Reply 20 of 40, by Farnsworth
Can you apply a patch to DOSBox CVS and compile it for your Mac?
I'll try it but I've got 2 questions :
The official DOSBox source?
This may be a dumb question : Can I apply the patch on the source on a PC and build that source on Mac ?
Thanks for the patch
Reply 21 of 40, by Qbix
Rank DOSBox Author
DOSBox Author
to this source:
http://dosbox.linuxsecured.net/dosboxcvs.tgz
and yes you can apply it everywhere. however the mac is probably easier as i think it has all utilities needed installed by default
Water flows down the stream
Reply 23 of 40, by jal
wd wrote:
Get a debugger, debug it, be happy.
Please wd, read the post will ya 😀. I already found the bug, it's indeed an endian issue. I just don't have the time to actually fix it (luckily HAL did).
JAL
Reply 24 of 40, by Farnsworth
Please wd, read the post will ya . I already found the bug, it's indeed an endian issue. I just don't have the time to actually fix it (luckily HAL did)./
OK I was already planning to do that. I had something else to do first but now I'm working on it, I've applied the patch and now I'm compiling the SDL thing.
Reply 29 of 40, by Farnsworth
Uhm don't we just need something like host_readw(...) instead of bitsA = *(Bit16u *)&vga.mem.linear[mouseaddr]; or is there […]
host_readw(...)
instead of
or is there more to it?
I hope my change is more efficient too
If someone makes a .diff I could test it.
Reply 31 of 40, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
At most it would break Win3.11, Win95 and whatvga 😉
(these work for me though)
The difference is only small, probably.
1+1=10
Reply 32 of 40, by wd
Rank DOSBox Author
DOSBox Author
Bitu mouseaddr = ((Bit32u)vga.s3.hgc.startaddr) * 1024 + moff * 16;
What if moff is negative? moff+=64 doesn't necessarily make it positive,
and mouseaddr is unsigned so might be very large.
Reply 33 of 40, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
I've worked some more on the patch, some of the cursor variables need to be limited in value. I'll probably provide a 8-bit and a 16-bit access version then somebody can test which one is faster. But not today as I'm forced to visit some relatives 😉
1+1=10
Reply 34 of 40, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Now it doesn't have so much in common with the original any more xD
The cursor values are now more extensively checked for overflows.
I think I'll skip the 16-bit one...
    byeorder_s3_hgc_2.diff
    12.91 KiB
    133 downloads
1+1=10
Reply 36 of 40, by ADDiCT
Oh dear. <sarcasm on>Of course, DOSBox will be at least 10x faster, on any system, with that patch applied! This patch alone makes it possible to run DOSBox on anything with a CPU, from a 70's pocket calculator to your grandpa's pacemaker, and play "Blood" in SVGA at full FPS on each device. It's the same thing as with Microsoft security patches, which accelerate the system twofold with each and every single patch. Oh, the wonders of information technology!<sarcasm off>.
Reply 37 of 40, by Farnsworth
I know that I won't make DOSBox any faster with a patch to fix the mouse but I thought maybe the mouse would work better or something like that? Why did he made another patch if it didn't change anything? I'm only asking it to know the difference.
