone3d
My goodness !! Will you scan that book as well ?
For the disks, make sure you write protect them before you image the disks, sometimes windows loves to write stuff in disks it shouldn't write which makes the images less authentical (if someone else have these disks and want to make sure they're totally untouched, a hash of yours could come handy, but only if their content is totally untouched).
Before imaging the disks, open their window to make sure there's nothing funny going on inside. I've had disks that had circular marks and that killed floppy disk drives from times to times, these are really annoying 🙁
Hopefully they'll be fine !
alternative
Reply 34079 of 40042, by bjwil1991
I had bad luck with diskettes for I/O controller cards that needed write-protection off to make a temporary file or would throw data errors across the board. Good thing the internet and a lot of people that bought that particular card had drivers listed online. Good thing I backed up my NX Pro 16 drivers and utility diskettes prior to using them, but they were NIB with the card itself, which was nice.
