Reply 35200 of 40040, by yawetaG
Salient wrote on 2020-07-21, 18:35:
Finally, after 3.5 months 'in transit' from Italy.... my Korg AG-10 module arrived!
If you have an old-school Mac (or a PowerPC G4/G5-based machine that can run Mac OS X in Classic mode), keep an eye on this thread:
Classic Mac MIDI application in Mac OS X Classic and MIDI interface use?
...because I will be posting screenshots from the official Korg AG editor (and hopefully the editor itself too) in the future.
Reply 35201 of 40040, by wiretap
Seller said it powered on and started up for a minute, then downpowered and wouldn't turn back on. I'll take on the challenge. Hopefully it is just the power supply.
Circuit Board Repair Manuals
My Project List
Reply 35202 of 40040, by pan069
appiah4 wrote on 2020-07-21, 11:17:
Well, I've cleaned the board (and the socket) as best I could. There were also some bent legs on the northbridge that I straigh […]
Well, I've cleaned the board (and the socket) as best I could. There were also some bent legs on the northbridge that I straightened.
Disassembling the socket didn't work too well, I managed to remove the lever but removing the top part was not possible. There are some socket/tabs that hold it down and the socket plastic is too brittle to actually flex enough to remove the top without cracking it, so I gave up. The hole around the scorched plastic is wide, I'm pretty sure this is due to an overheating pin that scorched the socket plastic and 90% confident the socket pin should work fine. I will give it a try tonight and see how that works out.
I have the same board, newer revision though. I was lucky, I found it new in box a little over a year ago. I'm using it in my 486DX4-100 build. It didn't came with a PS/2 mouse bracket though but I got one of those generic Startech PS/2 mouse headers, I just need to change the motherboard connector on it.
1.32 MiB
Reply 35203 of 40040, by bjwil1991
wiretap wrote on 2020-07-21, 20:30:
Seller said it powered on and started up for a minute, then downpowered and wouldn't turn back on. I'll take on the challenge. H […]
Or the Varta Ni-Leakium battery. Those are notorious.
Reply 35204 of 40040, by bearking
I traded today a few of my spare CPUs for these, also paid like 22 euros extra. Made the deal with a local scrapper, really nice guy. I hope he will become my "gold mine" of old stuff...
831.32 KiB
Unfortunately, the K6-2+ 550ACZ is not working, tested it on an ASUS P5A rev 1.04 with the latest beta BIOS 🙁
The P60 is an SX835, it should have the FDIV bug...
Reply 35205 of 40040, by bjwil1991
The CPU has the FDIV bug
Ironically, the Pentium OverDrives for the 486 machines had no bugs and the 386 CPUs all have the POPAD bugs, even the double-sigma ΣΣ CPUs.
Reply 35206 of 40040, by wiretap
bjwil1991 wrote on 2020-07-21, 21:33:
True, hopefully not. If that's the case, I'll just have JLCPCB print a new motherboard.
My Project List
Reply 35207 of 40040, by bjwil1991
If it's the PSU, you're in luck. And if the battery was removed long ago, double luck.
Reply 35208 of 40040, by CrFr
waterbeesje wrote on 2020-07-20, 16:59:
Nice catch! I don't think you overpaid... It's not a bargain either. Just anok price. These machines are generally quite popular […]
CrFr wrote on 2020-07-20, 14:40:
Bought this Compaq Prolinea 4/50S for 66€ including shipping. I don't know if I overpaid, but I have wanted a 486 or 386 desktop system with ISA slots for some time. It has integrated Tseng ET4000/W32i graphics, which I suppose is decent for DOS games. Hard drive is missing, hard drive mounting plate is missing, floppy drive doesn't work, but otherwise it seems to be ok. It is dirty, but after good cleaning, I'm sure it will look very nice 😀
Nice catch! I don't think you overpaid... It's not a bargain either. Just anok price. These machines are generally quite popular.
Floppy drive may just be dirt as well I guess. Clean it and you're probably all set.
For a hard drive a CF card would do perfectly, cost close to nothing and is reliable.
And do yourself a favour: see if you can set the base clock from 25 to 33MHz... The CPU will most probably just be a dx2-66 which is purposely clocked down by intel to fill a market gap 😀
Thanks for the tips!
I tried cleaning and lubricating the floppy drive with no results. When I grew a bit annoyed with this drive, I noticed that it reads floppies just fine if you slam them in angrily 😁 This needs more investigating.
Indeed the CPU overclocked nicely to 66MHz. The case had even nice diagram of jumper locations to make it easy. Runs at higher speed without problems. It is 486SX2-50 processor.
Hard drive on the other hand wasn't as smooth sailing. This machine seems to be very picky on what it accepts. First I tried 8GB CF card, but it didn't work. Always gave hard drive error on boot. Same result with several "modern" 60-120GB drives. Also 128GB SATA SSD with SATA-PATA adapter didn't work. Only drives that work were 1.6GB and 2.6GB ones I had. Both of them sound awful, so it won't be permanent solution. I ordered couple of different 1GB CF cards hoping I might have better luck with those.
Reply 35209 of 40040, by Cyrix200+
I spotted this ELV PCT-7000 PC-card-tester on my local auction site. Not sure how useful it is for me, and I need to find the documentation (still seems to be available from ELV)... Still a cool thing to have and I did not pay too much.
https://at.elv.com/pc-karten-tester-pct-7000-teil-12-203295
Self-developed, newly built or defective PC plug-in cards should be subjected to an independent test in order not to endanger the computer. The PC card tester developed by ELV is used for this purpose. It works without an external computer and can be used to carry out essential functional tests on PC plug-in cards.
1.75 MiB
1982 to 2001
Reply 35211 of 40040, by BloodyCactus
I'm 100% guaranteeing you its battery corrosion has eaten the board away in a large swathe. those old PSU are fairly rock solid.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 35212 of 40040, by wiretap
BloodyCactus wrote on 2020-07-22, 15:49:
Thank you for your opinion. We'll see when it arrives.
My Project List
Reply 35213 of 40040, by Miphee
I can't have a decent retro computer without a bunch of colored 5.25 disks next to it!
    577.78 KiB
Reply 35214 of 40040, by creepingnet
Because I'm a masochist, and I wanted a 486DX4 laptop with a sound card, and like challenges like building up hinge mounts out of thick gumps of SteelStik and J.B. Weld original, and taking my chances on 1990's era touch screens......I bought this NEC Versa M75.....and I have no idea what the heck that "Commpac Words+" System 2000 thing is, but it looks like a piece of medical equipment involving sound.....hey, maybe I'll find a musical purpose for it...who knows. Quite excited to see what I can do with this one after all the greatness my Versa 40EC has risen to. Heck, maybe I can LAN Game with the wife over wifi with this. I've got a WaveLan Silver that's sitting around doing nothing right now.
    24.18 KiB
    NEC Versa M75 wiith Commpac Words+ from E-bay
~The Creeping Network~
My Website - https://sites.google.com/site/thecreepingnetwork/home - ending 9/2021
NEW WEBSITE - 9/2021 https://creepingnet.neocities.org/
Reply 35215 of 40040, by yawetaG
creepingnet wrote on 2020-07-23, 03:06:
Apparently a system for augmentative communication (read: extra-loud voice-over). Later version PDF:
http://www.aactechconnect.com/products/pdf/106.pdf
Great for use at protests/people who won't keep their distances/parties* 😉
* circle your current fancy.
Reply 35216 of 40040, by Turbo ->
LewisRaz wrote on 2020-07-19, 11:29:
Won this motherboard on ebay the other day although I am having trouble finding its ID.
Your board looks similar to mine. Check Jumper settings for 486 motherbaord thread.
Reply 35217 of 40040, by LewisRaz
Turbo -> wrote on 2020-07-23, 08:02:
Thanks for that 😀
My retro pc youtube channel
Reply 35218 of 40040, by appleg33k85
Picked up these two beauties at a flea market. The Zenith is a ZDH-1217-DE that is really clean, looks like its hardly been used but can't really test much since I don't have a monitor compatible with it 🙁 Also can't find much information on it, see others that are -A0 but not really anything on what the -DE is.
Other one is an IBM clone that came with a 386 board, most everything inside is in really good shape except for the battery leaking and making general chaos.
Got everything including 2 keyboards for $140 so felt pretty good about that.
399.74 KiB
GPL-2.0-or-later
Reply 35219 of 40040, by Carlos S. M.
bjwil1991 wrote on 2020-07-21, 22:40:
Pentium overdrive were based in a later Pentium core (P54C iirc)
