Reply 36480 of 52812, by TheMobRules
Aublak wrote on 2020-10-14, 01:47:
As for the 4MHL3S motherboard, I dunno. It just doesn't start. I thought I got the jumpers right. I know the ISA video card works. Tried a bunch of different EDO ram. I just don't know.
EDO won't work there, or in most 486 boards for that matter. Only some of the later boards (usually PCI) support it, and very few (or none) can actually take advantage from it. In most cases you need FPM memory modules.
Reply 36481 of 52812, by Skanque
DaveJustDave wrote on 2020-10-14, 17:38:
not a bad way to spend $200 USD. interesting how the seller marked "for parts/not working"..
Skanque wrote on 2020-10-14, 13:22:
Finally after crossing the atlantic and being held hostage by customs this box arrived:
ATI Rage Fury MAXX 64MB AGP
Well I guess the seller did that to protect himself against unfounded claims, I don't blame him. But the card is like new, the software is not even open.
And I don't see what price has to do with anything.
Have a nice day
Reply 36482 of 52812, by luckybob
I list EVERYTHING as "or parts/not working". It's the only way a non-business seller can sell anything on epay without taking a 10" marital aid up the rear. And I happen to LIKE that sort of thing!
Reply 36483 of 52812, by vetz
luckybob wrote on 2020-10-14, 18:20:
Yup, only way for a seller to protect himself against scams on Ebay. I've never had a case of the item wasn't working, even though it was advertised as such (excluding obvious cases where the item is sold for parts and it has visible damage).
Reply 36484 of 52812, by Hanamichi
ATI Rage Fury MAXX 64MB AGP […]
Great box art and nice find!
(Watch out for the Bogey luckybob on your six 🤣)
ATI know how to do nice boxes , you need the Rage Pro? racing car box now.
I said no more motherboards to myself.. damn it couldn't resist:
203.81 KiB
(Sellers photos, there were other goodies too, maybe an Athlon Slot A 1000)
Reply 36487 of 52812, by luckybob
Hanamichi wrote on 2020-10-14, 20:06:
...Great box art and nice find!
I have a couple rage fury maxx cards, and I don't seek out boxed parts either.
I guess everyone is safe?
Reply 36488 of 52812, by Hanamichi
luckybob wrote on 2020-10-14, 21:42:
Ah I was referring to your marital aid comment but you lucky duck on the cards!
Reply 36489 of 52812, by darry
After discovering that my OSSC third-party unit is not that great at above 1024x768 input (ghosting and noise), I ordered an official one from https://videogameperfection.com .
Damn you COVID-19 for making me buy a third-party unit (fast local shipping) rather than an official or Kaico built one !
Reply 36490 of 52812, by cyclone3d
My Glitchworks Dallas battery replacement came today:
378.28 KiB
Installed:
198.68 KiB
Also ordered these because I saw them in another thread... never even knew they existed:
453.3 KiB
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 36491 of 52812, by Skanque
Great box art and nice find! […]
Thanks for the warning, but seems that bob is content atm. so the six is clear, for now.
I am not at all jealous of all those ASUS parts, especially the P5A in box 😳
Awesome finds!
Reply 36493 of 52812, by cde
darry wrote on 2020-10-15, 00:02:
Interesting! My unit could have the same issue. Were you able to characterize the problem (e.g with a test pattern)?
Reply 36494 of 52812, by Xicor
Today I received a boxed and sealed DX4ODPR100 from EvilBay, the seller had 9 of this beauties, snatched the last one @ the nick of time....
1.28 MiB
Also today arrived in the mail an original copy of Duke Nukem 3D, just to avoid using too much the boxed version.
1.24 MiB
In the local market and ads, found a nice psu from OCZ and a case from Fractal to make it's home.
1.21 MiB
The cool thing about this psu is that almost every cap is from reputable brands, like Nippon Chemi and Rubycon, the exception is the main smoothing cap, being a lesser one from Teapo.
855.99 KiB
1.63 MiB
Reply 36495 of 52812, by darry
cde wrote on 2020-10-15, 10:37:
I did not use any test patterns yet. The ghosting and noise are almost invisible on my monitor. It is only when I tested the OSSC's output on a Datapath E1S, whith real-time zooming on preview video, that I noticed it and was able to also confirm its presence on my usual monitor . No issues are visible when the Voodoo 3 is directly connected to the monitor .
I could have tested direct VGA capture on the E1S, but the VGA cables I have are too short.
That said, if you are not going to be capturing video at above 1024×768 through the OSSC, this is practically a non issue on a 25" monitor like mine, IMHO . I am, however, too much of a perfectionist to let it slide .
EDIT:
See Re: VGA Capture Thread for some samples .
Reply 36499 of 52812, by SVD
Tetrium wrote on 2020-10-14, 13:25:
Those Fujitsu Siemens boards were always a favorite of mine. Usually using standard PSU connectors and are capable of using a FS […]
SVD wrote on 2020-10-13, 18:38:
I got this Siemens w26361 w10 with a pentium iii 700/256/100 for about nothing along with a ton of other stuff.
Anyone know something about it? It's an OEM so is it worth having? I guess it can't do 133 fsb since it came with that processor.
Chipset is FW82443BX
SVD wrote on 2020-10-14, 07:33:
PC Hoarder Patrol wrote on 2020-10-13, 23:56:
Actual model is D1107-A (with LAN), and a couple of slightly differing versions of the manual
A26361-D1107-Z180-US.pdf
A26361-D1107-Z120-US.pdf
Thanks a lot 😁
The board is only 66/100mhz fsb and it looks like its autodetects it.
Those Fujitsu Siemens boards were always a favorite of mine. Usually using standard PSU connectors and are capable of using a FS royalty OEM version of Windows XP (though not certain this will work on your particular board) which would be pre-activated when installed on a compatible FS board, so these never needed to be activated.
The FS version of Windows XP was barely bloated if at all.
These boards typically have few options in the BIOS, but I see them as higher quality boards. Their systems were typically paired with an FSP PSU and not some El Cheapo featherweight, so these boards would usually not be subjected to unstable powerrails.
Not much good for overclocking though, but I loved them as these would just work and I prefer stability over overclocking any day 😁
Definitely a keeper in my book (provided it is functioning properly of course).
Thanks, will keep it, or sell it to fund my other projects😅 I want that 133fsb. Thinking the Soyo SY-6VBA133 might be the one 😊
Got some more stuff also ^^ About 2kg of ram, 30 pin, 72pin, SDR and 2 coast modules (for ~50usd). Also a beast of a Nokia 445Xi. Its feels like a ton hauling it up the stairs😂 Unfortunately it got a scratch, im wondering if i will remove the antiglare or not. I think it will stay on for now at least.
