Reply 44100 of 53082, by bjwil1991
This'll be my second PVM.
Gotta clear out some clutter so I can get another desk for my work system and put the PVMs right next to my work laptop and connect the RGB out to my 9L1 and the audio will play through the 9L1 until I find a way to add the audio input for the 1341 so the one can have the left channel and the other the right channel (technically stereo, but 2 separate speakers).
Either that or install external speakers that are shielded.
That and it'll be the first PVM I'll have that supports both analog and digital RGB. Which will be awesome for my CGA and EGA computers, and if I get a Tandy computer or a Platronics system, it'll be perfect as well.
Reply 44101 of 53082, by Shponglefan
bjwil1991 wrote on 2022-04-23, 16:49:
Hope this thing gets packed like a tank and doesn't fall apart on me like the last PVM.
See if they can encase it in rigid foam, and then box-in-box.
I had a monitor shipped that way not too long ago and it looked like it could have survived almost anything.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 44102 of 53082, by PD2JK
I was looking for a V1, then this 6MB Miro came up. The extra memory is not very useful in practice, but it looks cool... I am having a chipset heatsink laying around from an old 440BX board, maybe it will fit on the TMU.
And I will have to fix me a VGA cable with a 9 pin mini-DIN connector.
    1.53 MiB
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 44104 of 53082, by Gmlb256
Kahenraz wrote on 2022-04-23, 20:42:
Supposedly there are some games like POD that have graphical glitches when there is too much VRAM or something with 3dfx accelerators.
For early 3Dfx cards this could be dealth by adding SST_TMUMEM_SIZE=2 environment variable, thus allowing Glide games having issues to work fine.
Reply 44105 of 53082, by HanJammer
A s**tload of NOS accessories for AT/XT clone cases and XT-class motherboards... Not really "bought" - more like I received them for free. Those are some left-overs from a company which build and serviced PCs in the late 80s/early 90s in Poland. I also got a NOS amber MDA/Hercules monitor in the same bunch but I will show it some other time.
Reply 44106 of 53082, by HanJammer
Also this screen filter... I hated them 😁
Reply 44107 of 53082, by Brawndo
GigAHerZ wrote on 2022-04-23, 14:45:
Got this!
External SCSI SyQuest 230MB 3.5" drive. Full set, will archive the floppies unless they are already archived.
For whatever reason, it also seems to include coincidentally 230MB MO disk. I have an internal 650MB MO drive - i wonder, if it would work with that?
Wow, I actually (very vaguely) remember those Syquest drives from way back. Never had one though, it was one of those boutique peripherals I couldn't afford, like Zip and Jaz drives, but I did end up getting an Orb SCSI drive later on. Back when 2 GB on a removable disk was mind blowing, 🤣.
Reply 44108 of 53082, by PC Hoarder Patrol
...it also seems to include coincidentally 230MB MO disk. I have an internal 650MB MO drive - i wonder, if it would work with that?
Don't think so, unless you meant 640MB then yes the smaller capacity MO disks should work in the larger capacity MO drives
Reply 44109 of 53082, by PD2JK
Those MO drives are sleek and superior, I owned a Fujitsu internal SCSI drive with one Sony 230MB MO-disc. Same tech as MiniDisc of course, but too expensive to be successful. MiniDisc as a music system did not fail if you ask me. I still regret I sold my Sony MZ-RH1, how stupid could I be.
*dies in a corner
Reply 44110 of 53082, by GigAHerZ
PC Hoarder Patrol wrote on 2022-04-24, 06:47:
Based on Wiki, the MO disks were 650MB as it seems: https://en.wikipedia.org/wiki/Magneto-optical_drive
But thanks for confirmation! Now i have at least one disk per every "interesting" drive i have: SyQuest 3,5", MO 3,5", LS-120, ZIP 100 (i have 250 disk as well, but no drive).
Will be fun to try them all out 😀
Reply 44111 of 53082, by fosterwj03
I bought this Radeon 9250 DDR 256MB PCI card this week in my search for a really good PCI or PCIe graphics card fully compatible with Windows 95 and my Core i5-3570 overkill system. I wanted something that handles DirectX 8.0 and widescreen resolutions (up to 1080p). The card arrived in good condition, but the cooling fan won’t spin on its own, unfortunately.
It took a lot of trial and error, but I finally found a driver that recognized the card in Windows 95 (both Retail and OSR2): ATI Catalyst 3.7 for Windows 9x. While this driver only addresses 128MB of the card’s 256MB of VRAM, it does at least accelerate Windows 2D and 3D without crashing and it provides widescreen resolutions. The driver is meant for Windows 98 and Me, so it throws up a USER32.DLL error at boot-up. Otherwise, the driver seems to work properly.
The card gives me a solid 60 FPS in Thief 2 at 1280x1024 and runs Unreal Tournament smoothly even at 1080p. I also got a score of 6349 in 3DMark 2000 at default settings. Not too shabby for an entry-level PCI card of the era.
If I had one complaint, it’s that the Cat 3.7 driver has OpenGL support somewhere between awful and non-existent. Some games like Jedi Knight 2 and Return to Castle Wolfenstein refuse to start while MDK 2 runs at 5 FPS. This doesn’t happen when I test the card in Windows 98 with newer drivers, so it must be an issue with Windows 95, OpenGL, and/or the older driver.
Reply 44112 of 53082, by BitWrangler
I don't know if there's some super bad config of 9200 and 9250, but I noticed before in Notebook review benchmark tables the mobile versions frequently get hammered by the previous 7500s, 7000s, and the following x200 x300 mobile versions which nobody rates huge anyway. Real bad scores in some games, don't know if it's curable by driver selection, better BIOS, registry tweaks, or what.
Reply 44113 of 53082, by HanJammer
This time almost new TSENG ET1000 and interesting AST video card found in the heap of my usual 'trash' supplier...
Reply 44114 of 53082, by debs3759
HanJammer wrote on 2022-04-24, 22:35:
Any chance you could scan that ET1000 manual? I have the same model (it's made by DFI, not Addonics, they just put their branding on it).
Reply 44115 of 53082, by HanJammer
debs3759 wrote on 2022-04-24, 22:51:
Yeah, I will.
Reply 44116 of 53082, by AngryByDefault
Made an offer on a PVM-1341 that has composite, s-video (Y/C), analog RGB, and Digital RGB. No audio in for the RGB line and tha […]
Made an offer on a PVM-1341 that has composite, s-video (Y/C), analog RGB, and Digital RGB. No audio in for the RGB line and that can be arranged easily by installing a 3.5mm jack and only have mono audio directly to the amp. There might be a mod for that, however. The Sony emblem is missing and I might be able to find one somewhere.
Seller's photos:
Nice!
Weren't those meant to be used in video production back in the day?
Reply 44117 of 53082, by AngryByDefault
Got this pack yesterday.
The ad had some low quality pics with somewhat dusty parts and a title reading "Assortment of retro cards in unknown condition"; deatils listing "Two old sound blasters, a video card, some pentium processors and memory sticks, and three networks cards of unknown speed"...
You could spot a SB Live, an ISA sound card and at least two 256 MB SDRAM sticks which I happen to need ATM, so I decided to take my chances.
None of these will be mind-blowing but I think I still got a nice deal...
While the "network cards" where actually PCI and AMR *modems* and two of the processors got busted in shipping, I had no particular interest in those and I did get all (preliminary) working SDRAMS, a CT4380 Live! and a working ¿"SB 16"? CT2940 with OPL chip.
The micros are some low to modest 478 and 775 models I suppose?... I didn't look too much onto them.
Celeron D 336 2.88 GHz
Celeron 430 1.8 GHz
Pentium 4 631 3.0 GHz
Pentium D 915 2.8 GHz
Oh, and there's an MX440 wich will be handy as I just discovered the one I´ve been saving *for years* is artifacting on me (darn it!).
I paid for the whole pack what you could expect to pay here for a reasonably priced "SB Live!" or for both 256MB sticks alone. This doesn´t happen often to me 😀
1.12 MiB
retro-pack
Reply 44118 of 53082, by Cuttoon
AngryByDefault wrote on 2022-04-25, 00:47:
That is indeed a really good SB16 model. It has the Vibra Pro chip, is very low noise but comes with that relatively rare, square low-power OPL3 - many did not and relied on shitty emulation.
The IDE port and amplifier are also there. Others look like this:
https://upload.wikimedia.org/wikipedia/common … SB16-CT2940.JPG
So, nice catch!
I like jumpers.
Reply 44119 of 53082, by Cuttoon
Price of a beer, most expensive Pentium 133 I bought since 1997.
Ebay picture looks almost black and some others on the web look black and this one looks at least darker than many.
Were those differences batches, different production facilities or did they simply rip open a different shade of clay that day?
311.5 KiB
455.56 KiB
Ideal chip to test S7 boards - passive cooling, easy to handle, no heatsink attachment needed.
But still, I'm wondering if I could get that heatsink off. Pretty sure, but without scratches all over it? Any tricks?
I like jumpers.
