First post, by Spade
The screen resolution is stuck at 16.9.
Changing the fullscreen res or the window res in dos pref does nothing.
I have tested this on 3 systems in my house running leopard.
they all are stuck at 16.9 weather they are on a 4.3 display or 16.9.
If someone could help me out with this. It would be great.
Reply 3 of 6, by wd
Rank DOSBox Author
DOSBox Author
Try some mode13 game (regular 256 colour vga) like indy4 and choose
aspect=true, which should give a 320x240 (or scaled up) resolution.
If that works, and aspect=false doesn't, your gfx card/driver doesn't
hardware-scale the output.
Reply 4 of 6, by Spade
Thanks this seems to have given me fullscreen 4.3 ratio in almost all my games.
I would think it odd that none of my macs support hardware=scale.
Dos box acts this way even on my intel Imac with a nvidia card in it.
Reply 6 of 6, by wd
Rank DOSBox Author
DOSBox Author
Well "scaling" can be pretty much, what your gfx card has to do for the
dosbox defaults/output not surface is hardware scaling a non-usual resolution,
that is 640x400. The aspect=true turns that into a 640x480 which seemingly
works better for your system, though it requires software "scaling" (y-direction).
