Reply 47520 of 52969, by TheAbandonwareGuy
Radical Vision wrote on 2023-01-06, 17:09:
Got this ThinkPad T60 from trade (did give Cougar Speed mice pad).. It is with ATi Radeon x1400 and artifacts bonus..
Will gun down that crap artifacts with the heat gun, and see if will help... If not will use what i can to try to fix my 14 inch T60... Seems so far i have multiple laptops, and non is compatible with the other ffs... That being ThinkPad R60, T60 14", T61, T60 15"...
I can't recall if the X1400 is one of the models that uses system ram to supplement a small amount of onboard VRAM, but if it is try changing your memory out first.
Reply 47521 of 52969, by BitWrangler
Is T60 one of the ones you can get upgrade motherboards for if you are so inclined? So there's etiher that option, or maybe larger than normal availability of take-out motherboards.
Reply 47522 of 52969, by TrashPanda
Grabbed this little gem of a Cyrix CPU today, its a gold top Cyrix MIIv GP400 95Mhz bus @ 2.2v, going to add it to my socket 7 test bench, not everyday you see one of these so its a nice late Xmas present !
    284.97 KiB
    Seller Photo
Reply 47523 of 52969, by RetroPC_King
Today's find is a GIGABYTE GA-M61PME-S2 motherboard (without I/O shield) with 2x 2GB Mushkin Enhanced DDR2-800 in dual channel (it have heat spreaders) and a AMD Athlon 64 X2 3800+ Windsor CPU (part number ADA3800IAA5CU) with a Spire CPU Cooler. This kit I got it mostly for the CPU that will go into my forthcoming 2006 ASUS M2N-E rig. Any opinions?
    1.64 MiB
Reply 47524 of 52969, by BitWrangler
TrashPanda wrote on 2023-01-07, 06:42:
Nice! Yah those don't come up every day. I'm a little jelly. Enjoy.
Reply 47525 of 52969, by TrashPanda
BitWrangler wrote on 2023-01-07, 15:36:
I’m curious to find out if it can run at 100 fsb without needing to increase the voltage.
Reply 47526 of 52969, by vellu
got myself Olivetti PCS 33 (386SX) in good condition. I'll transfer the files from the harddrive before it dies and then reinstall dos and add a soundcard. I could go with SB16 (CT2800) from '95 or ESS1868 AudioDrive from '97.
    532.3 KiB
    1.58 MiB
retro rack
Reply 47527 of 52969, by TrashPanda
vellu wrote on 2023-01-07, 18:06:
For a 386 the SB16 does seem a better fit but ESFM is also really good but I think the Sb16 would have much better compatibility with the era of games a 386SX is able to handle.
A Soundblaster Pro 2.0 would be an even better fit for a 386SX but they can be rather expensive and hard to source.
Reply 47528 of 52969, by pentiumspeed
libby wrote on 2023-01-05, 09:18:
pentiumspeed wrote on 2023-01-04, 22:17:
That intel copper heatsink is spendy still on ebay.
Cheers,
I think that's because it weighs like 1.5 pounds and is pure copper, so the metal alone is worth a good $7 nowadays and people have long since recycled almost all of them.
More like 60 to 80 per purchase on ebay for intel server copper heatsink, so not about the recycling for copper value.
Great Northern aka Canada.
Reply 47530 of 52969, by BitWrangler
TrashPanda wrote on 2023-01-07, 15:54:
I'll cross my fingers for you, I do remember some others being super frigging stubborn about going over 290... not sure what kind of wall that is, the process goes past there in theory.
Reply 47531 of 52969, by vellu
TrashPanda wrote on 2023-01-07, 20:42:
it certainly hurts the wallet to go period correct with this one. I might go SB16 because it has the OPL but I'm also curious to hear what ESS can do.
retro rack
Reply 47532 of 52969, by Ydee
Very nice set, congrats!
Reply 47533 of 52969, by TrashPanda
vellu wrote on 2023-01-08, 07:33:
ESSFM when used correctly sounds amazing, sadly there are few games that implemented it correctly and the ones that do likely won’t run on a 386sx.
The SB16 has the compatibility win here.
Reply 47534 of 52969, by Grzyb
TrashPanda wrote on 2023-01-08, 10:41:
In theory...
In practice, with 386SX software, it's usually OPL3 vs. ESFM in OPL3 mode (I'm unable to tell it apart from genuine OPL3), and SB Pro DAC in mono vs. SB Pro DAC in stereo.
Also, the MIDI interface on CT2800 is known to be buggy.
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 47535 of 52969, by Gmlb256
Grzyb wrote on 2023-01-08, 12:00:
The differences are noticeable with trackers made for OPL3, games barely used the additional capabilities as developers didn't have the proper talent to get the most of it.
SBPro compatibility is completely overblown IMO, it is actually with few early games (Wolfenstein 3-D doesn't count as it really uses the mixer to get that stereo immersion) that many people are unable to name and Future Crew demoscene stuff which never supported the SB16. Some non-Vibra models of the SB16 has the CSP chip which is useful on slower computers like the 386SX when running Windows.
To be fair though, the ESS sound card doesn't have the single-cycle DMA clicking bug that non-Vibra SB16 has and comes with a bugfree UART MPU-401 implementation (this was never used back then due to MIDI devices being horrendously expensive for a regular consumer).
Reply 47536 of 52969, by TheAbandonwareGuy
Bought a Gainward GeForce2 TI 64MB for $21.
Now the only GF2 I'm missing is the GF2 Pro
Reply 47537 of 52969, by BitWrangler
Thrift bits nothing great, but got a Toshiba laptop/monitor supply that puts out a whopping great 6.3 amps so ready for anything now... gonna try that Goldstar 386 clamshell again and if really really no life, gotta dig into internal power board.
Reply 47538 of 52969, by Ozzuneoj
Pretty pleased about this one since I haven't found any rare sound cards in a long time. I have never seen one of these before and only found a handful of references to it online after looking it up tonight:
360.36 KiB
(seller's photo)
Apparently this is called a Media Vision Pro Audio Wavetable with an ID of IXW-JAZZWAVE. It is a Media Vision Jazz16, OPL3 and an ICS Wavefront wavetable synth.
I seem to have gathered a decent amount of interesting Media Vision hardware over the years, so this will be a nice addition.
So far I have managed to find:
Thunderboard (with disks)
Pro Audio Spectrum Plus (falls between original PAS and PAS16)
Several PAS16 and Jazz16 variants
Memphis (card, cable and multimedia speaker system\monitor stand with working SCSI CDROM drive)
Logitech Soundman
Logitech Soundman Wave (with manual and disks I think)
The PAS Plus was probably my least common card before, but I think this Pro Audio Wavetable would be the least common one of my collection now, since it isn't mentioned on any of the usual sources for Media Vision devices.
... still have yet to track down that elusive original Pro Audio Spectrum though. 😀
Reply 47539 of 52969, by JidaiGeki
Ozzuneoj wrote on 2023-01-09, 06:31:
Pretty pleased about this one since I haven't found any rare sound cards in a long time. I have never seen one of these before a […]
(seller's photo)
Logitech Soundman
Nice one! The MV Jazz Wave (aka MediaVision PAW-200 Pro Audio) looks like a pretty complete sound card, would be interesting to see how wavetable sounds.
However, the driver for the wavetable might be hard to find - the DOS Reloaded guys were looking for it (https://dosreloaded.de/forum/index.php?thread … -1995/&pageNo=3). From magazine reviews, the driver file seems to be called "MVLITE.EXE" (https://archive.org/details/Pcmania36/page/n43/mode/2up and https://archive.org/details/PC-Player-German- … de/2up?q=mvlite). I've got one of these without the backplate, but haven't been able to start the wavetable. Been on the lookout for random MediaVision floppies but nothing so far.
And coincidentally this arrived at mine today ...
1.52 MiB
