Reply 43560 of 52832, by Cuttoon
Areca ARC-1160 S-ATA RAID controller.
PCI-X with 16 channels.
At least the great aunt of all RAID controllers.
CPU is an SL9BE Intel 80331 ARM-based I/O processor.
(Had to pry the lens off my SLR to be able to read that...)
512 MB cache memory, so German, it is Swiss.
Not sure what the RJ45 on the backplate was supposed to do.
Also, rather uneventful "Prolink NVG11A" Gf2 MX-400 with Chrontel TV chip and native s-video port. Bent, but unbroken.
94.01 KiB
92.31 KiB
301.08 KiB
I like jumpers.
Reply 43561 of 52832, by ChrisK
HanJammer wrote on 2022-03-28, 20:59:
These 30-pin simm modules.
Could add these:
1.73 MiB
Of course double sided 😉
Reply 43562 of 52832, by Tetrium
ChrisK wrote on 2022-03-29, 12:30:
Could add these: IMG_20220329_142704.jpg Of course double sided ;) […]
Could add these:
and these
161.3 KiB
Most (if not all) are also double sided. Pic was taken years ago.
Of course these aren't 30p, alas 🤣
But I think HanJammer's modules are the most epic looking ones! 😜
My retro rigs (old topic)
Report spammers here!
Reply 43563 of 52832, by Radical Vision
Could add these:
Wtf one of these modules is 16MB 🤣...
Jesus insane server grade memory... Best i have seens here are EDO 72 pin 64MB, my best sticks are 32MB Siemens... And the 128MB Compaq EDO DIMM, but that is another thing, they have prob up to 512MB and maybe even 1GB per module...
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 43564 of 52832, by HanJammer
Could add these:
Yeah, I have modules like these and similar ones in both SIMM and DIMM form factor. They are pretty common. Some sitting around my desk right now:
Reply 43565 of 52832, by imi
I got these "tetris-blocks" a while ago x3... definitely the weirdest 30pin modules I have
254.63 KiB
Reply 43566 of 52832, by weedeewee
talking about 30p simms ...
yes, they're double sided
imi, time to build a tetris pc !
Do not ask Why !
Reply 43567 of 52832, by Kahenraz
I don't have any Tetris blocks to add, but I do have one of these. I feel like all of the nonsense of these huge memory "sticks" is from manufacturers trying to find clever ways to get rid of their old stock of chips. No one will ever see it inside the computer anyways, right?
168.68 KiB
Reply 43568 of 52832, by HanJammer
imi wrote on 2022-03-29, 15:25:
Nice, perfect for AWE32 too ;D
Reply 43573 of 52832, by Big Pink
99p for this Compaq motherboard from, it appears after a lot of searches, a ProLiant ML350 G2. I was kind of hoping the bottom slot was EISA but it turns out it's for the 'Feature Board'. Dual Tualatin capable! Now if I only two Tualatin CPUs. Or even one.
    421.09 KiB
    Seller's photo.
I thought IBM was born with the world
Reply 43574 of 52832, by Radical Vision
Big Pink wrote on 2022-03-29, 18:02:
Sadly that bottom slot is brown, not black and is not ISA it is clear... And you wont be able to run dual CPUs as well, unless you find the VRM module... Also if you dont have the proper Compaq PSU the board is useless... Hate that crap, my Compaq AP550 Pro came without the PSU, and is some special 20 pins + 6 pins...
Now when i did look more at that pic the VRM slots are 2 🤣... That prob means the board wont work at all unless there is one VRM installed...
Damn these modules and budget crap from OEMs...
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 43575 of 52832, by Big Pink
Yeah I know about the VRMs, although they're pretty cheap. I figured the PSU was proprietary at least in part with the extra input header.
Reply 43576 of 52832, by Solo761
Not much today, only ALS100+ ISA sound card for 486 that's on the menu to be built next.
331 KiB
Reply 43577 of 52832, by flupke11
Got 2 velociraptors, 500GB each for under 16 euro. Never knew they made them this large. I have two 74GB, two 150's and 2 300's now.
Why not start a collection 😀
Reply 43578 of 52832, by Cuttoon
Solo761 wrote on 2022-03-29, 18:33:
Dude, sorry, really nerdy nitpicking, but, you need to go for the non-plus!
The "plus" has an emulations of the FM synthesis "OPL3" integrated, while the card of that Youtube video has the "LSL262" clone of the real Yamaha YMF-262 chip.
The (original) ALS100 is pretty common and there are plenty of others to chose from:
http://www.amoretro.de/guides-workshops/opl2- … -und-nachbauten
(German, but transparent enough)
OK, sorry, that's a bit like spoiling a movie - the card will sound different, not worse. It just a conventional feature. Try it and compare some time, that's the fun of it 😉
I like jumpers.
Reply 43579 of 52832, by Kahenraz
Dell did something similar with their early Pentium 4 motherboards where they put the VRM module on a removable board. You'll definitely need to install one for anything to work. It could be very tricky to locate the correct module to use, as there may be many different kinds. It would be best to find a part number from someone who has a complete board already, to be absolutely sure.
