First post, by Varka
Exception in thread "main" java.lang.NoClassDefFoundError: SevenZip/Archive/IInArchive
at com.db.Database.<clinit>(Database.java:88)
at com.gui.MainWindow.open(MainWindow.java:94)
at com.gui.MainWindow.main(MainWindow.java:86)
Caused by: java.lang.ClassNotFoundException: SevenZip.Archive.IInArchive
at java.net.URLClassLoader$1.run(URLClassLoader.java:220)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:208)
at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294)
at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:336)
... 3 more
Reply 2 of 6, by Varka
Yes.
More info:
[k@localhost Videos]$ java -version
java version "1.6.0_05"
Java(TM) SE Runtime Environment (build 1.6.0_05-b13)
Java HotSpot(TM) Client VM (build 10.0-b19, mixed mode, sharing)
It's the SUN-supplied java RPM.
Command line is:
[k@localhost /] cd ~/dbgl
[k@localhost dbgl]$ sh dbgl
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 3 more
Reply 4 of 6, by Varka
[@localhost lib]$ ls -la
total 1992
drwxr-xr-x 2 keenerb keenerb 4096 2007-08-27 15:59 ./
drwxr-xr-x 9 keenerb keenerb 4096 2008-04-15 21:31 ../
-rw-r--r-- 1 keenerb keenerb 643806 2006-09-27 14:50 hsqldb.jar
-rw-r--r-- 1 keenerb keenerb 91967 2007-06-13 10:15 J7Zip.jar
-rw-r--r-- 1 keenerb keenerb 3085 2006-11-03 18:34 swing2swt.jar
-rwxr--r-- 1 keenerb keenerb 1245295 2007-06-25 12:12 swt.jar*
Reply 5 of 6, by Varka
OK, two strange observations:
That listing was from a new dbgl install.
When I checked the dbgl script, it looked like this:
#!/bin/sh
cmdline=$0
symlink=`find "$cmdline" -printf "%l"`
if [ $symlink ]; then
cmdline=$symlink
fi
cd `dirname $cmdline`
if [ $JAVA_HOME ]; then
$JAVA_HOME/bin/java -Djava.library.path=lib64 -jar dbgl.jar
else
/usr/bin/java -Djava.library.path=lib64 -jar dbgl.jar
fi
So I changed lib64 to lib, and it worked...
In my old folder (which used to work, a long time ago) I don't have the 7zip jar.
Reply 6 of 6, by MiniMax
Rank Moderator
Moderator
Whoa! That script is prone to many errors if some of the file names and paths contains blanks etc. And I don't like the [ $var ] test. Better make it explicit with -n. And with the help of some clever variable expansion we can get rid of the tests altogether and the repetitive code:
#!/bin/sh
symlink=`find "$0" -printf "%l"`
cd "`dirname "${symlink:-$0}"`"
"${JAVA_HOME:-/usr/bin}"/java -Djava.library.path=lib64 -jar dbgl.jar
_________________
