First post, by eL_PuSHeR
Java SE RE
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 1 of 11, by MiniMax
Rank Moderator
Moderator
And for those sceptics like me that don't like to download from random sites, go here:
http://java.com/en/download/
_________________
Reply 3 of 11, by Zup
Also, there is a myth that says that beginning with update 10, java would be deinstalled after upgrading (avoiding several jre installations in the machine).
I'm selling some stuff!
Reply 4 of 11, by Snover
Finally. I hope that's true; I can't tell you what a problem it is to have old versions of JRE hanging around on the machine in terms of security, and I can't believe it's taken them this long to comprehend that.
Yes, it’s my fault.
Reply 5 of 11, by MiniMax
Rank Moderator
Moderator
Why would it be a problem? Unless some brain-dead application picks a specific, old JRE, then it should always get the default one, right? And if a specific version is selected, there is probably a reason for that choice, like the application will not work with never version.
_________________
Reply 6 of 11, by Snover
Brain-dead like a malicious application that intentionally targets an old version that contains a security flaw so that it can break out of the sandbox and infect your machine with a virus? See also Java.ByteVerify and Sinowal/Torpig.
Yes, it’s my fault.
Reply 7 of 11, by MiniMax
Rank Moderator
Moderator
Excuse my ignorance, but can an Java-applet specify which version of the JRE to use?
_________________
Reply 9 of 11, by MiniMax
Rank Moderator
Moderator
Ahh - thanks Snover. That is scary!
_________________
