Reply 59780 of 60096, by Big Pink
MattRocks wrote on 2026-09-30, 20:56:
BS. It looks like two items are now lost in the post.
I'm not sure what the staff at Royal Mail do with the retro PCBs they intercept, but they are making me angry.
There's a lot of stuff going missing, not necessarily for underhanded reasons, for which I have to refer many people to customer services. It's what happens when your half-decade long staffing retention crisis is plugged with agency workers and hiring the unemployable. It's nearly a minimum wage job now!
I thought IBM was born with the world
Reply 59781 of 60096, by Thermalwrong
NeilKnows wrote on 2026-09-30, 17:21:
Fazeshift wrote on 2026-09-30, 15:28:
Good to hear. […]
NeilKnows wrote on 2026-09-27, 20:33:
Seems fine. I thought the backlight was a bit dim initially but seems totally fine...
In good shape overall 😀
Good to hear.
I was just curious. It is really hard to assess if the LCD issue is widespread or not, especially secondhand with unknown storage and care.
I got my Thinkpad at a yardsale in my own neighborhood, along with an Austin laptop (Pentium 90), and an external 5.25 Floppy drive still in the shrinkwrap. For $40 total. I doubt I will ever get this lucky with retro hardware finds in the future. Someone loved the Thinkpad - bigger/newer hard drive than spec, and was complete with all accessories, still booted to Windows 98.
However my TP 760EL I just pulled out to compare it with has now got a faulty backliught...arghh!
The joys of vintage laptops 😀 Good luck with getting that working
Hacket wrote on 2026-09-30, 16:01:
Got couple of Vaios PCG-C1 one with whole set with charger pcmcia cdrom and recovery cds and second single unit. Left it's Pentium II 400Mhz and second is Pentium II 266Mhz. 400 machine has a 64 mb ram upgrade. So i think i found my dos/win9x dream battlestation. It's bigger than librettos but it feels way sturdier and it doesn't have a ripping like a chips plastics.
Awesome! I have a PCG-C1XD and just won an auction for the accessory set for it the other day - really looking forward to getting the VGA adapter and the recovery discs. I've already got the CD-ROM for it -- something cool I discovered recently is that if you've got the PCGA-CD51 cdrom hooked up, it can boot from CD if you hold down the left Ctrl key when the VAIO logo shows up.
Would you possibly be around the Bristol area? Someone I sent something to via royal mail had their parcel fail to get delivered, no missed delivery card? It then sat in the warehouse for about a full month before they returned it to sender. Apparently they've got agency staff that aren't covering everything so they're likely falling behind. I had to send it back to them via Evri, somehow they're now better in his area. That was a hassle neither of us wanted.
Around my way near London, RM are extremely reliable and their new tracking system has been great for me.
Hope your parcels turn up soon 😒
Reply 59782 of 60096, by MattRocks
Big Pink wrote on 2026-09-30, 21:13:
That does not explain physical non-perishable items going astray: they can't put them in the bin in a sorting office and they can't store them on a shelf in a sorting office, so.. they accidentally put them in a lunchbox through lack of training or experience?
Desktop timeline [ MOS 7501 → 68030 → x86(P5/MMX) → x86(K6-2) → x86(K7*) → PPC(G3*) → x86-64(K8) → x86-64(Xeon) → x86-64(i7) ] * lost
Reply 59783 of 60096, by Hacket
Thermalwrong wrote on 2026-10-01, 00:01:
I have 2 pcga-cd51 but on other unit a small gear broke i should rebuild it or replace. You can boot from cd even with just chaneging in bios. I wanted to use that cd rom for recover my toshiba libretto ff but it seems it doesn't work out of the box without drivers in dos so no luck. I'm waiting for another tosh cd-rom to arrive. Woha i also need vga adapter for these vaios.
Reply 59784 of 60096, by Lylat1an
If anyone cares, I bought a Nakamichi MJ-5.16 yesterday.
(That's a 5.25" slot-loading 5-disc CD-ROM changer)
Kind of interesting to watch one work without the top cover: https://youtu.be/crE0MX0qqBg
Reply 59785 of 60096, by Shader_BiH
Pino wrote on 2026-09-29, 19:30:
Bought a socket 478 Pentium 4 Motherboard with ISA slots.
Despite retroweb and Ai search telling me the PCI-to-ISA bridge on it wouldn't support DMA I took the risk and I'm glad to say they are wrong, a National Semiconductor PC87200VUL bridge chip works great with the right BIOS settings, my soundblaster 16 works great with IRQ and 2 DMAs assigned.
It's really unusual for the 478 era... and it has a postcode indicator, if I'm not mistaken. Super cool 😁
Reply 59786 of 60096, by psychofox
Bought a interesting Datamedia Corp XT mainboard.
CPU is Nec V30, FPU is also present. Ram is soldered onboard. Also there is an large 60pin slot, what it might be? I could not find any info or documentation. Power plug is 10 pin, first thing is to identify correct voltages, it is not probably standard AT power connector?
Reply 59787 of 60096, by Big Pink
MattRocks wrote on 2026-10-01, 06:41:
All of the above I can cite examples, except for the lunchbox.
Assuming it made it to your local delivery office the most likely explanation, barring theft or dumping, is it got delivered to someone else in error. If the item was Tracked and you got notification that it was heading out on delivery (because it got scanned to core route) then the last person that handled it will be known and they can have their brains picked - the sooner the better before those memories are overwritten by another several hundred packets.
Reply 59788 of 60096, by Nunoalex
Look at this gorgeous beauty that came my way 😀
Soltek SL-86SPE-L
It has a PCI slot bent I hope I can put it back in place
The attachment soltek1.jpg is no longer available
The attachment soltek2.jpg is no longer available
The attachment soltek3.jpg is no longer available
Reply 59789 of 60096, by Nunoalex
Never expected to find one of these in my life...
I bought on a local marketplace a not very eventful Pentium II @ 400mhz for 40 euros ... and after a general look I decided to test it
Then turned it on and it booted ... but immediately the 4 GB Maxtor hard drive starting clicking like nuts ... well what a surprise huh ?
Suddenly I look at the POST screen and I see .. LS-120 IDE .. and I was wwwwwwwwwwhhhhhhhhhhhhaaaaaaaaaaatttttttt ????
My heart started racing, I turned the PC off and looked at the floppy drive .. it was one of those notches included on the case faceplate ...
To be honest I never bother even looking at the floppy drives of the cases I buy and most of the time I just disconnect them and remove the cables... but today I was lazy
Got a screw driver and started disassembling the case but I could already see the "laser" stickers and I was going nuts !
I was thinking well it will be one of those drives without faceplate because the face is the front of the case.
But when I finally removed all the screws and pulled the drive this beauty popped up, faceplate and all ! what a glorious day !
I already tested it with a regular floppy disk and it works ... I have none of those special floppies of 120mb !
The attachment ls-1203.jpg is no longer available
The attachment ls-1202.jpg is no longer available
The attachment ls-1201.jpg is no longer available
Reply 59790 of 60096, by Dothan Burger
Nunoalex wrote on 2026-10-01, 18:59:
Soltek SL-86SPE-L
Another Sexy Soltek, Nice.
Reply 59791 of 60096, by H3nrik V!
Bought an identical match for my Asus GTX780Ti reference design. Gotta look for a third and an sli bridge, to fool a bit around with my Asus P9x79 board 😎
Also panic- bought a lot of 2 floppy drives, a 3.5" card reader and some optical drives from a "that's crazy cheap" point of view 🤣 probably a fine deal, haven't looked much at it yet ..
Reply 59792 of 60096, by G-X
Soltek SL-86SPE-L
Looks amazing! Never seen these before.
Reply 59793 of 60096, by PD2JK
psychofox wrote on 2026-10-01, 18:23:
I would guess that 60 pin slot is for extending the ISA bus. 7 slots on-board, the 8th through that 60 pin connector?
has all kinds of stuff
Reply 59794 of 60096, by tehsiggi
Bought a HD4850 PCIe and X1300 PCIe for science.
The part that stood out for me: I initially wanted to use a HD4770 for my testing, as it would be absolutely sufficient. However those go for around 25-35€ on ebay here in Germany, whereas the HD4850 can be had for 10€ . Well, not that I need that much horsepower, but hey, I'll take it.
The X1300 wasn't as easy as I though either. Ideally low profile + DVI + as cheap as possible. But many cards are dell OEM ones with DMS-59, making be shudder at the thought of having a dongle on it. So after some search I found one for around 5€.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 59795 of 60096, by devius
Nunoalex wrote on 2026-10-01, 19:17:
Now you're obligated by law to acquire the 120MB floppy disks that go with it 😎
Retro Coisas no YouTube
Reply 59796 of 60096, by Trashbytes
Never expected to find one of these in my life... […]
Careful with that drive, LS120 drives have a rather nasty habit of getting the click of death as they age, of the three LS120 drives I have 2 are no longer functional due to the click of death, no idea exactly what causes it but I suspect its to do with the electronic eject system failing.
Never been able to repair it either as its beyond my pay grade level of skill.
I do love them though as they are significantly faster at reading normal 1.44Mb floppies than your average floppy drive.
AI is inevitable, there is nothing you can do to stop it, no Ironman snap to save you from the Basilisk.
Reply 59797 of 60096, by Trashbytes
tehsiggi wrote on 2026-10-02, 04:39:
The 4850 isn't much faster than the 4770 in real world use, it does run cooler and use less power though which may be of interest to you if you are looking for efficiency.
Reply 59798 of 60096, by tehsiggi
Trashbytes wrote on 2026-10-02, 11:38:
I basically needed "more than 4670" performance in the 4000 series.. and since I had a 5770 back in the day, I thought "Well, why not a 4770" 😁
Reply 59799 of 60096, by BitWrangler
devius wrote on 2026-10-02, 11:07:
Here are some of the packages to keep an eye out for ... Re: Bought these (retro) hardware today
