Reply 37880 of 52943, by ragefury32
SteveC wrote on 2021-02-02, 11:46:
ragefury32 wrote on 2021-02-02, 02:21:
Yeah, that's a common affliction of old subnotebooks - they generally do not boot off USB1.1 - not that USB1 is great for bootin […]
SteveC wrote on 2021-02-01, 18:18:
So these turned up today and both work but have failed hard drives. So annoying though as you can't boot off USB and I don't have the dock to get the RJ45 port for ethernet and I don't have the custom connector floppy drive so I can't boot off floppy! Have to prepare a drive in another PC and move it over, taking the laptop to pieces in the process.
Nice little laptops though - should make nice Windows 98 machines to play with - 2 player over irDA haha. PII 300Mhz with 128Mb might struggle under XP, and 2000 might be a bit restrictive on gaming.
edit - just working on the second laptop and the hard drive is fine, just partitioned (into win98 and win2k labelled partitions), wiped and looks like someone forgot to make a partition active or put boot files on it. I bet they didn't any method of installing Windows either so gave up!
Yeah, that's a common affliction of old subnotebooks - they generally do not boot off USB1.1 - not that USB1 is great for booting ISOs anyways. If you got a Toshiba external drive + cable, it might use the TEAC FFC26 interface. If it does, you can mod yourself a nice little mini-Gotek for those machines.
If you are lucky you got a pair of Portege 7010CT - the Neomagic 256AV is an okay 2D-only chip (although gona.mactar.hu and its DOS compatibility table will disagree). The real winner here is the legit OPL3-SA3 audio (YMF725 if I remember correctly). If I am gunning for a PII class subnotebook the 7010CT and the ThinkPad 240(ESFM Solo-1) will be my choices.
If you are not so lucky? You might end up with a pair of Portege 3110CTs. You'll want to look up how to configure the ESS Maestro 2 (ES1978) for DOS if you plan to use it there...it's not that straightforward. The Maestro 2 is a decent Windows AC97 chip but not well regarded in DOS. Keep expectations low for the Trident Cyber9525 video chip onboard - use it as a 2D card (it'll do fine and compatibility should be good) and ignore whatever Direct3D hardware acceleration it claims to have. It's based on the Trident 3DImage family, essentially a 3DImage 975 but with less VRAM - let's just say that there are generally more respect for the S3 Virge MX than this one - if it's not slow in Direct3D then it's glitchy as hell -> https://vintage3d.org/trident.php
Yeah, I know. Why can't Toshiba make a small machine with the Trident Cyber9525 and the YMF725F on the SAME CHASSIS? It would at least be a decent little laptop for late DOS/Early Windows...
I wasn't so lucky and got 3110CTs but I still think it's a nice little machine. I do need to research the audio in DOS though. Shame one laptop has died, but at least I have some spares for the other one!
Heh. Well, that gives you the opportunity to buy a 7200CT/CTe. Same audio chip as the 3110CT, Cyberblade e4 graphics (some light Direct3D gaming is possible) and a Coppermine Pentium III. It’s actually a pretty decent alternative to the Sony Vaio PCG-SRxx machines (those have YMF754 but TERRIBLE keyboards).
As for the ESS Maestro drivers, I swear that one day I’ll have some bandwidth and bundle up the working DOS config off my Dell C600.
Reply 37881 of 52943, by Deksor
wiretap wrote on 2021-02-02, 12:16:
Deksor wrote on 2021-02-01, 20:24:
AMD goldfinger look so simple and are becoming so hard to find these days that I think we should retro-engineer them and make a open schematic.
I have no goldfinger myself but I'd love to make my own ^^
There are several schematics out there for them. I was going to start a PCB design for one a while back, but the thread on here pretty much died and there seemed to be no interest. Maybe I'll pick up the project soon.
I haven't seen your thread about making new ones. Can I have a link ?
Reply 37882 of 52943, by gex85
Deksor wrote on 2021-02-02, 17:04:
There's also a thread over at the CPU-World forums: https://www.cpu-world.com/forum/viewtopic.php?t=28887
Seems it has been making very very slow progress over the last months and years, but has gained a little bit of traction lately. But it still doesn't seem like that GFD remake would be available in greater quantities anytime soon.
For the record (1): I would be interested in getting one, too.
For the record (2): Seems that finding a suitable connector is one challenge that arises during this project, I once bookmarked the TE Connectivity Part No. 1734037-4 that should be a good fit. Just in case.
My retro computers
Reply 37883 of 52943, by subnet_zero
Skanque wrote on 2021-01-31, 13:59:
New arrivals: […]
New arrivals:
ATI Radeon 32MB SDR PCI
Megavision3D - Trident ProVidia9685 3MB SDR PCI
ColorMax Va368 - S3 Trio 3D/2X 8MB SDR AGP
CardEx Pro GX2 / AGP (Gainward) - S3 Virge GX 2 4MB SGR AGP
IMG-2848.jpg,
Wow, never seen those boxes before. I somehow estimated that those Trident/Trios cards came without a box. Must have seen to many without it.
Also very nice artwork from the Radeon. This scorpion with the RADEON letters would make a very nice late 90ies t-shirt.
Reply 37884 of 52943, by wiretap
I can't find it, it was sometime a year or more ago. Maybe it was a different forum I'm thinking of. I plan on making a replica of the Northwind GFD v1.0, since it is the easiest (all THT), I have clear pictures of all the traces, clear pictures of all components, and I have the dip switch config table. One thing I could use help with is the part number for the AMD connector, and the pinout.
https://web.archive.org/web/20001206111700/ht … dcomputers.com/
My Github
Circuit Board Repair Manuals
Reply 37885 of 52943, by gex85
wiretap wrote on 2021-02-02, 20:23:
I can't find it, it was sometime a year or more ago. Maybe it was a different forum I'm thinking of. I plan on making a replica […]
Cool. Looks perfectly doable.
That connector actually looks like the one I mentioned above: TE Connectivity 1734037-4
https://www.te.com/usa-en/product-1734037-4.html
https://www.te.com/usa-en/product-1734037-4.datasheet.pdf
My retro computers
Reply 37886 of 52943, by wiretap
gex85 wrote on 2021-02-02, 20:43:
Cool. Looks perfectly doable. That connector actually looks like the one I mentioned above: TE Connectivity 1734037-4 https://ww […]
Thanks, I totally missed that.
My Github
Reply 37887 of 52943, by Deksor
Well I guess we could bump the old thread if you can find it make a new one ? ^^
Reply 37888 of 52943, by wiretap
Deksor wrote on 2021-02-02, 21:39:
Bumping one of your old threads I found that will be a perfect fit I think.
My Github
Reply 37889 of 52943, by SteveC
ragefury32 wrote on 2021-02-02, 15:55:
By the way the ESS Maestro DOS driver simply meant running maestro.com in DOS that was installed by the Win98 drivers - that's it!
Reply 37890 of 52943, by BetaC
Why yes, I will take those Apple Pro speakers that can only be used with a specific generation of hardware that I already have for $5.
1.89 MiB
Seriously apple, why did you need to make these speakers so proprietary.
Reply 37891 of 52943, by imi
BetaC wrote on 2021-02-02, 23:47:
scnr x3
152.44 KiB
Reply 37892 of 52943, by ragefury32
SteveC wrote on 2021-02-02, 23:17:
ESSAudio.sys on config.sys and ESSaudio.com on autoexec.bat - but that’s the easy part. The tough part is that essaudio.com requires an essaudio.ini file (note: not in Windows INI file format, it’s actually stored in hex/ascii values) that tells the underlying hardware how to set the audio hardware up - that ini file is created via an ESS bundled utility which derives it from your Windows audio setup when you install the vxd (not wdm) version of the ESS maestro audio drivers. For me, I took the semi-easy way out. I have a Dell C600 with a working Win98 install, and a Compaq n600c that needs one.
Since the Compaq n600c and the Dell C600 are so similar I simply swap hard drives between the 2 when I want to do DOS stuff, and most things seem to work. Although there are very subtle differences. On the c600 the Maestro works on DDMA mode. On the n600c it’s TDMA mode, which messes with some games (TIE fighter locks up on load). Chances are , if I zip up that essaudio.com and the ini file and toss it over to you, it should work.
Reply 37893 of 52943, by aha2940
appiah4 wrote on 2021-01-27, 09:24:
I got a Biostar P4M890-M7 SE, Intel Core2Duo E4600 and 2GB DDR2 Memory for my Win98/Linux build to go with the ASUS X850Pro PCIe […]
I got a Biostar P4M890-M7 SE, Intel Core2Duo E4600 and 2GB DDR2 Memory for my Win98/Linux build to go with the ASUS X850Pro PCIe I got a few days ago.
Trying to decide on a Linux distro to install on this..
The linux distro to use on a PC like that would depend on what you want to do with the machine, IMO. If you want to use it as a desktop, with graphical environment and everything, I'd go with a not so recent, but supported distro, like RHEL 7 (now that it is free). If you will be using it as a server, any of the newest distros would do the trick if you install it without any GUI.
Reply 37894 of 52943, by Ozzuneoj
Just nabbed this. Never seen one of these before, and I can't find any pictures of the card or the box online anywhere other than an old amazon.ca listing. Going by the pictures and feature set, I'm thinking it's a MediaVision Thunderboard variant. The real struggle will be to not open it play with it. I'm not one to keep sealed boxes around but this seems pretty rare.
211.68 KiB
248.9 KiB
The only other mention of an IBM Easy Options sound card I've seen is a post here relating to a 16-bit card that someone found.
It is on TH99 though!
https://arvutimuuseum.ee/th99/i/I-L/51749.htm
By the way... who got the sealed Windows Sound System from 1992? I was tempted but it was a bit pricey... even this one I got was not cheap. I need to block ebay on my computer for a while... 🤣
Reply 37896 of 52943, by Caluser2000
Ozzuneoj wrote on 2021-02-03, 05:50:
Just nabbed this. Never seen one of these before, and I can't find any pictures of the card or the box online anywhere other tha […]
The AudioVision Thunderboard never had any Midi support. It was my first ever x86 sound card.
Reply 37897 of 52943, by Ozzuneoj
Caluser2000 wrote on 2021-02-03, 06:02:
The Thunderboard has jumpers to enable MIDI over the gameport, but I have no idea what kind of support it has. I doubt it is MPU401 compatible... and I doubt it'd be too useful anyway, since even MediaVision's later cards had glitchy MIDI output.
Anyway, the card in the picture is definitely a Thunderboard. They list GAME\MIDI on the box because the card claims to have some kind of MIDI support. IBM was apparently under no obligation to test that functionality before designing the box. 😁
Reply 37898 of 52943, by Caluser2000
Ozzuneoj wrote on 2021-02-03, 07:01:
No it didn't. I sugest you readthis thread Topic 6452
Reply 37899 of 52943, by CMB75
Apart from various other items like an A2600 Darth Vader, some PC magazines from 93/94 and TAG-RAM chips I found this, rather dirty and quite beaten up, beauty.
I couldn’t resist the “wannabe from 70s” design of this 80186.
147.69 KiB
Unfortunately it’s going to need quite some effort to bring it back to it’s original glory.
