First post, by Unregistered
How do I instal VDMsound?
Reply 1 of 8, by eL_PuSHeR
Rank Moderator
Moderator
1.- Double-click on the .MSI installation file
2.- After finishing, reboot your machine
3.- Download and unzip latest update 2 to program folder
4.- Download and unzip Launchpad components (optional)
5.- Run INSTALL.BAT to register the Launchpad
6.- Reboot your machine
Reply 2 of 8, by vladr
eL_PuSHeR wrote:
1.- Double-click on the .MSI installation file 2.- After finishing, reboot your machine 3.- Download and unzip latest update 2 t […]
No need to reboot. Only reboot at the very end if things don't work.
V.
Reply 3 of 8, by eL_PuSHeR
Rank Moderator
Moderator
On my machine, I got the infamous error message of "DOSdrv cannot be found" if I don't reboot right after install.
Some people also got the error message "This PIF file is not suitable to run" or something like that. I've seen it on a friend's computer. All was cured after rebooting. Both systems running WinXP.
Reply 4 of 8, by HunterZ
I also thought that adding or removing shell-extensions (i.e. the right-click menu to Run with VDMS) doesn't take effect until rebooting. Maybe that's just for removing?
Reply 8 of 8, by Unregistered
I think i fixed it. WHen I tried to uninstall it last time i though it automatically takes the loaders shell of your computer, but it didn't. So when I tried to reinstall it wouldn't work. Then i found the loader file on my computer in which i could never throw away, but know I know why, and went into the folder and did the uninstall.bat on it. Once everything was off my comp i did a clean install.
