Reply 39260 of 59393, by EvieSigma
BitWrangler wrote on 2021-05-30, 13:02:
EvieSigma wrote on 2021-05-30, 03:18:
How weird that the box it came in (the box for a completely different video card) is also dated 1991. Kinda blows up my "the card in the box was an upgrade" theory.
I've seen that a lot, got burned a few times. The old part gets put away in the box the new part came in, whether it was dead or working. Bought a sealed (by thrift store) soundblaster box, had a game card in, bought a wireless card in box, had the old 10Mbit NIC in, bought a powercolor box (looked like it should have some variety of radeon) had a 6326 in.
I actually came out slightly better on that before, bought a PCI ESS-based sound card box and inside was an ISA SB16 Vibra card.
Reply 39261 of 59393, by Intel486dx33
I picked up this 2009 Mac Pro with Dual quad core Xeon’s for cheap this weekend.
I am going to use it in my Home theater as a media server.
I am going to load it up with hard drives Which is why I really wanted this computer
Because it supports up to 6 hard drives and NVME SSD’s.
These are selling for dirt cheap right now because of the NEW M1 mac.
I also picked up this Intel 486 DX2-66 CPU for my IBM PS/1
Which only supports the 169-pin 486 overdrive CPU.
Reply 39262 of 59393, by brostenen
ARMSID is back in stock, so I bought one.
Reply 39263 of 59393, by assasincz
imi wrote on 2021-05-28, 13:52:
that's the second trashed presario I received in 2 months...
Man, this post is haunting me and I keep thinking about it every day ever since I saw it, it is breaking my heart, as would any Presario 460 owner...
How badly damaged was the first one?
Reply 39264 of 59393, by MMaximus
PC@LIVE wrote on 2021-05-29, 19:50:
I have done it in the past with other cards, the alternative you suggest of the external battery, instead requires the setting of the jumpers, theoretically it is simple to do, unfortunately I do not have the manual and therefore I do not know how and what are the jumpers to set.
I'm 99% sure that the ext. battery connector is the 4-pin connector next to the barrel battery, and pin marked "1" (closest to the barrel battery) is the positive. It's also likely that the 3-pin jumper block right next to the battery connector is the one responsible for enabling the external battery. You could try changing the jumper setting and see if the board remembers the CMOS settings.
Hard Disk Sounds
Reply 39265 of 59393, by brostenen
Intel486dx33 wrote on 2021-05-31, 03:02:
I think it is a cool idea, but I must ask you about power use. To me it seems like a waste of energy for something that run 24/7 and really just are a network storage. My storage server uses 2amp at 5volt.
EDIT:
And physical space.... That thing takes up a lot of space for such a trivial job. How about noise level? is it silent?
EDIT, EDIT:
This equals Woooooo.... 😳 😳 I am so happy that it is not my media server.
Reply 39266 of 59393, by Intel486dx33
brostenen wrote on 2021-05-31, 14:19:
I think it is a cool idea, but I must ask you about power use. To me it seems like a waste of energy for something that run 24/7 […]
EDIT:
EDIT, EDIT:
Well, its not on all the time and it has energy saving and sleep mode. Yes, its pretty quiet.
The fans are silent only the hard drives make noise when seeking and writing.
Yes, I am waiting for some new low power computers to come out.
Maybe the next Intel gen CPU’s
I was going to go with the intel 10700k but I them the prices went up to high and short supply on GPU’s.
So I think I will wait for Next gen Intel CPU’s which I here are suppose to have more cores.
So this Mac Pro will have to do in the mean time.
Its just for my home theater TV and NOT a NAS media server.
But I see your point.
Reply 39267 of 59393, by Miphee
Yet another quad core from Ebay, they are still cheaper in China. Wonder how long it'll last though.
Reply 39268 of 59393, by brostenen
Intel486dx33 wrote on 2021-05-31, 14:41:
Well, its not on all the time and it has energy saving and sleep mode. Yes, its pretty quiet. The fans are silent only the hard […]
EDIT:
EDIT, EDIT:
Well.... Your mac uses eighter 115 or 145 watt in idle, and my media server uses just under 10 watt when going full speed.
You can actually set more than 10 PI's up and run then full hammer, while that mac is running in idle, and still use less power.
When your mac runs full hammer, it eats up power for 26 to 30 PI's going full hammer.
Reply 39269 of 59393, by BitWrangler
I think ppl misoverestimate what typical boxes do at idle, I've had some X2 boxes on a wattmeter and they were reading 40-50, it didn't actually seem to make much difference whether it was a 45W B series or a 95W CPU for idle consumption. That was with the rust spinning too, I hate using power down on HDDs.
Reply 39270 of 59393, by liqmat
EDIT:
EDIT, EDIT:
I wouldn't apologize for it. That Mac Pro looks way fucking cooler than a shitty PI imo. Let's get real. This hobby is also majorly into aesthetics and tbh I think that Mac Pro looks better with its side panel off. Enjoy it.
Reply 39271 of 59393, by Intel486dx33
brostenen wrote on 2021-05-31, 15:47:
Well.... Your mac uses eighter 115 or 145 watt in idle, and my media server uses just under 10 watt when going full speed. You c […]
EDIT:
EDIT, EDIT:
Yeah, I have run the numbers on computer energy consumption. Its also going to be a dual purpose dual boot desktop computer/Media server. Windows/OSX operating systems.
Its a little high on energy costs but should only be in use about 8 hours a day and will be in sleep mode the rest of the time.
Reply 39272 of 59393, by brostenen
BitWrangler wrote on 2021-05-31, 15:52:
I still think that a data storage machine (no matter what type of data) is insane to set up, if it uses more than a low energy light bulp. If for instance a media center uses some 140 to 300 watt, and have a USB port, then why set up another 115 to 145 watt computer? That is like using at least 300 watt plus tv plus potential amplifier to watch a movie.
But then again. It may just be me, who want to save money on the electric bill.
Reply 39273 of 59393, by BitWrangler
Yeah I can plug a 4TB external drive in my router, I was investigating idle consumption for a PVR rig that has to be ready to go to record on time.
Reply 39274 of 59393, by brostenen
Intel486dx33 wrote on 2021-05-31, 16:05:
What is your monthly electricity bill? Mine is at 65 US Dollars total each month. (aprox 108 KW/H a month)
Reply 39275 of 59393, by brostenen
BitWrangler wrote on 2021-05-31, 16:18:
Cool.... You have build in server-services in your router. That is a nice addition. 😜
Reply 39276 of 59393, by Intel486dx33
Only the NEW Mac M1 has low energy consumption.
But I dont think these old Mac Pro’s are DEAD just yet. There is something magical about having a Mac Pro
In you home theater room. Also I think NEW energy efficient graphics cards are going to keep these old Mac Pro’s alive.
I am just waiting for the next release of CPU before I go and invest in an energy efficient system.
Also my home theater surround sound amp and speakers must use allot of energy.
We mainly use laptops and tablets and this is going to be the only desktop computer in the house.
The Mac Pro only uses about 1-to-3watts of energy in sleep mode.
Also this is a Retro home theater/game room.
Reply 39277 of 59393, by imi
assasincz wrote on 2021-05-31, 12:36:
see: Re: Bought these (retro) hardware today
not nearly as severe as this one, but still cracked all over 🙁
Reply 39278 of 59393, by brostenen
Intel486dx33 wrote on 2021-05-31, 16:36:
Only the NEW Mac M1 has low energy consumption. But I dont think these old Mac Pro’s are DEAD just yet. There is something magic […]
But your mac would be awesomme as a workstation for older software. Perhaps spice it up and you have a decent Minecraft gaming machine. It would also be good as a video editor rig and a machine that you use to keep schematics and drivers.
Indeed ARM based machines are nice for servers. Low power use.
Reply 39279 of 59393, by brostenen
Bought a NOS 64pin 251715-01 PLA chip.
