Reply 36500 of 52808, by Intel486dx33
I threw away my computer certification books back in early 2005 so I have to buy new ones.
Reply 36501 of 52808, by debs3759
Intel486dx33 wrote on 2020-10-15, 19:18:
I have the MS-DOS 6.2 version of the first book. Looks good sat between The MS-DOS Bible and the DOS Programmer's Reference on my bookshelf. Haven't read and of them in years, but might have to again now I'm getting set up for rebuilding several retro systems.
Reply 36502 of 52808, by waterbeesje
The mailman brought me these today:
1. Cirrus logic GD5424 with 1MB 80ns onboard. Upgradable to 2MB for higher resolutiond or more colours.
2. Cirrus logic GD5428 with 1MB 45ns onboard. Upgradable to 2MB for higher resolutiond or more colours.
Makes me wonder: the 5428 should be quite a bit faster than the 5424 if it can manage to utilize the faster memory. Would the speed difference be that great?
#2 will probably end up in my CX5x86-100 system. It now runs another 5424 with no possibility to upgrade to 2MB.
Stuck at 10MHz...
Reply 36503 of 52808, by mpe
waterbeesje wrote on 2020-10-15, 20:37:
The mailman brought me these today: 1. Cirrus logic GD5424 with 1MB 80ns onboard. Upgradable to 2MB for higher resolutiond or mo […]
You get neither more useful resolution modes nor more colours with 2MB upgrade (except for pointless 1280x1024/16 colours and 1024x768/64k interlaced modes on the GD5428).
The 5424 cannot be upgraded to 2MB. The sockets you see are there likely for alternative memory configuration options (so that they could fit either 256K×4 or 512Kx16 DRAMs whatever was cheaper at the time of assembly ). The 5428 is slightly faster in Windows in 256 colour modes (due to basic BitBlt acceleration), but they are both low-end cards.
Also both chips have maximum memory clock of 50 MHz so there is no benefit of faster memory. Even 70ns is fine for the maximum clock of GD5428. The card with 80ns will be likely running at 45 MHz.
Blog|NexGen 586|S4
Reply 36504 of 52808, by kolderman
Did I need another midi module? Hell no.
Did I want another midi module? Not really.
Did I go ahead and buy it anyway? You bet I did!
The price was OK so there.
Edit: tested it and it sounds great so happy anyway.
Reply 36505 of 52808, by Warlord
I found these amazing speakers at a goodwill type place. I couldn't believe how good they sound. They have a lot of BASS and they were marketed a MEGA BASS
Theyre also very heavy for how small they are.
Not my box but i cant be bothered to upload pics
Sony SRS-Z750
Sigma-type magnetic circuit reproduces powerful bass sound
Built in 15w Amplifier
Magnetically shielded design
Sony Mega Bass bass boost circuitry
    7.97 KiB
    20.52 KiB
Reply 36507 of 52808, by EvieSigma
Grabbed what I thought was a complete in box Creative Ensoniq AudioPCI card...but it was actually a SoundBlaster Vibra 16XV model CT4170 ISA sound card. And it came with the documentation and drivers for the Vibra card too! Not bad!
Reply 36508 of 52808, by Horun
Wow good find ! I also just bought a couple of old books last week to replace some I had also donated away years ago. One is Peter Nortons PC Problem Solver second edition 1992 (covers thru DOS 5).
Reply 36509 of 52808, by kdr
EvieSigma wrote on 2020-10-16, 22:47:
I recently got two of the Vibra 16XV cards (they were installed in a pair of old Socket 7 machines that I bought). No issues at all using them for DOS games because the PNP BIOS had set them up with 'reasonable' IRQ and DMA choices.
There's no hardware wavetable synth (has to be emulated in software), and the hardware FM synth is Creative's CQM clone of the OPL3. I'd never heard it before, but ugh it's rough when playing back Adlib Tracker tunes, lots of weird noises and glitches in the higher frequencies.
Anyway it's a reasonable card for playing late-era DOS games, which only use the sound card for 16-bit sampled audio.
Reply 36510 of 52808, by imi
Having at least one Mac in the collection can't hurt right?
...especially if that means getting a 21" Trinitron CRT with it :3c
what a massive hunk of 35kg, it's heavier than my 22" Mitsubishi by quite a bit.
241.2 KiB
Reply 36511 of 52808, by Khorne
Quite happy with this PCI version of M400 64MB, snagged it locally for around 5 euro's while buying a serial mouse, it was advertised as AGP 😀
Unfortunately my current board seems to refuse to work with it (probably needs 2.2 PCI) so it will have to wait for something stronger than my socket 7 200MMX, but tbh it would be a gross overkill to leave it in there anyway.
    604.97 KiB
Reply 36512 of 52808, by kolderman
imi wrote on 2020-10-17, 14:41:
Having at least one Mac in the collection can't hurt right? […]
They made 21" trinitron versions of the translucent colored mac range? That's so cool.
Reply 36513 of 52808, by Skanque
Khorne wrote on 2020-10-17, 18:42:
Never thought I would hear Khorne talking about "gross overkill".. I thought it was blood for the blood god?
Reply 36516 of 52808, by imi
kolderman wrote on 2020-10-17, 18:50:
sure seems like they did ^^
unfortunately there's not much to see inside like in the later flat CRT models, because the whole tube and electronics are covered in a metal shell inside. still looks very neat... very hard to carry though ^^
Reply 36517 of 52808, by PTherapist
I used to have one of those monitors too, got 1 from eBay 2nd hand in the mid 2000s. It was a fantastic monitor with a great picture and yes it weighed a tonne!
Some might cry sacrilegious here, but even though I did own several Macs we actually used the monitor primarily on the main family PC running Windows. 🤣
Don't have it anymore though, after about a year and a half of heavy use it died. Screen shrank 1 day and then switched off. Might have been fixable, but unfortunately due to lack of space it was disposed of.
Reply 36518 of 52808, by Vynix
Ha these, the 17" had a on-screen menu, for this one the 21" it required you to plug it into a compatible Mac (see how the VGA cord has a USB cable coming out of it?).
There also exists a graphite grey version of this one, though it's a bit tougher to find than the blue one
Reply 36519 of 52808, by PcBytes
Scored some free gems:
- Office 97 Small Business Edition (DE)
- Windows 95C (DE)
- AOL Diamond (DE)
- EPSON Creative Design Pack (Multilanguage, but the sticker on it is in Deutsch)
- Corel Draw 7 OEM (Multi)
- Aztech SC16-3D + ATI Rage Pro Turbo Driver CDs (EN)
- CD-R w/ bunch of pictures from the previous owner
- Acer 56K Modem Driver CD
