D-Fend Reloaded (DOSBox frontend)
Reply 2240 of 2250, by Alexis78
So, D-Fend Reloaded isn´t updated any more?
I reinstalled D-Fend Reloaded after many years without using It and I have a few questions, after reading a bit in this thread It seems that the author, Alexander, isn´t here since 2016, is that correct?.
Reply 2243 of 2250, by 001
So... I got really annoyed with a bug in D-Fend Reloaded. There was a typo in the procedure that handled how to deal with mounted zip files. One thing led to another and I ended up not only up fixing it, I also updated some components (FastMM4, SevenZipVCL, GifImage) and the project got updated so it compiles with current Delphi versions (I'm using the latest 30 day trial). If anyone wants to fix or add anything this is a good starting point.
https://drive.google.com/file/d/1tlAmgeP1tkEz … I2YchfYsGd/view
The .7z has the updated source, and a precompiled DFend.exe.
Its 101% untested, I just compiled it a few minutes ago, got DosBox running and thats it. I'm pretty sure it has more bugs than features.
I'm not planning to make any updates or taking feature requests, aside from (maybe) fixing bugs related to the update to Delphi 10.4. pls report them here, not by PM.
Reply 2244 of 2250, by Onkr
001 wrote on 2020-10-12, 03:12:
Hello 001
It is great you took some time to upgrade Dfend code ! Thanks for your effort.
I downloaded your code but unfortunately there is an error in DosBoxUnit.pas when I tried to compile the project.
[dcc32 Error] DosBoxUnit.pas(1577): E2010 Incompatible types: '_PROCESS_INFORMATION' and 'Pointer'
Which Delphi version are you using ? I used the last community version 10.3
I also noticed that some modules have been fixed in your source but not included anymore in Dfend project (e.g. GIFImage.pas). Any reason ?
I am by far not an expert in Delphi but if someone could take this opportunity to jump on 001 work it would be great.
Most desired (IMO) : recover ability to download info/images from Mobygames or similar sites
Reply 2246 of 2250, by sleepybear360
Greetings Users!
I am a first-time poster here on Vogons and I loved D-Fend Reloaded. However, with that being said, it does seem like it has passed the end of its life-cycle and it might be time to move on to new pastures. This morning I decided to put my thinking cap on and start recreating this piece of computing history.
Enter D-Fend Renewed
Yes, D-Fend Renewed (thanks for the name by the way) has been born on 4-3-2021 and is ready to live, provided you want it too! What I am doing now is preparing to recreate and fix a lot of the issues in D-Fend Reloaded is a new iteration of the application called D-Fend Renewed, and it needs your support to live. What do I mean by support? Well, simply put, there has to be an interest in the project before I decide to continue it, after all, it doesn't make sense to spend hundreds of man-hours on an application if nobody will use it. So consider this post to be a probe if you will so I can tell if there is still a need in 2021 for this once beautiful piece of software.
Planned Features
  • A proper website
  • A brand new plugin system
  • A more intelligent way of adding new games
  • Upload/download installed games right to the cloud
These are just a few of the planned features that I would implement into D-Fend Renewed should the demand be great enough and we decide to create said application and distribute it. If there is not enough interest regarding D-Fend Renewed then it just like D-Fend Reloaded will just be a memory that lives warm in our hearts.
Cheers!
    22.05 KiB
Reply 2247 of 2250, by IIGS_User
sleepybear360 wrote on 2021-04-03, 15:35:
[*] On-demand games (yes, you will be able to browse, download and auto-install abandonware games directly within the application!)
Better to leave this point out.
On pg. 112, I was just joking about the new name, but nice to see this idea has been taken.
Best thing on it is to implement features new to 0.74/SVN, which are not seen in Reloaded, seen on its age.
Klimawandel.
Reply 2248 of 2250, by sleepybear360
IIGS_User wrote on 2021-04-03, 16:39:
Better to leave this point out. […]
Thanks for the heads up!
Reply 2250 of 2250, by Stiletto
sleepybear360 wrote on 2021-04-03, 16:46:
IIGS_User wrote on 2021-04-04, 19:29:
Because moderators doesn't like to see abandonware supported, and this must be for a good reason, for legality.
Agreed, we wouldn't let a utility, that automatically downloads software for which the copyright owner never granted redistribution rights to the general public, have an advertising/support thread on VOGONS.org.
do the Fandango!" - Queen
Stiletto
