Reply 34921 of 40040, by chrismeyer6
PC Hoarder Patrol wrote on 2020-07-01, 20:43:
chrismeyer6 wrote on 2020-07-01, 14:32:
Dual P3 850mhz 1 gig ram GeForce 2 ti SB Live! 5.1 9 9.5 gig Seagate 7200 rpm Scsi drives in raid 5 2x WD 120 gig ata 133 drives […]
PC Hoarder Patrol wrote on 2020-07-01, 04:46:
Do you have a spec of your system, Thx?
Dual P3 850mhz
1 gig ram
GeForce 2 ti
SB Live! 5.1
2x WD 120 gig ata 133 drives 1 has windows 2000 sp4 the 2nd has XP Pro sp3
Pci ata 133 controller card
Intel pro 1gig Ethernet card
2x DVD burners ide
Zip 100 drive
850 watt seasonic modular pay
Generic gamer window case from 2005 when I first built the system
4x aerocool DS 120mm fans
It's a awesome system and I love using it. Sadly I haven't used it in over a year and it's currently stored with our other stuff in my in-laws basement.
Once we finish our basement and I have my own area I'll have all my systems setup.
I'm pretty sure that's the full specs. Next time we're at my in-laws I'll double check the hardware.
A nicely balanced juggernaut 😀
It really is a nice system and I can not wait to bring it home and use it again. It's one of my all time favorite computers I've built.
Reply 34922 of 40040, by bearking
Bought this hightower AT case for about 30 euros.
181.99 KiB
It has a full 3 digit turbo display, and it is in a very good shape.
The seller said everything in it comes as a bonus!
1.52 MiB
So it has:
Gigabyte GA-586HX rev 1.56 mainboard
Pentium 100 MHz CPU + cooler
4 sticks of RAM, 48 Mb total
Some S3 Trio 1 Mb graphics card(with some issues)
Dawicontrol DC-974 PCI SCSI controller
2.1 Gb IBM SCSI HDD
some ALS100 Plus sound card
TEAC CD-56E 6x CD-ROM drive
FDD drive
Overall, I think it was a good deal. I'm happy for the case and also the mainboard...
Reply 34923 of 40040, by gdjacobs
wiretap wrote on 2020-06-01, 01:55:
Just won this Asus P2B-DS auction with a Make Offer deal for $119. (including RAM and CPU's) Now I can build my dually tually wi […]
Just won this Asus P2B-DS auction with a Make Offer deal for $119. (including RAM and CPU's) Now I can build my dually tually with two Upgradeware Slot-T slocket adapters. Going to load the beta BIOS, do the multiplier and voltage mods, then it should be good to go. I only have to modify one of my Upgradeware cards since it needs the 0 ohm resistor moved to enable SMP. Apparently my other is good to go from a previous owner since it is a rev 1.0 but already in the correct position.
I suggest trying NT 3.51. The amount of performance is hilarious.
Reply 34925 of 40040, by wiretap
gdjacobs wrote on 2020-07-01, 23:26:
I'll give it a try. I've used NT before (when I worked in a TV studio - the Globalstreams Trinity host used it), but I currently don't have any NT machines at home. It should be fun.
Circuit Board Repair Manuals
My Project List
Reply 34926 of 40040, by cyclone3d
I have 35 motherboards and 75 cards on the way from that same seller I bought all those cards from before.... YAY!
Yamaha YMF7x4 Guide
Epstein didn't kill himself
Reply 34927 of 40040, by Horun
cyclone3d wrote on 2020-07-02, 02:16:
Good luck ! BTW I donated a bunch of my bad boards to him, hope those are not included in the batch 😁
(You do know they get them from someone 🤣): just kidding...
Reply 34928 of 40040, by deleted_nk
Bought this dual Pentium 3 lot sold as not working 2 months ago, one motherboard contains a matched pair of 1.13ghz Tualatin CPUs, the rest had 1ghz Coppermines
Two of the boards work, one has blown caps and a dead CPU I need to replace on it. Though the coolers got slightly bent up in shipping on the dead board, I'm sure I can straighten them out. Two boards also had a full 512MB installed, which on these boards, require at least two DIMMS installed for a successful POST. either way, fun times on Win2K or XP ahead...
Reply 34929 of 40040, by cyclone3d
And you can add the ISA slot to them if you want. My dual PIII Tualatin board has PCI and ISA but no AGP.
Yamaha YMF7x4 Guide
Reply 34930 of 40040, by cyclone3d
Horun wrote on 2020-07-02, 02:21:
Heh.
Well, I think this is probably the last of it for now. From the sounds of it he was parting out a bunch of computers that he got from somewhere.
Yamaha YMF7x4 Guide
Reply 34931 of 40040, by luckybob
ninkeo wrote on 2020-07-02, 02:45:
Bought this dual Pentium 3 lot sold as not working 2 months ago, one motherboard contains a matched pair of 1.13ghz Tualatin CPU […]
3 dual boards in one post? Yes please!
Reply 34932 of 40040, by deleted_nk
cyclone3d wrote on 2020-07-02, 02:54:
It could very well work, but I'm not that sure all the components are there to drive the ISA slot signaling, since there's a few missing transistors in that area. Could be worth a try just for the lulz on the one needing repair, if you know what I mean.
luckybob wrote on 2020-07-02, 04:18:
https://media.giphy.com/media/3EV74tm43smVa/giphy.gif […]
Some people might have sworn these off because they're VIA Apollo Pro 133T based boards rather than the Intel based equivalents, but to be honest, the working two are stable as a rock even running Win9x on one, and Win2k on the other.
I might do a build thread with either the Coppermine or Tualatin board, however I'm running short of GPUs that aren't MX 440s or 9250s. Might need to invest in a few proper GF4 cards, or maybe even Radeon 9000 series cards.
Reply 34933 of 40040, by CMB75
ninkeo wrote on 2020-07-02, 05:24:
I just did exactly that and it works perfectly with my AWE64 Gold.
Re: What retro activity did you get up to today?
Just drop me a note if you need any close up pictures of the supporting SMD components.
Reply 34934 of 40040, by CMB75
Just bought an “ASI Aquarius Intel 286-12Mhz PC” from the bay for roundabout 70 Euro, shipping included.
Needs some rework & retro brighting love but it seems to be in a decent condition already.
145.73 KiB
My first ever 286 😀
322.35 KiB
Back in the day I worked with 8088, 186, 386, 486, …
Reply 34935 of 40040, by imi
CMB75 wrote on 2020-07-02, 06:53:
My first ever 286 😀
I'm sorry for making you pay more :x
Reply 34936 of 40040, by CMB75
imi wrote on 2020-07-02, 07:25:
My first ever 286 😀
Sorry, I snatched it 😉 ...
Reply 34938 of 40040, by 386SX
Those looks great. I'd like to test some light linux like Lubuntu lxde i686 on those board to see how they would still be capable to run it. I think with a PCI SATA to SSD disk they'd still be good modern home computer. 😁
Reply 34939 of 40040, by CMB75
386SX wrote on 2020-07-02, 10:24:
I'm running period correct SuSE Linux 7.3 Professional on this kind of board without problems and with good performance - it supports gfxboot for a nice setup with 4 OS on one SSD (lilo-rewriting).
file.php?id=82776
