Reply 50400 of 52951, by pentiumspeed
Bought few weeks ago and received today is a Kontron mini ISA SBC card. Uses socket 7 mobile processors to keep watts down. This one is a SY028 regular pentium 133MHz with voltage core of 2.75V-3.1V and i/o of 3.3V, yeah a split plane mobile CPU. Does support different processors as well. 2 x 72 pin slots, 256K PB cache, CHiPS B69000 for video, enbedded vram too! HX chipset but not full used due to single tag ram.
Second Kontron coming in as well but comes with a optional compact flash daughterboard, 512K PB cache and intel ethernet NIC on board, in same form factor of ISA only, mini too.
Kontron are great on support for that old! I can't speak of the Adventech as this one was a 486-386 SBC but no documentation.
Cheers,
Great Northern aka Canada.
Reply 50401 of 52951, by bearking
CharlieFoxtrot wrote on 2023-09-14, 18:57:
bearking wrote on 2023-09-14, 18:50:
... and here is what came in today:
Roland MPU-IPC, about 45 Euros shipped
Nice! I thought you need to trade your kidney for these nowadays. If you manage to find one, that is.
I guess I was lucky with this one. First a saw it, like two months ago, on a local classified ads site for something like 70 Euros and put it on my watchlist. I totally forgot about it until this week. Now the seller asked 50 Euros + shipping(~5 Euros) but I just had to ask if he could do 40+shipping, and he accepted 😁
Reply 50402 of 52951, by Shponglefan
Just got this industrial DFI motherboard: ATX Socket 7 with six ISA slots.
I see another six sound card build in my future. 😁
1.03 MiB
And speaking of sound cards, also added this Terratec EWS64 XL to my collection.
725.14 KiB
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 50403 of 52951, by pete8475
Shponglefan wrote on 2023-09-14, 19:46:
Just got this industrial DFI motherboard: ATX Socket 7 with six ISA slots. […]
Onboard video + 2 PCI is perfect for SLI Voodoo 2 cards too!
Reply 50404 of 52951, by Repo Man11
Repo Man11 wrote on 2023-09-04, 01:52:
I dismantled the 939 system and cleaned the case. I cheated and replaced only the two popped caps because I only had two caps that were the correct voltage and capacitance, and they were generic unbranded Ebay ones (and they are scarily identical to the failed ones). So that'll do for now until I get some quality ones and replace all of them. Board is working fine, XP is installing while I'm typing this. My other 939 board has a Via chipset, so it's nice that this SATA controller works with an SSD.
The build of this thing wasn't good. Every drive in it was only held in place with two screws on one side, and the motherboard standoffs were mismatched with some being fine thread, while others were coarse thread.
It's too bad there are so many scratches as it's a nice color, and I like this case for sentimental reasons. Maybe if I get really ambitious I could paint it.
I was wrong - looking closely the Ebay capacitors I had, they weren't unbranded, they are KZG, and the reason they looked so much like the two that I replaced was because the failing caps on the board were also KZG! I replaced all five this time, using Nichicons.
One thing I noticed with this board is that the heatsink retaining bracket is held in place with push pins rather than screws (my Asus A8V uses screws). As a result, the bracket was a little loose, and this meant that some of the clamping force meant to press the HSF against the CPU was being wasted pulling the bracket tight. My solution was to use some blue masking tape to shim the retainer's back plate. It took about four layers to get it tight. I had never noticed before, but from AM2 on they switched to using a bracket that has four screws to hold it tight.
Reply 50405 of 52951, by pentiumspeed
Repo Man11 wrote on 2023-09-14, 22:00:
There are metal back plate with screws instead of type of what you have. Easily found on ebay.
Cheers,
Reply 50406 of 52951, by Repo Man11
pentiumspeed wrote on 2023-09-15, 15:28:
Cheers,
That's certainly a better long term solution, but what I did worked, and it cost me nothing. I thought I had the perfect solution since I have a dead AM2 motherboard, but that's when I discovered that AM2 on use four screws to hold the bracket in place.
Reply 50408 of 52951, by Kahenraz
Xanxi wrote on 2023-09-15, 17:07:
Just bought a Miniplus USB MIDI device to add to my MIDI music stack. […]
Not retro in itself but will join my older Roland/Yamaha/Korg stuff.
Is it any good?
I tend to be a very harsh judge if MIDI synthesizers. Doom. Duke Nukem 3D. And Warcraft 2. These are my litmus tests. 👍
Reply 50409 of 52951, by Xanxi
Kahenraz wrote on 2023-09-15, 17:10:
Youtube has a sample of Doom with this device. What do you think?
https://www.youtube.com/watch?v=y1STRYKY5_M
Reply 50410 of 52951, by RetroGamer4Ever
It's very much middle-of-the-road. Powered by a low-end DREAM chip and intended for performance/creation use. Perfectly adequate for GM gaming, but not anything special. A Dreamblaster unit would be a better buy, if you want something with a bit more quality and potential or Roland GS sound.
Reply 50411 of 52951, by Ensign Nemo
Is it any good?
Sounds serviceable to me. Not as good as an SC-55 imo, but still decent. If you are looking into more midi options and aren't concerned with using actual retro hardware, you can't go wrong with a Raspberry Pi. MT32-pi is a great project and can be used for general midi as well:
https://github.com/dwhinham/mt32-pi
You could do a similar thing with a tablet or even a small pc or thin client. You're probably familiar with these, but I thought I'd mention in case you weren't.
Reply 50412 of 52951, by Xanxi
Yeah actually i have all this already (MT32, SC55, SC88 - don't use this one at the moment, too bulky for my desk space, Yamaha MU-100 and Korg X5DR), but i like to add new blood to my MIDI tower and have sometimes them play together.
All this stuff is connected to two Amiga, to my retroPC, to my modern PC, and perhaps one day to an Atari Falcon, thanks to the Roland A880 is got lately.
So far, the SC55 is the better GM/GS synth all around and in most games, but the MU-100 is better in some like Dark Forces and sounding newer. The Korg one sounds like a console from the early 90's but is sometimes sounding odd.
MT32 is MT32.
I would also like to have a Casio GZ-50M.
The MT32 -pi i have one but it keeps complaining about low power with the different psu i have so i haven't really used it so far (with Rpi3A+).
Reply 50413 of 52951, by Ensign Nemo
Xanxi wrote on 2023-09-15, 19:06:
Yeah actually i have all this already (MT32, SC55, SC88 - don't use this one at the moment, too bulky for my desk space, Yamaha […]
MT32 is MT32.
Midi gear is a whole other rabbit hole to go down. Even though the emulation is really good, there's something special about having actual hardware. I recently picked up a Roland MT-300S and love it. It was meant to help people learn how to play piano and looks like a boombox with a floppy drive. Once I got it working, it has been a great poor man's SC-55.
Have you ever considered doing showdowns of different midi devices, especially the rare stuff you own?
Reply 50414 of 52951, by Grem Five
I swear it looks like those caps are trying to spell out something.
Reply 50415 of 52951, by luckybob
Use a better quality cable. or a shorter one. sometimes BOTH. I'm a fan of the ANKER Powerline+ cables.
Reply 50416 of 52951, by Xanxi
Ensign Nemo wrote on 2023-09-15, 19:27:
You're right, this a lot of fun, especially hijacking old stuff from musicians (usually selling them cheap, except the great Yamaha MU-1000/2000 still selling for a lot) to use them with old computers and games.
I have nothing rare actually, but only the most common and known MIDI synths. Your MT-300S is way rarer.
Youtube has plenty of vids already about these devices and games.
Reply 50417 of 52951, by Xanxi
luckybob wrote on 2023-09-15, 19:45:
ok, will try that this week-end.
Reply 50418 of 52951, by EvieSigma
I got this little friend-shaped Compaq, been wanting one of these...but mine seems to be quite ill, the motherboard is just not initializing at all.
229.78 KiB
184.7 KiB
Reply 50419 of 52951, by Kahenraz
EvieSigma wrote on 2023-09-15, 23:11:
I used one of these when they were contemporary with Windows 95. They're little troopers and we're a delight to use. What are their specs?
