Reply 45960 of 52822, by Ydee
- Oldbie
Meatball wrote on 2022-08-14, 14:00:Ydee wrote on 2022-08-14, 07:02:Meatball wrote on 2022-08-14, 00:15:I recently snapped up this Montego II Quadzilla (Vortex 2) still sealed. The wrap is pretty loose, though. I'm curious to see all that's inside, but I don't know if I'll open it.
Nice shot, but I don't think it's originally packaged - it seems to me that the box has chipped corners and has been wrapped in foil as an afterthought.
It's understandable to suggest since I wasn't clear with my wording.
It's original, the wrap is loose because it has a T-split and rip at the entire seam of the bottom, and the entire length of the box has somewhere between minor and middling concave crush damage. It has the same consistency as the wrap of the box on the right and the corners are tight. It's because of the size of the split and the big chunk missing off of the front which makes me think I might as well open it. Then I can straighten out the box (crushed boxes bother me to no end...)
Ah, it's clearly visible now from this angle that it's an original foil. Thanks for the clarification.
