IBM PS/1 Audio Card.
Developer's Forum, for discussion of bugs, code, and other developmental aspects of DOSBox.
Re: IBM PS/1 Audio Card.
Postby Great Hierophant » 2018-12-22 @ 19:47
matze79 wrote:Is there any Documentation how the DAC works ? :)
Ahh i see..
Code: Select all
These two activate the IBM PS/1 Audio Card. It is always situated at ports 0200, 0202-0204, so there's no need for a "base" value.
is it dma driven ? or more like a covox device ?
It's an in-between, think of it like a more capable Disney Sound Source. it uses a 2K FIFO buffer for the DAC and can send an interrupt when the buffer is almost empty. The rate in which the FIFO is sent to the DAC is controlled by an 8-bit timer. The Options from the Technical Reference will tell you how it works : ftp://ftp.mindcandydvd.com/pub/drivers/ ... index.html
User avatar
Great Hierophant
Postby DaveJustDave » 2019-1-03 @ 05:21
Does anyone have the sierra patch utility for this card to enable support on SCI games? I would love a copy
I have no clue what I'm doing! If you want to watch me fumble through all my retro projects, you can watch here: https://www.youtube.com/user/MrDavejustdave
User avatar
DaveJustDave
Postby Cloudschatze » 2019-1-03 @ 05:33
DaveJustDave wrote:Does anyone have the sierra patch utility for this card to enable support on SCI games? I would love a copy
ftp://ftp.oldskool.org/pub/IBM_PC_BBS/ps1/instdrv.exe
User avatar
Cloudschatze
Previous
Return to DOSBox Development
Who is online
