Reply 45240 of 52813, by debs3759
- Oldbie
TrashPanda wrote on 2022-06-18, 04:52:HanJammer wrote on 2022-06-17, 23:36:debs3759 wrote on 2022-06-17, 23:32:Or close all your windows and enjoy the high 😀
Better not, some air dusters are pretty toxic and inhaled in large quantities can cause brain damage and neurological problems... 🙁
What happened to Gordo in "Halt and Catch Fire" is a serious threat to any guys doing some more serious work with electronics (yet I can't get used to using proper filters when soldering)...I dont know how it is elsewhere in the world but the most common propellants here are Propane and CO2, with CO2 mainly used for Foodstuffs and Propane used for most other aerosols, air dusters are the exception as laws here made the manufacturers change what they were using so you cant get high from them. (They can still kill you but you sure as fuck wont be high doing it)
Air Dusters here are either propane or butane. They don't say which, but it is highly flammable. I was refilling a lighter with butane one time (from a cheap lighter refill can, not an air duster) and it gave out a spark, and ignited! I was fortunate that the can didn't explode, the flame died when I removed from the lighter.
