Reply 45600 of 52813, by LewisRaz
bofh.fromhell wrote on 2022-07-15, 14:03:
It looks dirty and corroded. A thorough clean and dousing in contact cleaner might help. And whats that mess in the CPU socket? […]
LewisRaz wrote on 2022-07-15, 13:53:
Picked up this 486 motherboard from ebay. Its not on ultimateretro.net. […]
Dated March 97!
Most of the basic jumper settings are silk screened on but I still cant get any cpu to boot with it and cant find the settings for the remaining jumpers.
Anyone able to find anything? Its an ALD PCI 5433
And whats that mess in the CPU socket? =)
2 tantalums and 2 electrolytics sharing the same pads?
Its filthy but not correded anywhere. Postcard is showing all the voltages are right just getting a braindead ---- which is indicative of the cpu being set up wrong 😀
And yes, they are sharing the same pads, and it doesnt look like its been messed with. What a madness 😁
My retro pc youtube channel
Twitter
Reply 45601 of 52813, by chrismeyer6
LewisRaz wrote on 2022-07-15, 14:14:
Dated March 97!
Do you have a bios battery installed? There are quite a few motherboards that will either act dead or behave weirdly with a missing,dead,or low bios battery.
Reply 45602 of 52813, by LewisRaz
chrismeyer6 wrote on 2022-07-15, 14:52:
Yes, battery installed 😀
Twitter
Reply 45603 of 52813, by chrismeyer6
LewisRaz wrote on 2022-07-15, 15:00:
Good I've seen that trip up people in the past. It's gotten me more times than I care to admit.
Have you tried different CPUs and ram?
Reply 45604 of 52813, by LewisRaz
chrismeyer6 wrote on 2022-07-15, 15:02:
Ive tried 3-4 different combos of ram. (all known working)
Ive tried all the 33mhz CPUs I have (You can see the board was previously set for 33mhz @3.3v) including:
amd dx4
amd 5x86
intel dx2 @ 5v
Twitter
Reply 45605 of 52813, by cyclone3d
TrashPanda wrote on 2022-07-15, 12:14:
The ASUS P2B-D Rev 1.06 D03 Arrived today and once I give it a quick test run Ill be doing the mod detailed here Asus P2B-DS Rev 1.06 FSB Modification to it. Got a nice pair of PIII 667 CPUs for it along with a Voodoo5 5500, should be a fun Win2k/XP system.
Would have loved the SCSI version but the non SCSI board is pretty rare and the SCSI version even more so, anyone have a good recommended PCI SCSI card to pair with this board?. (I guess Sata Raid is also and option with a pair of Velociraptors or SSD)
Will do a bigger write up of the build when I get it modded and setup.
No real reason for SCSI or RAID. Since you are using 2k/XP, just get a SATA II, 300 card and use an SSD. Going to be faster than SCSI or spinning rust RAID.
You'll still be limited by the PCI bus, so probably around 120MB/s but of course the seek times will be almost non-existent so it will be fine.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 45606 of 52813, by BitWrangler
Hmmm, how many ports can you get on a PCI SATA RAID card? 'coz for older machines you could just collect up cheap/free small SSDs and glom them together in 0 or JBOD
Reply 45607 of 52813, by RandomStranger
I got myself a GTS450 1GB GDDR5 for my XP rig. I always found this card weirdly alluring for some reason.
1.66 MiB
So far it's running, the drivers (version 296.10) are installed 47-48C° idle which is very nice compared to the 8800GT. It's supposed to have 30% lower TDP while 25% more performance, so I gain back as much if not more more than I lost by downgrading from the 8800 Ultra. The GTS450 also has a VGA output so I can use it without a DVI adapter with my KVM switch or a CRT. On the downside, my XP rig is no longer period correct.
1.28 MiB
1.54 MiB
So this weekend I'll be testing if it has any issues. I'll be also curious about the temps under load. With the 8800GT I needed very aggressive fan control to keep it below 80C° which made it very noisy. The card also supposed to be a good overclocker. I have no plans for OC, but it's good to know.
Reply 45608 of 52813, by TrashPanda
BitWrangler wrote on 2022-07-15, 15:51:
I think I can get a 4 port card for Sata, its limited by the PCI bus and if you use all 4 ports its even more limited for RAID purposes, I do wonder if using two cards would work to spread the bandwidth around a bit then use 2K to setup a raid via Windows rather than using hardware Raid. The idea is growing on me as I have a bunch of 60gb SSD drives in the spares box .. at 60gb they are not useful for modern systems but strung together in software raid they would be perfectly fine for 2K/XP.
The board has plenty of PCI slots free since there wont be anything using them.
Reply 45609 of 52813, by chrismeyer6
TrashPanda wrote on 2022-07-15, 16:45:
That's an interesting thought and would probably be worth testing out and seeing what the benchmarks show and how the systems performance feels overall.
Reply 45612 of 52813, by myrsnipe
On my way to pickup a fresh in box Fujitsu Siemens C700 17" CRT. You guys in the state probably won't understand but finding something like this in a small country like Norway is next to impossible, need to go on eBay for something like this and pay a ton of shipping.
Reply 45614 of 52813, by RandomStranger
myrsnipe wrote on 2022-07-16, 08:00:
What did Norway do with all their CRTs? It's not just in the states, but in most countries generic CRTs are mostly given away for free or their price is something like 15€ at worst unless they are some super nice high refresh rate 1600×1200 monitors.
Reply 45615 of 52813, by imi
RandomStranger wrote on 2022-07-16, 09:14:
just like most countries most of them got probably thrown away into a landfill or empty warehouse somewhere in big piles... it's a shame 🙁
probably shipped on to some poorer countries to make it "their problem".
Reply 45616 of 52813, by myrsnipe
Speaking of throwing away, when i picked up the crt the guy told me he had thrown away 100kg of old 90s computers this week while cleaning, only stopping at the crt because it was still in its box. My heart sank a little, but he gave me a goody bag of Pentium 2,3, Celeron and some AMD CPUs as a freebie as well as some ram sticks that he had missed.
    895.37 KiB
    Still in the box
Reply 45617 of 52813, by RandomStranger
myrsnipe wrote on 2022-07-16, 13:41:
Sort of happened to me too. A friend of mine, or more like a good acquaintance told me a couple of months ago he used to fix PCs as a side gig and his basement was full of 90s hardware. Key word is was. The previous year he threw away everything. I almost cried.
Reply 45618 of 52813, by iPonRMA
Dated March 97!
In our shop we was sold many of this motherboard. Unfortunately i didnt have any of this yet. As i remember it was quite unstable low cost motherboard. Often suffered from BIOS corruption, we had spare EPROM ICs containt the BIOS dump. As i remember this one wasnt a fast thing, the Octek DCA2 was way faster, but maybe we did not check it enough, the Celeron 300A overclock to 504 or more was more interesting at that time. I suggest to check that board with Intel 486DX50 CPU (not the DX2 one) if possible, if not, AMD 486DX40 with POST card in ISA slot - if you have. FPM memory also recommended instead of EDO.
Reply 45619 of 52813, by MarkP
Picked up an NComputing thingy which allows anther user login to an XP system being used by another user with different monitor, keyboard and mouse.. Haven't currently got an XP boxen set up at the moment.
ALso picked up a beige two port KVM switch to connect a couple of Ye Olde 486DSX2/66 systems to a single monitor, keyboard and mouse. One of the 486s has OS/3 v3 on it and one a primarily Dos testing set up with WfW 3.11, and various PC Geos version installations as well as other goodies on it.
    238.53 KiB
    233.12 KiB
