Reply 38940 of 53049, by dulu
What is this? Sellers picture
It looks identical to the GeForce 4 mx460 I bought a few years back. But that could be any GeForce card that gpu and ram cooling solution was used on a ton of cards.
Geforce 2 or Geforce 3. Geforce 4 had a distinctive and different looking cooler.
dulu wrote on 2021-05-04, 20:41:What is this? Sellers picture
I'd wager a Geforce 3 ti200, with the top heatsink lost.
it's a Quadro2 Pro 😉
I'd ask for a clear picture of the back, clear enough to read labels
Got these two at the end of last year, both still sealed.
This will complement my two ASUS P3B-F setups.
I'm looking forward to unsealing, breaking that packaging open, then then trying to work out what to store on the Jaz disks 😀
DELL Dimension XPS M200s
:Intel P1 MMX 200MHz
:64MB EDO
:DOS 6.22/Win95b
:Matrox Millenium II + m3D (PowerVR PCX2)
Chaintech 7VJL Apogee
:AMD AthlonXP 2700+
:512MB DDR
:Win98SE/2000 SP4
:3dfx Voodoo5 5500 AGP
flupke11 wrote on 2021-05-04, 21:02:dulu wrote on 2021-05-04, 20:41:What is this? Sellers picture
I agree !
added: near exact layout as my 64mb. the socket headers are for an add on TV out part.
I was fortunate enough to snag a "computer parts" listing locally on FB. The seller told me they worked at Radio Shack in the 90s and early 00s, and were into building PCs but moved on to other interests years ago. I had to take everything, there were several bins of stuff, here are the more interesting items.
- AWE64 Gold still sealed in the bag, in a plain white box
- AWE64 Value CT4520
- SBLive with LiveDrive and remote
- Socket 423 beige tower PC; Abit TH7-Raid mobo, P4-2ghz, 512MB PC800 RDRAM (4x128MB), Geforce2 GTS, Antec/Chieftec tower
- Mitsubishi Diamond Pro 91 CRT (1600x1200x75hx, 1280x1024x85hz)
- SCSI items; 4 adaptec host adapters (ISA and PCI), 2 hard drives (2GB Seagate Barracuda and 240MB Quantum), 4 CDRWs (one Kenwood True-X)
- GPUs; 9800GT, 2x S3 Trio64, Creative Permedia2, ATI Radeon AIW
- 3.5" internal floppy and zip drives
- Several NICs (ISA and PCI)
- Evergreen MXPro 200 CPU with many bent pins
- So many cables, fans, and modems
I am particularly excited about the AWE64 Gold and the CRT. Thus far I have only tested the tower PC and monitor, which work fine. I had not used a high resolution CRT in a long time, that was nice. Next I need to rearrange my computer setup to make room for the CRT.
framebuffer wrote on 2021-05-04, 21:36:dulu wrote on 2021-05-04, 20:41:What is this? Sellers picture
Yes, it is Quadro2 Pro. But he do not have a good opinion selling mostly untestet garbage. Cheers
Got a $1 beige box custom PC build from circa 2003?ish from an estate sale.
Main event is this sweet purple motherboard with bad caps (already have the caps just gotta get soldering)
Probably will use it for a Windows 98 build, though the lack of ISA slots really sucks.
Also scored a Radeon 9800XT in the same system. Will probably try to sell it. Some caps were... like falling out of the board. Soldered them back in, tested it and it works great at least on Jedi Knight Dark Forces II, a game that refuses to load a level on my Voodoo 5 5500.
Early 90s: IBM PS/2 Server 95/A, Pentium 66, 16MB RAM, XGA-2, IBM SCSI Corvette, SCSI2SD, 3 Com EtherLink III MCA, Resound 2 AdLib MCA
Late 90s: Micron Millenia MXE, ABIT VH6-II, Coppermine 1ghz, 1024MB, Voodoo 5 5500 PCI, GUS Max 2.1, 128GB SATA PNY SSD
Socket 462(A) with DDR/SD-RAM? You paid a wonderful price for that system.
It's also compatible with low power AMD Geode CPUs. Add the universal AGP slot and you have one of the best Socket A motherboards for retro computing.
My builds!
The Underdog - The budget K6
mistermister wrote on 2021-05-05, 03:53:I was fortunate enough to snag a "computer parts" listing locally on FB. The seller told me they worked at Radio Shack in the 9 […]
- So many cables, fans, and modemsI am particularly excited about the AWE64 Gold and the CRT. Thus far I have only tested the tower PC and monitor, which work fine. I had not used a high resolution CRT in a long time, that was nice. Next I need to rearrange my computer setup to make room for the CRT.
The case is awesome!
BigDaddyM wrote on 2021-05-05, 04:42:framebuffer wrote on 2021-05-04, 21:36:dulu wrote on 2021-05-04, 20:41:What is this? Sellers picture
he who?
and why are you telling it to me, I just helped to identify the card, have nothing to do with the seller 😁
Camtheman wrote on 2021-05-05, 04:49:Got a $1 beige box custom PC build from circa 2003?ish from an estate sale. Main event is this sweet purple motherboard with bad […]
as noted by others - what a great buy! i was thinking "what bad caps?" until half way down, but i'm sure it'll be good as new when you are done
i wouldn't worry about the lack of ISA, to me that board says Athlon XP and Windows XP. i'd be happy with that
She looks much like Elsa Gladiac, here is GF2 Ultra.https://www.anandtech.com/show/634/2
Camtheman:
Wow, nice buy. Nothing special, but unordinary purple/violet beauty from ECS. I remember dark brown/almost black K7S5A with SiS 735, which I have years ago. Pretty cheap, but usable board for AMD Duron and Athlon, none OC options (except several FSB/MEM frequencies in Cheepo BIOS from Cheepoman http://www.ocworkbench.com/2002/ecs/k7s5abios/cheepobios.htm). I had no idea there was a Pro version.
And for missing ISA - You can already use some PCI audio, even with FM.
Microsoft Natural Keyboard and IntelliMouse (both brand new)
XFX 7300GS 512M DDR2
Radeon 9500 Pro
HIS HD 4850 IceQ 4
XFX 9500GT
ASUS P4P800 SE + Pentium4 3.06GHz
Nice haul Framebuffer
Not too sure if I'll keep these:
But I'll definitely keep this 😀 :
I need to improve my repair work, and I prefer to sponsor one Asian country over the other.
Edit: I'm cleaning the Ultra now. It's origin is a smoker's household. No judgement, we all do whatever we want, but tar is a bitch to clean.
imi wrote on 2021-05-04, 19:44:this nice trio of boxes arrived recently :3
Very nice Gravis hardware. I live in BC and these frequently show up in thrift shops. I haven't found a Gravis Pro joystick yet so the hunt continues. Very nice, I'm jealous.
