Reply 37280 of 52819, by H3nrik V!
Check out this thread regarding TVC1622 (amongst other info on slotkets) MS-6905 slotket V2.3 works fine, V2 only at 100MHz
Reply 37281 of 52819, by devius
LewisRaz wrote on 2020-12-17, 22:33:
SW60XG midi board arrived today. Had some faffing around to get it to work but am very happy now!
Wow, very nice! That was the sound card of my dreams back in 1998 😀
Reply 37283 of 52819, by appiah4
Not hardware per se but I found manuals for a Commodore C1084S and an ASUS P2B-F in mint condition for next to nothing so I grabbed them.
I also grabbed four local PC magazines from 1989-1991 that I used to read cover to cover again and again as I sat in the can back in the day. I think I will go over them and make a post here later, to detail the computer market in Turkey back in those days, because it was.. amazing 😀
Reply 37284 of 52819, by torpedo_
Bought these today - Olidata OLI-BX (it looks like this is Asus P2B) with P3 500 and some RAM, ASUS V7100 Magic (GF2 mx200), another ATI Rage Theater 128, couple of Microsoft mice, hdd rack and Saitek ST110.
1.74 MiB
And these TEAC speakers that follow iMac G3 style 🙂
1.47 MiB
Reply 37285 of 52819, by Aublak
Another E-waste pickup
-AOpen AX6BC Slot 1 mobo
My Asus P3B-F mobo hasn't been taking kindly to my Coppermine 1ghz (SL4BS) processor. Even after upgrading the BIOS. I was hoping this AOpen board would do better, but it seems to only have a max FSB of 100mhz. Damn. 🙁
-Socket 3 Chicony CH-491F mobo
Still looking for that perfect 486 mobo. I'm not finding much info on this one. Its in great condition though so I had to take it.
-Intel i740
I was always curious about these cards. This one unfortunately doesn't have its slot cover.
-Pentium 166mhz with attached heatsink
I dunno what kind of power cable I'd need to power the fan. I searched Ebay for "2-pin female-to-female power cable", but I'm not getting what I'm looking for.
    1.02 MiB
    Intel i740
    695.88 KiB
    Pentium 166mhz
    1.5 MiB
    Chicony CH-491F
    940.74 KiB
    AOpen AX6BC
Reply 37286 of 52819, by Aublak
I bought this ti 4600 off Ebay for ~$30. I only really bought it for the heatsink. I have like 7 broken ti 4600s that I pulled from e-waste, but they are all so difficult to fix. I figure, I'll be able to fix at least one of them.
Anyways, the seller says this ti4600 has artifacting. On closer inspection, seems like some of the capacitors are swollen. Might be an easy fix. Everything else looks fine.
EDIT: Spoke too soon. Found a broken trace.
I also bought this new/old Slot 1 Titan cooler. Looks great on my 1ghz P3.
Reply 37287 of 52819, by devius
Aublak wrote on 2020-12-19, 18:00:
I have a Pentium 120MHz that has a similar system. It looks like this:
100.24 KiB
Pentium 120MHz with attached heatshink
Reply 37288 of 52819, by Aublak
devius wrote on 2020-12-19, 18:27:
Ah, okay. I figured it went straight to the motherboard.
Reply 37289 of 52819, by appiah4
Another E-waste pickup […]
-Intel i740
My DX33 rig runs on a CH-471A and it is fairly good despite some minor issues (Y2K bug and no PS/2 mouse header being the top of my list). I'd be interested to hear how 491 fares for you.
Also, use Dupont female to male jumper wires for that fan and connect them to +12V and G on a Floppy molex.
Reply 37290 of 52819, by Robin4
Where can you buy such a cable?
Reply 37291 of 52819, by Aublak
appiah4 wrote on 2020-12-19, 18:50:
-Intel i740
I didn't know there was a CH-471A. Maybe its manual could shed some light on this mobo for me.
I think this might work for my power needs.
https://www.ebay.com/itm/4-Pin-Molex-IDE-to-3 … gwAAOSwi8VZUqSo
or this
https://www.ebay.com/itm/Micro-3-Pin-Fan-Conn … bgAAOSwoX5asqEH
Reply 37292 of 52819, by appiah4
Chances are CH-491E is more likely to help you. Yours may just be a 5V/3.3V version.
Reply 37293 of 52819, by Aublak
appiah4 wrote on 2020-12-19, 19:08:
Yup, I do see some 3.3v jumpers. I wonder how I could get one of my AM5x86s to run on it?
Reply 37294 of 52819, by appiah4
Set it up as an Am486DX2 and try it. You won't damage the chip, and it might just work. It is an AmDX2 with a 4x internal multiplier after all.
Reply 37295 of 52819, by Aublak
appiah4 wrote on 2020-12-19, 19:42:
Alright. I just want the "Ultimate 486 Doom Machine".
I also have a Pentium Overdrive, but I might as well go Socket 7 then. Would be interesting to how this board could handle Quake on a POD83 though.
Reply 37297 of 52819, by pentiumspeed
WOL cables are same 3 pin connectors. I bought this way and gives you two ends by cutting the wire in half, to reconnect retail pentium heatsink by soldering together this to any connector needed at hand.
Cheers,
Great Northern aka Canada.
Reply 37298 of 52819, by devius
Aublak wrote on 2020-12-19, 19:02:
I think this might work for my power needs. https://www.ebay.com/itm/4-Pin-Molex-IDE-to-3 … gwAAOSwi8VZUqSo or this https://www […]
or this
The connectors seem the right ones, but the pins on the smaller connector are not in the right order. Pentiumspeed ‘s suggestion might be easier depending on what tools you have available.
Reply 37299 of 52819, by psychz
Last retro hardware purchase for 2020, arrived today... Sonnet Encore/ST G4 Duet 1.3GHz - two 1.3GHz PPCs on a G4 CPU card
This went in a side-of-the-road find 400MHz Sawtooth PowerMac which had its HDDs taken out and a dead PSU. I have already restored/upgraded it with:
  • a bigger PSU (ATX pinout rearranged as described here)
  • more 100MHz SDRAM (the sweet spot might be 768MB to 1GB, above it some apps tend to glitch)
  • a flashed Club3D ATi Radeon 9250 AGP running 1920x1080x32 just fine in OS9 (64KB firmware here)
  • 2x80GB WD blacks
  • an ATAPI ZIP with the original graphite-case front panel borrowed from another G4 whose case was on worse condition
  • a PC SoundBlaster Live (patched drivers) with MIDI through OMS (scratch that, Creative's extensions made it take ages to boot, I'd rather use an Audiophile or a USB MOTU interface)
  • a new clock/nvram battery
It is currently running MacOS 9.2.2, I'm considering moving to MorphOS but as far as I can tell, the second CPU will be left unused.
Don't care about OS X at all, after all I still keep my Intel unibody at 10.6.8 with Rosetta, so it's either MOS or OS9 on this thing.
Next upgrade would possibly be a OS9-boot-compatible SATA card...
Stojke wrote:
