Reply 40680 of 52973, by pixelatedscraps
Damn, you guys are lucky. I have yet to come across the e-waste recycler who processes everyone’s throwaways so I’m always paying top eBay dollar for my ‘finds’.
Some very recent ones, in no particular order:
• Thinkpad A22m
• IBM PS/2 trackball mouse
• Creative CD-RW 4x2x24x Sept 1999
• Yamaha CD-RW CRW4416E 4x4x16 June 1999
My ultimate dual 440LX / Voodoo2 SLI build
Reply 40681 of 52973, by Unknown_K
liqmat wrote on 2021-10-04, 21:54:
Unknown_K wrote on 2021-10-04, 20:35:
NIB precision Instruments CARDVLB-C caching VLB IDE controller.
Nice. I archived that card over at -0° awhile back. I'd be curious if you have slightly different drivers that need archiving.
BIOS revision 2.05
Driver disk for SCO Unix 3.2, AT&T Unix 4.0 Revision 1.2
Driver disk for WFW, NT, OS/2, Netware Revision 2.07
Reply 40682 of 52973, by liqmat
Unknown_K wrote on 2021-10-05, 08:15:
BIOS revision 2.05 Driver disk for SCO Unix 3.2, AT&T Unix 4.0 Revision 1.2 Driver disk for WFW, NT, OS/2, Netware Revision 2.07 […]
BIOS revision 2.05
If you ever find time it would be great if you could image those and send them to modem7 @ VCF.
Reply 40683 of 52973, by SVD
Finally got my Quadchrome that i posted about earlier while everyone where busy discussing ozone (not the band).
As far as I have gathered it is a very rare screen even for beeing EGA so i am quite happy if it works. I have cleaned it, but it is yellowed badly. Two nice surprises tough, it came in the original box and Styrofoam, how many of these boxes are still around i wonder? 😅 Also what looked like scratches on the ebay photos where actually just glue residue that i easily removed. That where probably from one of those filters they used to put in front of the CRTs at the time.
Still wondering about painting the "beige" part industrial grey, maybe the case of my IBM 5162 too, that would look awesome with my industrial M.
Reply 40684 of 52973, by DaveJustDave
that would make sense seeing as the 5151/5153/5154 were all painted as well. I think you'd get better results and end up with a nice texture without the hassle/brittleness of retrobrite
I had this same monitor but sold mine because the tube was getting really dim and I had picked up a 5154
SVD wrote on 2021-10-05, 16:22:
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
Reply 40685 of 52973, by gex85
In the past weeks I managed to get my hand on not only one, but two Radeon HD4870X2 cards with the somewhat rare Arctic Cooling aftermarket cooler. Haven't tested them yet, though.
Now I need to get a Crossfire-capable motherboard and a 1000W power supply.
Any recommendations on motherboard/CPU combinations that would not bottleneck a quad GPU setup and is somewhat period correct and affordable?
975.71 KiB
Dual Radeon HD4870x2
My retro computers
Reply 40686 of 52973, by RandomStranger
gex85 wrote on 2021-10-06, 11:38:
I'd probably go for a Sandy Bridge/Ivy Bridge i7 or any modern CPU if your daily driver mobo is up to the task. I'd expect it's performance somewhere around (likely below due to bad scaling with CFX) the HD7970.
Reply 40687 of 52973, by sirotkaslo
sirotkaslo wrote on 2021-10-04, 09:56:
I see it's a lottery board, have to check if it has real cache.
Tested with cachechk and it seems to be functional.
Would a soundforte SF16-FMP-03 with vibra 16s be an ok sound card for this 486 machine or would I be better off getting something older and use this one in my p1 mmx PC? Can't find a lot of info about it.
Thanks
Reply 40688 of 52973, by HanJammer
Is it yellowed beyond repair? If it's not broken - do not fix it.
Reply 40689 of 52973, by pixelatedscraps
In the past weeks I managed to get my hand on not only one, but two Radeon HD4870X2 cards with the somewhat rare Arctic Cooling […]
Nice find. I’ve got on the back burner a desire to pick up a second 5970 to Crossfire in an ultimate 2009 build as well.
Would a QX9650 work and be period-correct? I’d be curious if there are any CPUs from 2007-2008 that wouldn’t bottleneck and you’d be better off aiming for a CPU from 2009, like the i7 975.
Aim for the 1000W and throw in a couple of 150GB Raptors in RAID and you’ll be flying (for 2008) 🤓
Reply 40690 of 52973, by SVD
DaveJustDave wrote on 2021-10-05, 17:07:
The tube on this one does not look dim at all from what i can see. I fired up the 5162 with an generic CHIPS EGA card and the screen goes completely dark. When it is disconnected or the computer is off i get this vertical band (same as on ebay listing). I might send it to repair, if it is not a simple fix. I have a repair shop locally here.
Can a capacitor or several of them cause this?
Reply 40691 of 52973, by Locutus
'Universal' 386/486 mainboard with EISA slot.
Looking for manual / jumper settings instruction...
1.96 MiB
Reply 40693 of 52973, by Locutus
imi wrote on 2021-10-07, 15:04:
careful, that's not EISA but a UMC proprietary local bus 😉
I'm a bit confused...
178.71 KiB
Finding 'manual' was easy...
https://stason.org/TULARC/pc/motherboards/U/U … 6-BC3486UL.html
Reply 40694 of 52973, by bjwil1991
I have a 386/486DLC board that has 2 of those slots and it's backwards compatible with ISA cards, which is nice. EISA cards won't work, sadly and finding local bus cards are hard to find.
Reply 40695 of 52973, by TheMobRules
Locutus wrote on 2021-10-07, 15:19:
They probably labeled it "EISA" since they used the same type of connector as actual EISA motherboards. Similarly, I've seen VESA Local Bus motherboards where the VLB slots are labeled "MCA" because it's the same connector used by the IBM Microchannel Bus (flipped backwards).
But that is definitely a custom local bus slot, don't insert any EISA cards there as they may get fried.
Reply 40696 of 52973, by bjwil1991
Learnt that the hard way and 1 of the cards I have burnt a trace and I patched it after that.
My board still runs without issues, but it's in storage at the moment since I installed a Jetway OPTi495SX 3/486WB Local Bus board.
Reply 40697 of 52973, by Locutus
TheMobRules wrote on 2021-10-07, 15:33:
bjwil1991 wrote on 2021-10-07, 15:38:
Thanks 4 the warning... !
Reply 40698 of 52973, by vmr_
Another super elusive specimen 😁
Guess this one was plagued by limited production quantities and pressure for Cyrix to move to higher frequency / PR ratings to attempt competing with Intel and AMD back in 97.
Will put it to the test soon.
Retro builds & sandbox
IBM XT 5160 | 286 | 386 | 486 | S4 SI5PI AIO & S4 Batman + P60 SX828
S8 & PPro 200 | SS7 FW 5VGF & Asus P5A & AOpen AX59PRO K6-III+ 550MHz
Asus K7M Athlon 1Ghz GDF | Abit SH6 Pentium III 1GHz SL4KL...
Reply 40699 of 52973, by PTherapist
Bought and received a couple of days ago, but I've been away on holiday so only got around to opening the package today.
Couldn't resist another retro Console purchase to add to my collection, I don't see these crop up for sale very often and certainly not for as good a price as I paid -
221.18 KiB
253.51 KiB
An "Adman Grandstand" branded Fairchild Channel F.
In need of a bit of a clean, but otherwise seems in full working condition.
I'm too young to have ever experienced one of these back in the day, they seem relatively obscure and hence I don't see them come up for sale very often. In fact, I wasn't even looking for one, I was looking for something else and accidentally stumbled upon an eBay listing that had 0 bidders and was ending soon. I put a bid in towards the end, fully expecting to be outbid and ended up being the only bidder. No love for the poor Fairchild Channel F it seems.
I only have the 1 cartridge at the moment and it isn't a very exciting one, so I'm keeping my eyes out for other games. In the meantime I can enjoy Pong & Tic-Tac-Toe. 🤣
