Reply 36620 of 52812, by kdr
Munx wrote on 2020-10-25, 18:10:
I thought I got myself an 8bit ISA serial card for 1Euro. But then I realized that its a female connector. Too few pins for VGA.
Did I buy a CGA/Monochrome video card?
Can I use it on a VGA monitor with a passive adapter?
What is the text on the main chip? I can't quite make it out from the photo... is it EICIO or BIGIO or something else?
It probably isn't an MDA, because it lacks the 16.000Mhz or 16.257Mhz oscillator. But you can confirm whether it's an MDA by trying to write a value to the CRTC cursor address register:
C:\>DEBUG
-I3BA
F0
-O3B4 0E
-O3B5 55
-I3B5
55
-O3B5 AA
-I3B5
AA
If you don't see "55" and "AA", it's not an MDA.
Reply 36621 of 52812, by furan
Aublak wrote on 2020-10-23, 11:47:
That simple, huh.
CT1350B can also be upgraded to support CMS using some Philips chips. It's super cheap and you can still get those chips on the web/ebay.
Some info:
http://nerdlypleasures.blogspot.com/2013/06/t … ms-upgrade.html
Reply 36622 of 52812, by Aublak
furan wrote on 2020-10-25, 20:48:
CT1350B can also be upgraded to support CMS using some Philips chips. It's super cheap and you can still get those chips on the […]
That simple, huh.
Some info:
Yeah. I watched PCL's review on it. Still, that link you posted has more detailed info. I was intending to upgrade it eventually.
With that said, I don't even know if the card works. I'm still waiting on my Yamaha chip to arrive.
Reply 36623 of 52812, by HanJammer
HanJammer wrote on 2020-10-23, 07:50:
Aublak wrote on 2020-10-22, 23:26:
I spurged today. I bought this all for $60.
I haven't identified some of it yet. I'm kinda curious about this weird Creative video card. And I found an extremely early Creative card. Game Blaster? If I'm not mistaken.
CT7230 is just MPEG2 decoder (PC-DVD Encore).
CT1350B - that's Sound Blaster 2.0 - you just need OPL2 chip (you can still buy them on eBay) and you are good to go (as long as the card works).
That simple, huh.
Thanks.
Yeah. Simple and cheap.
https://www.ebay.com/sch/i.html?_from=R40&_tr … ym3812&_sacat=0
Also card will probably work without OPL2 (in which case no FM music for you, just the PCM sound).
Reply 36624 of 52812, by Almoststew1990
Not sure if this is universally accepted as retro but I picked up a GTX 295 today for £25
Looking forward to putting it with my i7 860 also from 2009!
Reply 36626 of 52812, by Almoststew1990
No I've been sizing up my power supplies. I think my best PSU should handle it. VGA1 and VGA2 12v has 30a each and it's a 650watt PSU. The reviews state a need for 50a and a total PC power draw of 450 or so (with an overclocked 1366 i7)
Reply 36627 of 52812, by slimblin
Hi!
Just bought this old guy (case with speakers):
    1.07 MiB
    612.57 KiB
Reply 36628 of 52812, by Predator99
XT-Board with some expansion cards from a scrap lot. Board looks like new but DIN connector is broken. The cards seem to belong to the system. Didnt identify the card with the battery yet. Seems to be a Floppy / PAR /SER / GAME card with RTC?
1.37 MiB
1.22 MiB
Reply 36632 of 52812, by Artex
slimblin wrote on 2020-10-26, 16:44:
Hi!
WOW - AWESOME. I love it!
Reply 36633 of 52812, by HanJammer
Predator99 wrote on 2020-10-26, 17:31:
Yeah, exactly - multi I/O with RTC. Graphics card is CGA (very nice to have for debugging older hardware as it has composite out and works fine with Landmark Diagnostics) and the little card - MFM controller.
Reply 36634 of 52812, by HanJammer
slimblin wrote on 2020-10-26, 20:16:
One more ugly-beautiful pc for cleaning.
I have one like this as well - it has dual-coloured MHz display (green + red).
And make sure to post the speaker case here: Re: The AT cases with built-in stereo speakers thread! (along with the pics of it inside!)
Both excellent finds anyway!
Reply 36635 of 52812, by furan
I like the inverted tower designs (having the drives on the bottom instead of the top). We didn't get many of those in generic AT/ATX here in the states. I think maybe Compaq or Digital made a machine or two like that, but they are a rarity. Very nice! I wouldn't call it ugly.
Reply 36636 of 52812, by Robin4
HanJammer wrote on 2020-10-27, 00:05:
Iam guessing that longer ISA card is having dual floppy connectors.
Reply 36637 of 52812, by HanJammer
Robin4 wrote on 2020-10-27, 03:04:
Yeah, seems so, but some of the logic chips are not populated so it may not work with 4 FDDs is not populated (also second UART socket is not populated as well)
Reply 36638 of 52812, by Predator99
HanJammer wrote on 2020-10-27, 08:03:
Yes, thats possible. This will also require some BIOS support. There are 2 ROMs on the Mainboard, maybe one is for this purpose? Will check this...
Reply 36639 of 52812, by HanJammer
Predator99 wrote on 2020-10-27, 08:50:
Both the original PC and XT BIOS and XT clone BIOSes support 4 FDDs out of the box... also taking a second look at the board I may be wrong about the missing logic chips (they may be for a second UART chip which would make a more sense, as this card uses the same NEC FDD IC as the original IBM controller). Hard to tell without looking at the back side of the controller.
