Reply 52460 of 53103, by Shadzilla
Kahenraz wrote on 2024-04-02, 13:13:
Shadzilla wrote on 2024-04-02, 12:29:
Looking forward to building my first Slot A system 😀
I've heard that these AMD systems need a very strong 5V rail, which doesn't seem to be a common feature in modern power supplies. If the system is unstable, this might be the reason.
Good to know, thank you!
Reply 52461 of 53103, by PC@LIVE
Purchased a little while ago, a batch of three motherboards, two socket 370 and a 423, just a few days ago I had bought another 423, but this one has RDRAM instead of SDRAM, and that's fine for me, I wanted a second 423 with RDRAM, and I keep four modules aside for a total of 512 MB (4X 128).
The 370s on the other hand have VIA chipsets, no Tualatin support, only Coppermine, but it's still good.
I hope they arrive soon, in the meantime I'll start preparing, RAM and other things, I don't have the heatsink with fan for 423, I'll see if I can adapt one, or if I can find a second-hand one.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
AST Pentium Pro 200 MHz L2 256KB
Reply 52462 of 53103, by fillosaurus
supercordo wrote on 2024-04-01, 21:48:
Just bought my first video card from Quantum3D!! Sellers picture.
I have the AGP version.
Y2K box: AMD Athlon K75 (second generation slot A)@700, ASUS K7M motherboard, 256 MB SDRAM, ATI Radeon 7500+2xVoodoo2 in SLI, SB Live! 5.1, VIA USB 2.0 PCI card, 40 GB Seagate HDD.
WIP: external midi module based on NEC wavetable (Yamaha clone)
Reply 52463 of 53103, by fillosaurus
Reply 52464 of 53103, by fillosaurus
Reply 52465 of 53103, by Linoleum
bestemor wrote on 2024-04-02, 03:09:
Me just curious, when you turn it on, does it have a LOUD 'bang' each time ? Louder than you'd expect, I mean ? And what is the […]
Linoleum wrote on 2024-04-02, 01:01:
What I thought I was going to pickup was a 19 inch Viewsonic CRT monitor (my dream), turned out to be a 22 inch!!!!! If I am reading the manual correctly, this thing can do 2048 x 1536 @ 60 Hz. Now I am going to feel like John Carmack when he was coding Quake!! 🤣
Louder than you'd expect, I mean ? And what is the manufacture date on the back (month/year) ?
PS: also the max resolution seems to be possible even @68hz refresh rate.
(page 5 in the manual, bottom table, the 'manually' set rates vs the preset timings)
Kind of... But not as loud as I thought it would be.
#1: Sempron 3000+, 1Gb, HD3650 AGP, SB Audigy 2 ZS
#2: P4 1.8Ghz, 512Mb, Voodoo3 3000, SB Live!
#3: P3 866Mhz, 384Mb, Riva TNT2 AGP, SB Live!
#4: P233 MMX, 64Mb, ATI Rage II+, SB 32
#5: P100, 32Mb , S3 Virge, Sb16, Mt32-Pi & PicoGus v2.0
Reply 52466 of 53103, by BetaC
Nothing too fancy today, just a cute little ceramic 5x86 with a board sandwich below it to, maybe, just add a fan to it.
204.55 KiB
Reply 52467 of 53103, by Trashbytes
BetaC wrote on 2024-04-03, 05:01:
Thats an interposer, likely to throw it onto a board that doesnt support that CPU, if you are just putting it onto a 5v board then it wont need that interposer.
Can you separate the two .. would be cool to see pics of that interposer, would be able to tell what its for.
Reply 52468 of 53103, by BitWrangler
That sounds backwards to me, should be to support it on a 5V only board.
Reply 52469 of 53103, by BetaC
Trashbytes wrote on 2024-04-03, 05:58:
Here's the bottom:
374.78 KiB
And here's the mass of layers. I don't have a tool to remove the CPU cleanly, so I am going to keep it together for the moment.
47.71 KiB
Reply 52470 of 53103, by OMORES
This Genius EasyMouse, serial, for 1$.
https://fccid.io/FSUGMZE3 - a hot item from 1996...
My best video so far.
Reply 52471 of 53103, by acl
OMORES wrote on 2024-04-03, 18:27:
Hmm.
That reminds me that I ended up with too much old mice. I will try to list them on the givaway thread before sending them to trash.
I have some serial ones I guess... yours looks familiar to me. I might have one too.
Reply 52472 of 53103, by ubiq
A wondrously and evenly yellowed AOpen/Acer AT case (incl. the cdrom!), ca. 1996 I figure. A little too new for it, but I'll be putting a 486 of some sort in it.
710.99 KiB
Reply 52473 of 53103, by BitWrangler
I am crossing my fingers for you, but somewhere around then Acer went to weird not quite standard stuff.
Reply 52474 of 53103, by ubiq
BitWrangler wrote on 2024-04-04, 03:57:
Huh, you're not wrong... looks like the slots for the plastic spacers are slightly non-standard. Thankfully, there are also threaded holes for metal standoffs, so looks like I might have dodged a bullet:
1.24 MiB
1.17 MiB
Reply 52475 of 53103, by PD2JK
Nice board, Mr BIOS and I see three brands of cache memory. 25 and 20ns?
Now I wonder how SRAM speed corelates with cpu speed. I.e: do you need 10/12/15ns cache in order to run a 133MHz CPU perfectly stable, or does 25ns suffice as well?
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Orion 700 | TB 1000 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 52476 of 53103, by ubiq
PD2JK wrote on 2024-04-04, 04:35:
Yeah, the board came with that odd assortment of cache memory. I haven’t run it up at all other than to verify that it posts. Honestly, if it’s stable I’ll probably leave it as is. I’m planning just a classic DX2/66 + 16 megs ram and not looking to build a perfectly optimized speed demon.
Reply 52477 of 53103, by GigAHerZ
ubiq wrote on 2024-04-04, 04:18:
Huh, you're not wrong... looks like the slots for the plastic spacers are slightly non-standard. Thankfully, there are also thre […]
Please dump the rom!
There are almost no 486-class MR BIOSes available.
Share the love! 😁
Reply 52478 of 53103, by PD2JK
Highscreen Kompakt III with an AMD 386SX-33 for not too much. Fortunately only discolored by the sun, not tar or nicotine.
I might just win a 'who-got-the-yellowest' competition.
722.67 KiB
There's a Philips LMS ( CM260 card + CM206 drive ) installed, never seen one in the flesh.
1.07 MiB
