Reply 38280 of 40007, by PTherapist
H3nrik V! wrote on 2021-03-02, 05:24:
Yeah, the fun is the process 😉 well, as I'm an electronics engineer, and the C64 being relatively simple, some debugging should be doable.
But then again - will a recap of the power supply help anything, or is it just a transformer? And where would be the right place to find and ask for information? Is there a subforum here on vogons, that suits?
If it's like most C64 power supplies it'll probably be filled with epoxy inside, so no chance of a simple repair job. It's easier & safer just to buy a modern C64 power supply replacement.
Reply 38281 of 40007, by H3nrik V!
PTherapist wrote on 2021-03-02, 05:48:
Oh, yeah, that would make sense. At least it's simple 😀
Reply 38282 of 40007, by brostenen
brostenen wrote on 2021-03-01, 20:24:
H3nrik V! wrote on 2021-03-01, 09:11:
Didn't actually buy this per se - as the cost was "If you ever get it to work, invite me to a gaming night". A friend texted me yesterday as he was cleaning out his garage and asked if this was something for me.
Apparently it worked 10 years ago, when it was last powered up. I don't have anything to connect it to (or maybe the old TV has an analogue tuner) and I'm also reluctant as I've heard the Powersupply should pose a great risk of frying the computer - or is it just a matter of opening and recapping?
First you need to check voltages on that PSU. Just keep in mind that it can blow at ANY time. Most of the times it releases a massive spike in voltage, in few situations it just dies. Anyway. If no picture, and voltages are fine, then it can be anything from dead VIC-II, over dead PLA to dead memory chips.
Getting it to work is most of the fun right? 😁
That is a nice job you have. Were you educated down in Sønderborg? I have a number of half finished educations from back in the 1990's, and I were a student down there at "skolepraktik". Back then it was called "Datamekaniker". Today it is just "Datafagtekniker". However, we were screwed over by the boss at skolepraktik, as he did not give us any jos that were related to the education. He sure was inventfull and had us all clean old 8088/8086 bank computers, that he then could sell for a profit. We were told by him, that all education related practice and chores, were something that we had to do strictly in our spare time. Well... It does not take much brainpower to figure out, that nobody passed any tests and examinations in class.
Anyway....
The PSU you have, are one of those wedge ones. It is a standard old school linear AC and DC power supply. Yup. 9v AC and 5v DC as far as I remember. The voltage regulator is the bad news regarding all Commodore64 PSU's. It is only rated at exactly what the machine is supposed to be supplied with. And taken that it is from 1984'ish, then it has degraded and will short out at some point. The good news about your PSU, is that most of the DC part is not enclosed in Epoxy. The square white ones have all parts inside a big lump of epoxy.
As you can see, then it is a relatively simple device. Nothing strange or anything, other than a regulator that are not rated high enough. When it goes, then it goes. And then it will send a major surge of power straight into the 5v DC line. The chips inside the machine do not have any protection. You know. Commodore cheap'ed out on so many things, and engineers like Bill Herd have said so many times, that they designed all machines for a max of 3 or 5 years use. He never ever thought or believed that we would still play with 8bit machines in 2021.
I will be sending you a PM, regarding places that you can ask for help at. Vogons do not have any sub forum for these old 8bit platforms, or even 16bit such as Amiga or AtariST.
Reply 38283 of 40007, by Warlord
Just bought a 1080ti for $59.00 Someone is selling a huge lot of them this morning.\ If you want one jump on it, they already sold 13 of them in 30 minutes.
Reply 38284 of 40007, by bearking
Warlord wrote on 2021-03-02, 14:26:
https://www.ebay.com/itm/EVGA-GeForce-GTX-108 … cQAAOSwt9JgPkQ7
Hmmm, usually what is to good to be true, it's not true... I don't think the seller has more them one card... But, good luck!
Reply 38285 of 40007, by aaronkatrini
It´s just a scam... nobody would give them away!
Reply 38290 of 40007, by Munx
Yeah it's a scam. This happened quite a lot during the last GPU shortage.
My builds!
The Underdog - The budget K6
Reply 38291 of 40007, by fosterwj03
Warlord wrote on 2021-03-02, 14:41:
I'll take my chances.
I took a chance as well. I've had good experience getting money back on eBay (usually at lower price points though) when I received something different from the description and/or it didn't work.
I have no issues with purchasing used computer equipment at a reasonable price. If it works great! If not, oh well.
If this is a scam, I could post a Youtube video like those on RandomGaminginHD's channel when I disassemble it.
Reply 38293 of 40007, by HanJammer
imi wrote on 2021-02-04, 01:05:
so, while browsing my usual searches a few days ago this thing popped up and I was like... "sure" even though I have no idea wha […]
so, while browsing my usual searches a few days ago this thing popped up and I was like... "sure" even though I have no idea what it is x3
at first glance it looks like a SB 1.0 clone to me with a bunch of GALs to substitute logic chips?
could not find anything about this card, there is unfortunately no FCC ID or anything on it, only a generic serial number sticker on the back.
the supposed "OPL2" does not look like a genuine yamaha chip to me so idk what's under this sticker.
edit: on second glance the chip looks the same as the "5A12" OPL2 clone chip on another card I have.
looking at the date codes it seems to be a card from 1991?
will take a more detailed picture when it arrives but I thought I'd ask if anyone knows what this is ^^
seller's picture:
Yeah, that's SB compatible card. I have like 3 of them in various versions...
Check out my YouTube channel the "Rusty Bits"
Reply 38294 of 40007, by pentiumspeed
True scam. Sometimes I get a auction where seller listed for example 2TB M9T for 20 each and then suddenly ebay pulled the auction and refunded all the buyers. This had happened 2 times for me on two separate occasions with different items.
I think seller was trying to gather the money and ship bricks.
Cheers,
Great Northern aka Canada.
Reply 38295 of 40007, by bjwil1991
As someone who got swindled by a scammer on Twitter, I'm not taking chances either for those items.
Reply 38296 of 40007, by dulu
1.77 MiB
$30. The most horrible disassembly ever, but not because of the strange design. In order to unscrew the fan cover I had to use a dremel eventually. The screws acted as if they were welded on, and you could see that they were factory-made. I understood why the cover of the second part of the "sandwich" was (unfortunately) broken by the previous owner. One of the fans does not work (when the voltage is turned on, it vibrates slightly. This white plasticine is left over from thermalpads. I ran it in dell optiplex 7040 with an additional external power supply without a fan to check if it works - I log into windows (w10), drivers are installed but In the device manager I see 2 GX2 GPUs with a yellow triangle. Well, I'm glad that I can see the desktop at all, because I did not expect that the card will even start in such an unusual config. Card is cleaned up and waiting for new thermalpads and a fan. The cheapest option - $4 (and the only one) are these two corrupted gpu`s:
294.4 KiB
The color and basic code of the fan is correct, but I'm worried that it only has 2 wires (the fan in gx2 has PWM). I can't find information anywhere if there were different PCB versions of these fans, I hope I can solder some additional wires.
Maybe someone has a gpu with this type of fan with two wires and can check ammount of pins.. i would be grateful 😀
Reply 38297 of 40007, by MCGA
I bought a Zenith Data Systems Z-425S+ yesterday. I don't know much about this system, I really couldn't find much about it online.
I thought i was buying a 386 -- which I really want, but when I opened it up I saw it was a 486. I couldn't read the model number from the poster's picture.
The battery was leaking, but from what I can tell it was confined to just the plastic holder. But just in case I'm going to pull the board out and check the back.
Hopefully this system works, and hopefully I can get into the BIOS.
    400.11 KiB
Reply 38298 of 40007, by pentiumspeed
486sx 25 is like fast 386 33 still good deal. Sometimes I am OCD about what exactly wanted to get so I paid little more to get 386 parts to rebuild my compaq computers.
My turn:
Value Village yielded goodies: Optiplex 990 SFF (sandy bridge CPU type), Rage IIc 2MB PCI for parts or use, LG 19" or so, Jasper board xbox 360 black with 120GB. Was still keeping a eye out for 360 slim hopefully score one with hard drive cartridge. Oh well, genuine microsoft slot in type (smaller type) in any size cartidges are expensive (around 50 cdn dollars total).
have to look at model number on LG and take apart the optiplex 990 tomorrow, very late tonight, I was with my friend at their house for dinner after trip to V.V.
Cheers,
Reply 38299 of 40007, by Horun
Bought a Cooler Master cheap mini tower ATX case today for $20 from the local thrift store, will work well for any mini AT or mini ATX board.
Has a mobo and parts so was really hoping for some older more Vintage AMD board but nope was a 2015 era board.
WARNING not Vintage: has a Gigabyte GA-F2A68HM-HD2 rev 1.1 board, AMD A4-7300 APU, 2 x 4Gb Ballistic DDR3 1600Mhz, 500GB WD Blue HD and a no name DVDROM.
Disappointed in the PSU is very crappy no-name 450watt but the machine boots fine. Guess it was worth $20 but inside was dust filled and looked like it was a vacuum cleaner bag 🤣
Was really hoping for some older more Vintage AMD board but nope was a 2015 era board.
    185.25 KiB
    307.41 KiB
    235.57 KiB
