Reply 47820 of 52973, by HanJammer
Warlord wrote on 2023-01-29, 04:00:
its too bad its not 1 drive letter.
It wouldn't be possible to switch discs without additional software (would be a nightmare installing it for every possible OS and SCSI enabled machine) or controls on the drive itself (so again not that different from manually replacing the discs).
Reply 47821 of 52973, by H3nrik V!
Heavily inspired by this thread: Best 100mhz FSB Processor? (that I currently own!)
I had to buy it, when I stumbled upon a 1.1 Coppermine P!!!
Especially since I already owned one - and an Asus P2B-DS 😁
Reply 47822 of 52973, by Pawlicker
Got this in the mail last week and fixed it. It's a NEC PC-9801es. It's just a normal 386...except it has a V30 too and can run classic point and click adventure games like Yu-No. Luckily it still works despite battery leakage and I had to build a homemade PSU adapter. I mainly bought this to drive a rare sound card, I need to unstick the floppy drives as the heads sound jammed and won't boot from disks. I also need to install a SCSI board but I have plenty.
621.9 KiB
1.01 MiB
246.1 KiB
344.12 KiB
313.74 KiB
Reply 47823 of 52973, by debs3759
Looks more like an XT class (with the V30 on the motherboard) with a 386 upgrade board (the 386 being added on top of the MoBo). Not a regular 386 with an added V30 😀
Nice, whichever way you look at it 😀
Reply 47824 of 52973, by dj_pirtu
TrashPanda wrote on 2023-01-29, 06:51:
Athlon XP-M 3000, been looking out for one of these to throw into my Abit NF7-S box but they don't show up on the bay very often and are usually priced stupidly high, this one was pretty reasonable. IIRC these are unlocked out of the box so it should make for a fun little overclocker.
Athlon XP-M CPUs are great with Abit KT7A, you can build an epic all-arounder because that mobo has that one ISA-slot... You can change mobile-Athlon multiplier from DOS (setmul.exe) or from Windows freely.
Reply 47825 of 52973, by TrashPanda
dj_pirtu wrote on 2023-01-30, 09:00:
Heh, I have a lot of options for ISA, including a Slot A Athlon, if I run across a KT7A that doesn't need recapping at a nice price Ill be sure to pick one up but most of the ones I see require new caps which means more work that I don't have free time for.
Reply 47827 of 52973, by Tetrium
LewisRaz wrote on 2023-01-28, 10:42:
7600GS AGP. Not sure what system I will build with it but could not pass it up for £10
If it works, that's a good deal for such a card.
I have 2 GF7600GS AGP cards, one by MSI and the other may be this exact one.
I'd advice to keep a close eye on temps, I ended up adding case fans juryrigged to the heatsinks in order to keep them cool, after which they worked fine for years.
My first one first ended up in my AthlonXP 3200+ rig and the second ended up in an A64 AGP rig.
But do consider adding active cooling in some form, or at least consider it.
My retro rigs (old topic)
Report spammers here!
Reply 47828 of 52973, by Tetrium
pete8475 wrote on 2023-01-28, 14:53:
SrFenix wrote on 2023-01-28, 14:32:
I bought a pc for €20, and I found this inside, not bad, it's not retro but it's pretty good hardware. The plate did not start a […]
I bought a pc for €20, and I found this inside, not bad, it's not retro but it's pretty good hardware. The plate did not start and after a wash it works perfectly.
I would throw the OCZ ram directly into the trash where it belongs. Otherwise good stuff.
Why throw the OCZ memory away?
If it works perfectly fine, then throwing it away is rather foolish. or at the very least it's a waste.
And to add to what others have already said, I've personally used 2x2GB DDR3 1333 for years in one of my rigs and it always worked perfectly fine.
The only thing I didn't like was that the advertised latency could only be reached by overvolting. Kinda lame marketing but since the modules worked fine, did everything I needed it to do (and on top of that looked rather good), I'd definitely not consider OCZ memory that bad.
Interesting seeing your experiences with OCZ customer support. Seems rather lame indeed but tbh it's not the only company with useless customer support like that. It definitely doesn't bode well for the reliability of that company and the products they had for sale at that time BUT that was then and now is now, if the memory comes out of a working system, the memory probably worked fine for at least a while.
I'd say just test it and if it works fine, use it. Parts I personally think are rather overrated, I'll probably run it at more relaxed settings if that helps make things run stably.
But OCZ is not a brand one should throw out on sight. That should be reserved for parts that can be outright dangerous (like certain PSUs for instance).
Reply 47830 of 52973, by Pawlicker
debs3759 wrote on 2023-01-30, 08:20:
More like PC-9801VM class in this case (except it's technically a VX+ given that it has the EGC chip, which the VM lacks). The reason I say that is Epson made 286/386 machines without the EGC chip (only the GCRG chip), which means that they cannot run games that use the EGC chip. NEC handled backwards compatibility by using a physical NEC V30 chip that could be toggled via a front panel switch and later a "speed" switch in the setup menu to slow the CPU down at boot, while Epson handled this with a "speed switch" on the front of the machine that actually acted like a true turbo switch. There's a V30 emulation mode in many machines however the speed is dodgy when playing games like The Screamer (DEHUMANIZE YOURSELF AND FACE TO BLOODSHED) among others.
Reply 47831 of 52973, by pete8475
Tetrium wrote on 2023-01-30, 15:53:
Why throw the OCZ memory away? If it works perfectly fine, then throwing it away is rather foolish. or at the very least it's a […]
Why throw it out? For the reasons I already mentioned, in short I consider it bottom of the barrel trash. I have quite literally hundreds of good SD, DDR, DDR-2 and DDR-3 ram modules on hand anyway, so no need to add junk to my stock.
Reply 47832 of 52973, by Tetrium
pete8475 wrote on 2023-01-30, 20:54:
Then why advice someone of who you don't know if they also have quite literally hundreds of good DIMMs in their stash to ASAP toss the OCZ modules out without a second thought? Because that advice came across more as if OCZ modules are inherently flawed so badly that throwing all out is the only sane option or something.
Reply 47833 of 52973, by Nexxen
Some DDR3-1866, but I can't see any advantage over 1600.
Maybe FPS in games? Probably so.
Could be handy for some overclock.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 47834 of 52973, by pete8475
Tetrium wrote on 2023-01-30, 21:42:
Again this is what an OCZ rep says about their modules; "prime 95 generally stresses our memory out too much"
This is my last post on the matter, so I'll just end with it's trash and the people that worked there admit it. Trash goes in the trash bin.
Reply 47835 of 52973, by TrashPanda
pete8475 wrote on 2023-01-30, 22:05:
Painting with a board brush is generally a bad idea, sure some of their modules are known to be trash but not all their modules were trash. And of the trash modules 99% of them work just fine with a tiny voltage adjustment or at slightly lower ratings.
I have dozens of OCZ modules in DDR/DDR2 and DDR3 and they all work as expected, now if you were to ask me which modules I have had serious issues with then Kingston would be at the top of that list with Corsair a close second, but again not all of the modules from Kingston and Corsair are garbage. Corsair in particular made some really great modules and at one point had the absolute best DDR2/DDR3 modules on the market.
Perhaps you might want to consider using a smaller brush when defining "Trash"
Reply 47836 of 52973, by TrashPanda
This board arrived today and on closer inspection well I'm not having much luck with Dual Tualatin boards ..now I have three boards that need recaps...sigh
They all post and appear to work just fine, so I may just pick the best one of the three and recap that one and keep the other two as spares in my projects box.
1.28 MiB
GA-6VTXDR
Hopefully I can find the caps I need from Mouser/Digikey, will likely make a thread on this board to get some advice on replacement caps. (The search engines on mouser/digikey are damn confusing to the uninitiated)
Reply 47837 of 52973, by Shponglefan
TrashPanda wrote on 2023-01-31, 01:50:
Especially when one takes law of averages into account. One person's bad experience might just be that: a bad experience. It may hardly be indicative of a product line or company as a whole.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 47838 of 52973, by TrashPanda
Shponglefan wrote on 2023-01-31, 02:03:
ASUS is a good example of this..they have had a lot of stinkers but also a lot of award winners and I find that assessing each item on its own merits is better than just claiming every product from them is garbage. (I know at least one user here will disagree with me about ASUS)
Reply 47839 of 52973, by Ozzuneoj
Painting with a board brush is generally a bad idea, sure some of their modules are known to be trash but not all their modules […]
Just to add my 2 cents... I only recall coming across defective memory three times in the past ~22 years or so. Once was a high density generic 256MB PC-133 stick back when that stuff was really cheap and often garbage. Second one was a stick of Wintec AMPX overclocked DDR2 memory that went bad after it was discontinued. They were a pain to deal with but I got my original purchase price refunded entirely after a while. Also found a bad stick of Patriot DDR3 in a laptop a couple years ago which was a bit surprising.
I had some OCZ DDR-500 Gold memory which was very expensive when new. I kept it around for several years, and one day looked it up and saw that it was worth even more than I spent on it originally... and this was long before the retro-PC craze kicked in 6-7 years ago. I tested that memory out and it still worked fine at it's rated speed\specs so I sold it for what was, in my opinion, a ridiculous price at a time when new PCs were using DDR3. It must have worked fine for the buyer too, because they kept it.
I also had some OCZ DDR2 and it was also totally fine.
I would test OCZ memory now, and if it tested fine I would hang onto it. It's pretty uncommon to find high speed DDR and DDR2 these days.
