Reply 38620 of 52983, by cyclone3d
kixs wrote on 2021-03-30, 11:36:
cyclone3d wrote on 2021-03-29, 18:27:
Finally found an M919 cache stick on eBay... while I was scouring through a ton of listings.
Me too. It also came with the motherboard 🤣
Hah... I have an M919 that came in a scrap lot but with no cache stick. Was actually contemplating selling it and then the other day decided to do one of my way too broad searches on eBay and found the cache stick after looking through at least 1,000 listings.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 38621 of 52983, by imi
that wasn't on ebay by any chance?
snatched it away right in front of me :p
Reply 38622 of 52983, by cyclone3d
imi wrote on 2021-03-30, 15:29:
I saw a listing on eBay where somebody was selling 3 M919 motherboards. Only one had the cache stick and since at least one of them was already sold I'm guessing the one with the cache stick went first.
YMF7x4 Guide
Reply 38623 of 52983, by flupke11
I've picked up a beauty today:
66.92 KiB
108.43 KiB
It has the V55LA mainboard, so with the Ali Alladin III. Nothing fancy, but I like the fact that this cas has only been opened once, to install "multimedia", being the CD-rom and a sound Blaster Vibra. No smoker's environment and only a few specks of dust around the cooler.
I got the original clickety-click sounding qwerty keyboard and a 4:3 pretty pristine NEC 17" screen.
Reply 38624 of 52983, by chrismeyer6
luckybob wrote on 2021-03-30, 02:56:
https://www.ebay.com/itm/303930527344?ul_noapp=true
Overpaid for a single p-pro board. Like seriously. The only reason I decided to fully open my wallet was the chipset. All p-pro boards I've seen are 440FX or TX. This is the first one i've seen based on the 450GX. Which is the same chipset in my ALR 6x6.
So a massive multi-processor chipset, on a single cpu board...
To be honest I would of done the same thing. It'll be fun to see how that chipsets performs with only one P-Pro.
Reply 38627 of 52983, by EvieSigma
I originally thought I had paid too much for this Mitsumi keyboard, given it doesn't have clicky switches and I paid $40 shipped for it...
...until I noticed this AT/XT switch that conveniently wasn't shown in the seller photos. I didn't feel so bad after that!
Reply 38628 of 52983, by bjwil1991
Bought a Compaq Diagnostics kit for my Portable 1.
237.32 KiB
Reply 38630 of 52983, by brostenen
Next DIY-Soldering project PCB's are ordered.... (I bought two different ones)
They are so awesomme, that I will not say what they are yet. I will post more, once the first are build.
Reply 38631 of 52983, by chrismeyer6
brostenen wrote on 2021-03-31, 09:11:
Sweet im looking forward to seeing that. The other projects you've done are awesome.
Reply 38632 of 52983, by Doornkaat
mpe wrote on 2021-03-25, 20:45:
Nobody can have too many Socket 5 so I bought this FIC PA-2000. […]
It is going to be first VIA chipset covered in my Pentium Chipset comparison. Several people asked be to add VIA.
This one has Via Apollo Plus (575MV) which is actually cost reduced version of the Apollo Master (575M) chipset without pipelined burst support. So I might eventually add also FIC PA-2001 with full version of the chipset.
Also buffered RAM and 8 SIMM slots so I don't have high hopes for performance....
This board was in the first PC my brother and I got as a hand me down. It isn't fast but I think it's kind of cool that it's mostly through hole components. Not too common on a Socket5 board.😄
I have still got the board somewhere.
Reply 38633 of 52983, by kixs
I get lucky sometimes 😁
Reply 38634 of 52983, by bjwil1991
After years of searching, I found a POD 83 and won the auction.
380.92 KiB
Reply 38635 of 52983, by brostenen
chrismeyer6 wrote on 2021-03-31, 12:53:
Thanks. 😀
I am so looking forward to build it. And there are virtually no mention of this elsewere on the net. I can across the webshop by accident some time ago. The only thing I can say, is that it is DIY vintage computer PCB's. However they are in no way the original shape and one is not even the same form factor.
Reply 38636 of 52983, by devius
seleryba wrote on 2021-03-30, 19:13:
Finally.
And a 520 instead of the more common 524! Very nice 😃 My first ever PC was a 510 with an upgraded CPU, so this brings back memories.
Reply 38637 of 52983, by chrismeyer6
brostenen wrote on 2021-03-31, 17:46:
Thanks. 😀
That sounds really fun. Definitely looking forward to see the project.
Reply 38638 of 52983, by EvieSigma
I'm sure this isn't a particularly great card but I had a hard time passing up a good condition PCI video card for 5 dollars. It's a STB Systems "Nitro PCI 1.5" (at least, that's what the video BIOS chip label says) based around a Cirrus Logic CL-GD5434 chip and with I assume 2MB of video memory onboard, with expansion to 4MB.
Reply 38639 of 52983, by devius
EvieSigma wrote on 2021-03-31, 19:53:
... I assume 2MB of video memory onboard, with expansion to 4MB. […]
1MB, expandable to 2MB actually.
