Reply 34480 of 52977, by boxpressed
On impulse, this NOS MAG monitor showed up on eBay, and I pulled the trigger. It's a low-end 15" MAG with a non-flat screen, but it came in the original box and foam, so I knew it would survive the journey to my house.
I'd decided to give up on CRTs except for my Sony PVM, but I couldn't pass up a brand new model.
1.34 MiB
Reply 34481 of 52977, by OMORES
Creative Labs Model Number ES1371 with ES1373 chip.
It works in Windows 3.11 with Watler's drivers, but I wait the original drivers files from Jo22: PCI Sound card for Windows 3.11 & Dos 6.22?
My best video so far.
Reply 34482 of 52977, by vutt
Talking about near fail ebay purchase.
I wanted to to add for my recently purchased SB CT3670 ram modules.
Well description was clear - single sided 30-pin SIMM. Note next to picture was little bit concerning - "Example Picture - Image similar", but seller was well known german shop elecromyne. What could possibly go wrong...
...and I received this:
104.54 KiB
So other side has pcb-like material covered with painted black metal plate. yikes!!
They just fit, but they are clearly under tension.
196.02 KiB
Then again - black matte color, very modern, only RGB is missing...
...also Made in Germany!!
Reply 34483 of 52977, by Cyrix200+
vutt wrote on 2020-06-11, 19:06:
Talking about near fail ebay purchase. […]
Well description was clear - single sided 30-pin SIMM. Note next to picture was little bit concerning - "Example Picture - Image similar", but seller was well known german shop elecromyne. What could go possibly wrong...
Well it's it's black matte color - very modern, only RGB is missing...
I have a few of those as well, I think is was an extremely low-budget brand called "Topless". Sometimes they are like these plates and sometimes more like blobs of black plastic.
I did a Google image search on "topless" for some examples but then I got distracted...
1982 to 2001
Reply 34484 of 52977, by darry
Miphee wrote on 2020-06-11, 17:40:
Munx wrote on 2020-06-11, 17:31:
Looks like it was hit with the same thing that hit the nearby capacitor C21 and knocked it out partially.
The capacitor is slightly damaged but it's okay. Unfortunately the memory chip is indeed cracked.
Something definitely "rammed" it .
Seriously, if you can't easily replace it, maybe you can disable the affected RAM bank .
Reply 34486 of 52977, by Miphee
darry wrote on 2020-06-11, 19:16:
I need practice with smd anyway so it's going to be a good opportunity. Good thing it's a generic S3 card and not something valuable.
Can these 514260 memories be replaced with 53C16258 from a different S3? They are pin/package compatible but timings are different.
Reply 34487 of 52977, by andrea
Miphee wrote on 2020-06-11, 19:54:
I don't pretend to be an expert at SMD soldering because I'm not, but I'll tell you how I did when I desoldered the memory for my S3 a few pages back. I turned up the iron some degrees hotter than normal. The display on the Yihua (you can tell the quality from the brand alone) said 350°, but it's out of calibration so I'd say about 320-330 actual degrees. I then put a big blob of solder that covered all the pins on one side of the chip, and then kept moving the iron back and forth to keep the entire blob molten while pushing this side of the chip up with a small screwdriver. No need to use force, once it's molten it'll tilt up very easily. Then remove the leftover solder with whatever method you prefer.
Finally repeat with a blob on the other side, except since one side is already free once the tin it's molten the chip will be free without having to pry it.
Disclaimer: this is not the proper way to do it, professionals™ or anyone who sort of know what they're doing would use hot air, but without it you kinda have to be creative.
Reply 34488 of 52977, by Miphee
andrea wrote on 2020-06-11, 21:15:
Thank you for the tip, I appreciate it.
I have no experience with SOJ packages so it will be a challenge.
Reply 34489 of 52977, by piatd
Looks like someone tried running the memory at ramming speed!
Reply 34490 of 52977, by mockingbird
vetz wrote on 2014-03-12, 22:39:
Some stuff I've picked up the last period of time. ASUS P/I-P55TP4XE. Socket 7 430FX w/ 512kb L2 PB COAST module & optional PS/2 […]
ASUS P/I-P55TP4XE. Socket 7 430FX w/ 512kb L2 PB COAST module & optional PS/2 bracket connector (not in picture) (1995). This was ASUS's highend board in 1995 and into 1996. Released in autumn 1995. Supports all up to the 200mhz Pentium (233 by 1.5x). The P55TP4 versions were:
-P55TP4 - Only async cache, no COAST module socket
-P55TP4XE - Sold with either 256/512 Async cache or 256/512kb COAST module (I got hold the best cache option). IR connector
-P55TP4XEG - Same as XE, just without IR
-P55TP4N - Released a bit later. 256kb PB cache hardwired to the board with COAST module for another 256kb.
Unfortunately the board was damaged in shipping and the DIN connector came loose, as the board only came in a thin padded envelope! I need to solder on a new one. Still powers on fine.
I thought I'd backup the BIOS for a P55TP4XEG I acquired recently and upload it here before upgrading as I don't see it available anywhere else. BIOS version is 1.15.
backup.zip
75.3 KiB
54 downloads
(Decommissioned:)
Reply 34491 of 52977, by seleryba
Bought a little pile of junk:
370.68 KiB
133.04 KiB
Most interesting things for me:
- Asus TX97 motherboard (Socket 7, i430TX, K6-2 ready) - need to replace the caps
- Sound Blaster Pro 2 CT1600
- AMD 486 DX4-100
Reply 34492 of 52977, by bearking
seleryba wrote on 2020-06-12, 13:42:
Most interesting things for me: - Asus TX97 motherboard (Socket 7, i430TX, K6-2 ready) - need to replace the caps - Sound Blaste […]
- AMD 486 DX4-100
Hey, that's a nice find...
Reply 34493 of 52977, by LewisRaz
Bought a little pile of junk: […]
- AMD 486 DX4-100
And what a nice pile of junk that is 😀
My retro pc youtube channel
Twitter
Reply 34495 of 52977, by Skanque
Finally this beauty and a surprise arrived from Italy.
Skywell Magic 3D Voodoo 1 PCI (1996)
Diamond Sonic Impact S90 Aureal Vortex1 PCI
I never get tired of the artwork on these old boxes.
Have a nice day
Reply 34497 of 52977, by Salient
Recently acquired these nice pieces of history for very reasonable prices.
A poor-mans MT-32 2nd generation (aka, the Roland RA-50 Realtime Arranger)
And a nice MT Multimedia monitor-stand speakersystem with subwoofer.
Reply 34498 of 52977, by Skanque
devius wrote on 2020-06-12, 16:05:
Nice! Now you'll finally be able to play interactive, texture mapped video games.
Yes, I can't wait for that sweet interactive game experience.
Reply 34499 of 52977, by bjwil1991
Yesterday, I bought a Pentium 4 system for $13. Case looks good, but the board has 2 caps that are blown and spewed its guts on top.
