Reply 45860 of 52811, by TheAbandonwareGuy
TrashPanda wrote on 2022-08-07, 02:38:
Meatball wrote on 2022-08-07, 02:35:
TrashPanda wrote on 2022-08-07, 02:28:
Here its nothing but flat open scrub land leading into a vegetated desert (Aussie deserts are weird till you get to the center of OZ).
Im glad I dont have to deal with humidity, spent a few weeks up in the tropics of Australia and the humidity nearly killed me, Ill take dry heat any day of the year. (Dry heat is also great for storing retro parts)
I don't like the humidity, either, but when we went vacationing in Nevada and Arizona, we couldn't stand the dry heat; it was very hard to breath. Thank God for A/C is all I have to say.
Hard to breathe, hmmm I guess if your lungs had adapted to living in moist environment better suited to a fish I could understand that 🤣.
Humidity is hard on retro components though, but as long as they are stored with silica gel packets or in a controlled environment I can see them holding up well for a while.
This causes me constant concern, most of my machines are stored outside in a garage that is used and isn't climate controlled, I'm sure the humidity nears 100 percent in there some days. The floor gets moist on the worst days, but I try to keep my components up higher. I haven't seen anything fail yet, but I keep meaning to go pull all the graphics cards and move them in doors, since those seem to be the main thing going up in price.
I don't really have any better options, unfortunately. I don't own the place and this is the space I'm alotted.
Reply 45861 of 52811, by TrashPanda
TheAbandonwareGuy wrote on 2022-08-07, 05:16:
if you can get some silica gel packets or beads you can throw them in with the GPUs and teh silica will absorb the moisture, no idea how long they last but it should be quite a while inside of a anti-static bag.
Reply 45863 of 52811, by chrismeyer6
Have you tired the Damp Rid buckets? I've used them in the past and they work quite well. A proper dehumidifier would be best but the buckets are cheap and do a decent job.
Reply 45864 of 52811, by DerBaum
Today some free stuff popped up on the selling site i frequently look through for pc parts.
The parts were located in the town next to where i live, so i picked everything up as fast as possible.
This weird and chonky aftermarket cooler for a graphics card...
1.16 MiB
And a Mainboard.
1.97 MiB
Seller told me the BIOS is broken because it doesnt save settings anymore...
Of course i have not told him that the Battery is inside the replacable Odin chip and its a easy fix. 😀
It came with a Pentium 166 (without MMX) but in the newer cost reduced package. Thats neat.
I think the board does not support MMX. Probably something to hang on the wall.
FCKGW-RHQQ2
Reply 45865 of 52811, by bearking
Flea market finds
638.9 KiB
677.94 KiB
Nothing impressive, but still nice to find boards like these. Specially for 10 usd/eur for both.
Also bought a 12 Mb Voodoo2, PowerColor branded for 33 usd/eur this week. The card is missing it's bracket, but it's working!
1.53 MiB
1.39 MiB
Reply 45866 of 52811, by devius
DerBaum wrote on 2022-08-07, 12:11:
It does support MMX. You can see one of the jumper settings tables mentions P55C.
Reply 45867 of 52811, by Meatball
Today some free stuff popped up on the selling site i frequently look through for pc parts. The parts were located in the town n […]
And a Mainboard.
I got rid of a perfect working Pentium board the same way just a few years ago. It had solder points for a coin battery, and I thought it was a factory mistake or something. It never occurred to me batteries could be elsewhere (in my case the Dallas chip). Oy....
Nice find, and you can't beat the price!
Reply 45868 of 52811, by DerBaum
devius wrote on 2022-08-07, 14:02:
JP4 should be below the CPU socket. But its not populated and some components around the jumpers are missing...
The manual mentions a later revision to have MMX support... but not this REV.: 1.52 one.
I was also looking for JP1 JP2 and JP3 to set FSB and multi... But if it has the Switch block the Jumpers are not populated.
Its a weird board. 🤷‍♂️
FCKGW-RHQQ2
Reply 45869 of 52811, by chrismeyer6
And a Mainboard.
That cooler was quite common back in the day. The ATI and Nvidia stock coolers left alot to be desired especially the ATI ones. It was relatively quiet and did a great job cooling.
Reply 45870 of 52811, by TheAbandonwareGuy
chrismeyer6 wrote on 2022-08-07, 17:31:
And a Mainboard.
Did they make a version of that which fits the 9600 Pro? I've got a working 9600 Pro that lost its cooler at some point.
Reply 45871 of 52811, by Repo Man11
bearking wrote on 2022-08-07, 12:40:
Flea market finds 20220806_131453.jpg 20220806_131532.jpg Nothing impressive, but still nice to find boards like these. Speciall […]
Flea market finds
Synchronicity: I have a Lian Li case that has a sticker on the inside indicating that it once had an A7N8X in it, and it now has a P4P800 in it.
Reply 45872 of 52811, by devius
DerBaum wrote on 2022-08-07, 14:52:
Oh, that's unfortunate 😬
Reply 45873 of 52811, by chrismeyer6
TheAbandonwareGuy wrote on 2022-08-07, 17:45:
And a Mainboard.
I'm almost positive they did make one to fit the ATI 9600,9700,9800
Reply 45874 of 52811, by Radical Vision
And a Mainboard.
How nice when someone give away free stuff, but they are also brands, socket 7 GIGAbyte is nice. Ofc when they give me parts for free last thing is to brag, how the stuff are not what i want... But anyway is nice you could have gotten noname socket 7, u got instead GIGAbyte very nice. No Dual BIOS 🤣... And yes the battery is ezz fix, i did similar thing, when a guy wanted to give me his socket 3 mobo, since it did have leaked battery, and his keyboard was not working, but i found that the mobo is more then fine...
1.44 MiB
Flea market finds
If i was on ur place, id go and straight sell these crap ASUS boards, and they just die for no reason, ABIT, GIGAbyte, SOYO, SOLTEK, MSI, AOpen and others are better in terms of reliability then the shitty ASUS...
Hate when some moron removes the bracket, i have lot of I/O shields, brackets and other spare parts from many dead stuff over the years, YET non of them was compatible with missing Voodoo II bracket ffs...
Also it makes me wonder why the hell someone did bother to install 1 heatsink, but not 2 more, on the rest chips, it makes no sense. Unless he did have only 1 heatsink, but then why to bother installing 1, since the rest chips will cook themselves...
For example look at this shit that Voodoo, 2 of them only 1 have 1 heatsink + fan on 1 of the chips, and what about the other chip 🤣.... When they do something to do it at least the right way, when installing extra cooling, install on the second damn chip as well, he want to be cooled as well, or dont bother to do anything... Imagine if Voodoo 5 5500 did come with only 1 heatsink on it, and the other chip to be naked, what BS that would be...
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 45875 of 52811, by SrFenix
Radical Vision wrote on 2022-08-07, 20:59:
How nice when someone give away free stuff, but they are also brands, socket 7 GIGAbyte is nice. Ofc when they give me parts for […]
And a Mainboard.
Flea market finds
why are you always so unpleasant, and always underestimating, this is shit, that is worth nothing, I don't understand your way of seeing things.
Reply 45876 of 52811, by TrashPanda
SrFenix wrote on 2022-08-07, 21:32:
And a Mainboard.
Flea market finds
You get used to ignoring their posts, I have them on ignore because I just dont like their attitude or conduct, so rather than complain about it or respond I just hit the mute option and move on, always remember people are free to have their own opinions and we are free to ignore said opinions.
Thsi is not intended as a hate post or anything of the sort, just some simple advice.
Reply 45877 of 52811, by Meatball
TrashPanda wrote on 2022-08-07, 23:00:
What I want to know is how does Radical Vision get Voodoo 6000's for a nickel + "shitting?" I know he's done it, but hasn't let us know as of yet, haha...
Reply 45878 of 52811, by appiah4
OK, so is this something worth buying? I'm guessing it's an 8-bit monochrome video card for XT class PCs or something? I have neither any XTs nor monochrome monitors, but I'll grab it if it's valuable 🤣.
Reply 45879 of 52811, by Kahenraz
I have heard of Easter eggs in some games if you hook up a secondary monochrome monitor. For example, you get some kind of information readout in Mech Warrior 2.
The reason this works is because the memory area reserved for monochrome output is mapped separately from VGA, so you get kind of a primitive form of dual monitor support, but only for software that is written specifically to take advantage of it.
