Reply 37100 of 53082, by RetroAddict
Slot1 wrote on 2020-11-10, 22:10:
Hanamichi wrote on 2020-11-10, 21:48:
Thanks, she's a thicc one too you can feel the quality. I forgot I had this for a partner in crime: […]
Slot1 wrote on 2020-11-10, 19:40:
The board looks beautiful. Now I wish I had a red board like that but with ISA slot for the GUS. 😀
That GUS looks unused! Congrats!
I remember there being a TMC S7 red board and some red SIS 370, 462 boards with ISA slots 😀
Nice choice, a red ForteMedia sound card. I love the matching color.
Thanks, it does look in excellent condition. Also congrats for finding the board, its lovely.
Wanted to thank you for your message @Slot1, I unfortunately cannot reply to these yet! Too few posts!
Reply 37101 of 53082, by pentiumspeed
Nip!
Tetrium's wrote:
You also stated that the snapping of the stock Intel CPU HSF must have been some kind of user error on my part. I've build over a 100 systems of that era and taken apart and repaired literally hundreds of systems from that era and I can tell you that the snapping of this particular piece of plastic was abnormal.
But noooOOOooo, you had to reply with this ranfurie idiotic generalization of yours that it must have been some kind of user error of my own doing or something.
It's definitely an issue, just like for instance the yellowing of white and beige plastics is. Or are you gonna say that these were manufactured this way as well now?
No kidding, back in the day, when P4 just came out, at work, we put together this and their intel's design two lever heatsink made alarming noise when we carefully latched on. But being curious, tried to unlatch snap!
Cheers,
Great Northern aka Canada.
Reply 37102 of 53082, by cyclone3d
pentiumspeed wrote on 2020-12-01, 03:14:
Nip! […]
Nip!
Cheers,
While I don't care for the two latch Intel system, the only time I have had one break was when I dropped the cooler on the floor from a few feet up. think I had one damaged in shipping as well but that was because the seller of the parts I bought did not package properly.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 37103 of 53082, by ODwilly
I will take the lever system over the God awful pushpins any day. Iv had 5 break when installing them and 2 break when just removing them.
Reply 37104 of 53082, by ragefury32
adalbert wrote on 2020-11-30, 21:59:
ragefury32 wrote on 2020-11-30, 21:50:
The ESS Maestro/Allegro on the machine (also found on the Inspiron 4000) is a bit of a hit-and-miss though. It's not hardware ESFM so some of the FM synthesis sounds a bit off (kinda like an Ensoniq S2000).
Yeah, for that I have Presario 1800 with ESS Solo-1, which is nice for late 90's games (P3 700MHz, ATI Rage Pro 128 16MB /i soldered additional 8MB/). It can even run Windows 3.11 with working display drivers and sound.
Ah yes. My K6-2+ thin client and my Thinkpad 240s all have ESS Solo-1s, and they are excellent for FM synth. My Dell Inspiron 4000 features the Rage Mobility M3 / 16MB of VRAM which is very similar to yours - I do like it enough to keep it around.
Does your Presario originally have 8MB of VRAM and you solder in an extra 8 to yield 16 in total, or are you on 24MB of VRAM now? The extra RAM actually increased your total VRAM bandwidth so it'll show a performance bump-up....from what I remember off an old Anandtech writeup (https://www.anandtech.com/show/505/2) all of the Rage Mobility 128s / M3s have 8MB embedded internally with a 64 bit data-path (think TNT2 m64), while the 16MB version has an extra 8MB on its own 64 bit data-path, giving you the full 128 bit.
The Compaq Presario 1800s are very solid machines - it's too bad HP pulled the old Compaq documentations making it difficult for collectors to shop configurations based on sub-model information. If I didn't get the Dell I would've gunned for the Presario.
Reply 37105 of 53082, by cyclone3d
ODwilly wrote on 2020-12-01, 03:44:
Oh yes... the push-pin system was/is horrid. Ever had one pop loose while a system was powered on?
I mean.. it works most of the time but I am always afraid I am going to break something when locking the last one in place.
YMF7x4 Guide
Reply 37106 of 53082, by adalbert
ragefury32 wrote on 2020-12-01, 04:08:
It originally had 8MB only on-chip and two empty solder pads. I soldered two chips taken from desktop Rage 128 Pro card and now it has 16MB. 3dmark99 went up from 4160pts to 5314pts 😀 /I had 1GHz P3 during both benchmarks, but 700MHz generates less heat/
Yeah, there are numbers like 18XL123 etc., but it's hard to tell what that means, and higher doesn't mean that it's better.
Reply 37107 of 53082, by Dmetsys
Another CPU to add to my collection: Am5x86-P75. I've been wanting to play with one of these.
A7N8X-LA | 2800+ | GeForce2 MX400 | Audigy 2 ZS
BE6-II 1.0 | PIII-933 | Viper 770 TNT2 | Live 5.1 Value
MS-5169 | K6-2 450 | Voodoo3 3000 AGP | AWE64 Value
P5A-B | P200-S | 64MB | MGA Millennium | Yamaha 719
LS-486E | Am5x86-P75
Reply 37108 of 53082, by fool
Just to participate even once, todays catch is the following...
- Hercules Dynamite VL Pro, very nice condition and 4x512kB chips. Perfect for my Shuttle HOT-419R3 + Am5x86 P75 build.
- Beige ATX-case, clean and very good condition. I will make some approproate PII or K6-2 build into. Period-wise keyboard and speakers came along.
- Voodoo 3 3000 AGP, nothing special here but for a good price could not miss.
    49.12 KiB
    43.16 KiB
    1.25 MiB
Toshiba T8500 desktop
SAM/CS9233 Wavetable Synthesizer daughterboard
Coming: 40-pin 8MB SIMM kit, CS4232 ISA wavetable sound card
Reply 37110 of 53082, by pc-sound-legacy
fool wrote on 2020-12-01, 19:04:
Nice ET4000 VLB card! The ISA one is relatively common, VLB is quite rare, thought.
Reply 37111 of 53082, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
guys, if you can't make your points without calling other users names, just don't make them at all.
For now I've deleted several posts in which you named others idiotic, stupid, retarded. Sorry if that breaks a bit of this thread but would you just behave, please?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 37112 of 53082, by aha2940
Turbo -> wrote on 2020-12-01, 19:57:
A sentence that has words nothing special and Voodoo doesn't exits. 😀
Funny, I have a voodoo 3 2000 PCI and I also think it's nothing special. IMO, the special voodoo cards are the 1 and 2, which seem to be compatible by default with all the cool voodoo-only accelerated games. The voodoo 3, while mostly compatible, many time requires patches and what not to play properly, and for the ones that it is compatible by default (like Unreal) they look the same or better (again: IMO) using the latest updates and OpenGL. Anyway, I'm glad of having that card, it was given to me as a gift because "it was broken" many years ago with its drivers CD. In fact, it was just dirty and it works perfect.
Reply 37113 of 53082, by appiah4
I think the Voodoo 3 PCI and Voodoo 4 AGP are also special cards as far as I'm concerned. Voodoo 3 AGP and Voodoo 5 mean nothing to me though.
Reply 37114 of 53082, by ODwilly
Bought a Asus GTX 570 from a pawnshop for $20. This card : https://www.newegg.com/asus-geforce-gtx-570-e … N82E16814121432 I think I will pair it with a I5-760 Dell XPS, bump the ram from 8gb up to 16gb and throw a 500gb SSD on it for my 14 year old niece. She needs something for school since her laptop died, and wants something to game on since she doesnt have a console.
Reply 37115 of 53082, by fool
Now I have a feeling I should have been more specific with the statement
That is a great card, I did not mean to criticize... although Voodoo 2 SLI is more interesting to play with.
Voodoo 3 just gives me anything new for my retro builds. I have a bunch of those already and it also reminds me about PCI version I need badly.
Reply 37116 of 53082, by ODwilly
cyclone3d wrote on 2020-12-01, 04:46:
Omg nope I cant say I have, thats nuts! I currently have one 2nd gen i5 system with 3 push pins secured. The 4th one simply wont latch. Temps are stable and low, so I dont think I care enough to replace the HSF.
Reply 37117 of 53082, by CrFr
This was in a computer I bought. Nothing special, just a token ring card, but the PCB looks interesting. I wonder why it was built like this? It almost looks like some hobbyist prototype made on strip board.
1.65 MiB
1.91 MiB
Reply 37118 of 53082, by liqmat
CrFr wrote on 2020-12-02, 12:47:
That card is pure sexy looks. That's a wall hanger imo.
Reply 37119 of 53082, by chrismeyer6
That card is super cool looking. I'd probably mount it on a shadow box to display.
