Reply 36080 of 52813, by SpectriaForce
- Oldbie
Moarr S462 goodness
NOS PC CHIPS M811
(that disclaimer at the bottom 🤣)
NOS MSI KT4 Ultra
NOS Asus A7N266-C
All these S462 will be recapped as far as needed (already made a inventory).
Moarr S462 goodness
NOS PC CHIPS M811
NOS MSI KT4 Ultra
NOS Asus A7N266-C
NOS Asus MEW (socket 370 PPGA only + PCI only)
Quality board from 1999 with Japanese capacitors.
I'm not sure yet whether I'm going to pair this with a PCI FX5500, MX4000 or even a Voodoo2.
NOS PATA HDD and CPU
Nice mobo's ! All I found this weekend was some 1.44Mb floppy disks. Box of 50 for $6.50 (was half off yellow tag price). Odd thing is the side label says 1995 and 7/95-S/H, wonder if they are that old or TDK just kept using same box style for a long time....
Anyway, you can not have too much media for vintage gear 😀
As mentioned in another thread, I ordered a NOS OEM AWE64 Value (CT4520) to test whether the craptastic line-out noise performance on mine is typical or if I have an outlier .
My CT4520 unit has low volume pulsing noise (probably below -60dB, I did not measure) on line-out which my CT4520 CT4500 does not .
EDIT: Edited for clarity and to correct typos . My original post made no sense .
darry wrote on 2020-09-21, 00:26:As mentioned in another thread, I ordered a NOS OEM AWE64 Value (CT4520) to test whether the craptastic line-out noise performance on mine is typical or if I have an outlier .
My unit has low volume pulsing noise (probably below -60dB, I did not measure) on line-out which my CT4520 does not .
Which card is "My unit" ? Hope new one works ok. Have read there are some variants of the ct4520, some were worse than the earlier 4380 that it replaced.
Horun wrote on 2020-09-20, 00:56:EvieSigma wrote on 2020-09-20, 00:28:You certainly don't find 2400bps Hayes modems at Goodwill very often. Of course the annoying 9VAC power supply is missing, thoug […]
You certainly don't find 2400bps Hayes modems at Goodwill very often. Of course the annoying 9VAC power supply is missing, though.
Nice ! Yes Goodwill is bad at not keeping the AC adapter with the unit intended (so they can get a few extra $ selling it separate). Did you look over the shelves to see if it was in with cables and stuff ?
I keep my eye out for any external serial modem, have yet to find a decent 2400 but have found a few 28.8 and 33.6
I actually found this in the "Outlet Center" part of the store (along with a pair of Creative branded PC speakers I also grabbed) and while I found what might have been a 25-pin serial cable to go with it (that I didn't buy because I didn't know if it was serial or parallel) I could not find a power supply even after an extensive search.
Horun wrote on 2020-09-20, 23:25:Nice mobo's ! All I found this weekend was some 1.44Mb floppy disks. Box of 50 for $6.50 (was half off yellow tag price). Odd thing is the side label says 1995 and 7/95-S/H, wonder if they are that old or TDK just kept using same box style for a long time....
I remember buying TDK disks in that exact style of box in late 96.
Horun wrote on 2020-09-21, 01:56:darry wrote on 2020-09-21, 00:26:As mentioned in another thread, I ordered a NOS OEM AWE64 Value (CT4520) to test whether the craptastic line-out noise performance on mine is typical or if I have an outlier .
Sorry about that.
I just re-read and corrected my post .
Basically, the CT4520 line-out is crappy. The Ct4500 line-out is much better . The CT4500 has crappy line-in . The CT4520 line-in is better .
I also ran some line-in tests on another CT4520 that I have in another machine . See Noisy AWE64 recording from any input (line in, EMU8000 MIDI, etc) + upcoming AWE64 comparison
mpe wrote on 2020-09-19, 11:33:Also arrived today. Micronics-branded dual socket 5 / 430NX. IBM part made by Micronics in full-AT form factor. […]
I notice the board has two Intel Overdrives. Didn't Intel disable SMP in their overdrives? Or was that just the MMX overdrives?
feipoa wrote on 2020-09-21, 07:12:mpe wrote on 2020-09-19, 11:33:Also arrived today. Micronics-branded dual socket 5 / 430NX. IBM part made by Micronics in full-AT form factor. […]
This is what I am trying to find out 😀 It came with two P90's which is what it was designed for. Those I installed are Socket 5 overdrives which should be close to stock CPUs.
MMX Overdrives don't support SMP. Non-MMX might as there are hints in datasheets saying so.
I've got this nice kit today for a good price(23 euro incl. shipping)
Soyo 019R1 mobo with 128 kb cache + Cyrix Cx486DLC-40GP + Cyrix Cx87DLC-40QP + 4 Mb SIMM 30 RAM.
And also this 8-bit multi-i/o card
Unfortunately, the board is playing dead with me; all the chips are getting warm but still no beep, no video and also nothing on the POST card... only the LED-s are light up.
PS: I've already removed the varta...
Couldn't wait for Jensen to hurry up baking the next batch of 3000 series cards..
4000 series courtesy of PNY
Ye already be disturbed; now leave me be. Yer company be toil enough as is.
Back to the GW to check for more media and got 150 DVD blanks for $10. They have a shelf full of unopened various brands DVD+R and some DVD-R for $3 or $4 for 50 packs or $7 or $9 for 100 packs.
The little 25 packs were also $3.... Any body need some DVD media for cheap ? These are what I left on the shelf......
mpe wrote on 2020-09-21, 07:20:feipoa wrote on 2020-09-21, 07:12:mpe wrote on 2020-09-19, 11:33:Also arrived today. Micronics-branded dual socket 5 / 430NX. IBM part made by Micronics in full-AT form factor. […]
This is what I am trying to find out :) It came with two P90's which is what it was designed for. Those I installed are Socket 5 overdrives which should be close to stock CPUs.
It's a real shame about Intel removing SMP for the MMX overdrives. Please keep me informed about the non-MMX overdrives.
bearking wrote on 2020-09-21, 22:25:I've got this nice kit today for a good price(23 euro incl. shipping)
Looks great! I love that gold Cyrix printing on the chip. +15 ns cache +Cyrix FPU +Barrel removal and you're already golden. Make a new thread!
Artex wrote on 2020-09-22, 00:55:bearking wrote on 2020-09-21, 22:25:I've got this nice kit today for a good price(23 euro incl. shipping)
Sweet ! That is a great bargain for everything.
Horun wrote on 2020-09-21, 23:37:Back to the GW to check for more media and got 150 DVD blanks for $10. They have a shelf full of unopened various brands DVD+R and some DVD-R for $3 or $4 for 50 packs or $7 or $9 for 100 packs.
I don't need them, but the Fuji +R's might (or might not) be Taiyo Yuden.
I just ordered a Roland VS-880EX from Japan to replace my Akai DPS12, which I have been using as a mixer . The reason for this is the "issue" discovered and described in this thread : Noisy AWE64 recording from any input (line in, EMU8000 MIDI, etc) + upcoming AWE64 comparison
The VS-880EX is not perfect and it definitely is not new, but
a) it has an uncompressed mode, but that is limited to 6 tracks, which is enough for me
b) it has 6 analogue balanced inputs
c) it has S/PDIF output
d) its hard drive is 2.5MM, IDE and can be replaced by a CF card or likely an IDE to SATA converter
e) it has a universal PSU
f) it is relatively inexpensive
Wish anal retentive perfectionist me luck. Hopefully the VS-880EX will not be worse than my DPS12 😉
EDIT: I would have just bought a modern mixer, but finding one that has S/PDIF output (USB is what they all have) and does not cost multiple arms and legs is practically impossible .
Today I received a couple of curious vintage hardware, the first was a bit of a gamble. From the layout it looks like a graphics adaptor, but the DA-15 connector does not corroborate. With little info on the silkscreen and labels I became intrigued by this little 8 bit isa card. Puled the trigger on it, and now I have a more clear picture, the 28 in ic (U1) is a 6264 static ram. The logo on the main ic and pcb, is from a company called "Video Associates Labs". I now think that this thing is MDA for a CNC machine, probably reusable on a xt class pc.
The second piece of vintage hardware is an IBM classic, the iconic IBM PS/1 model 2011 ( @ least for me ) :
The special thing about this machine is a rare PS/1 sound card, besides being a cute little box :
@ last but not the least, a book about the ISA interface, this is a good reference book from 1995, so a bit late for the lifespan of the ISA "standard", and that makes it a very thorough book:
