Screenshots of the current CVS
Reply 60 of 95, by Kain
Thats probably because you have more than 2.4 gigs in that harddrive being used. Some older programs only see the first 2.4gbs and if they are full they think there isnt enough space, or with Baldur's Gate 1, it only sees 2gb of freespace.
Anyways, here you go I got DUKE NUKEM 3D running!
    128.33 KiB
Athlon Xp 1700+ @ 1.833ghz
ASUS A7N8X v1.4
Crucial 256mb Pc 2100 @ 166 mhz
Chaintech GeForce 4 Ti4200 128mb
Western Digital 40gb WD - 400
Windows 2000 Professional
Creative SB Live! 5.1 Dolby
Maxtop Case w/ 350w PSU
Reply 61 of 95, by Kain
Yeah! Life to the 1st person shooters!
Here's doom2, this one is playable with some CTRL+f7/8 + 11/12
    136.82 KiB
ASUS A7N8X v1.4
Reply 62 of 95, by Kain
Here you go! Another pic of a game!
Crime Fighter
    111.61 KiB
ASUS A7N8X v1.4
Reply 64 of 95, by Kain
I said 'some'. Because some games have a problem detecting games over that much space or they have a faulty save system. Also, I have gotten a message like that in Albion but it was solved once I made a "SAVES" folder in the ALBION folder.
Hope it helps!
PS. WOOT this post hits its 22000 views!! 😁
ASUS A7N8X v1.4
Reply 65 of 95, by maYO
YES!
It works!
Some speed issues. But perhaps I can fix them.
No SFX for now but I'm also trying to get them working
    94.71 KiB
DOSBoxGui - multi platform DOSBox frontend
check my weblog (german only)
Reply 66 of 95, by maYO
maYO wrote:
YES! It works! Some speed issues. But perhaps I can fix them. No SFX for now but I'm also trying to get them working […]
YES!
It works!
Setting the CPU cycles to about 3000-3500 seems to be appropriate for playing at normal speed.
I also got the sound working. Just had to use the install.exe and select SoundBlaster (me stupid 😜 )
The high resolution mode (key: R ingame) works also, just a bit slow sometimes, but I guess this was a problem of the game itself.
Happy parking
Reply 67 of 95, by zpeidar
Tentacle wrote:
I'm happy with Zak running finally on my box, now even with sound, which I couldn't activate in DOS, and my version of Zak did not run with scummvm, either.
But now I finally may be able to play it (have to test game-saves). I did hold back playing "day of the tentacle" until now, because I hoped to be able to play Zak Mc Kraken first, and now my wish comes finally true, thanks to "dosbox"!
you know, DOTT has been playable on Linux, Mac, Amiga, and Windoze for a løng time now, ScummVM does the trick ScummVM
"640 kb ought to be enough for anybody"
Reply 68 of 95, by mr_zen256
Well, well, well... Lookie here. Police Quest 4: Open Season is back and is working great! Doesnt work with a soundcard selected, but music works just fine!
Look at those pigs standing around all staunch 🤣
    28.09 KiB
Reply 70 of 95, by ChaosFish
Dear mother of crap! Little Big Adventure 2 is running on DOSBox CVS!
No sound except for CD music, and very, VERY slow. But it runs!
    122.02 KiB
Reply 71 of 95, by Qbix
Rank DOSBox Author
DOSBox Author
Hmmm 1800 cpu cycles is off course awfull slow 😉 (try increasing them)
But then LBA2 might run VERY slow. instead of very very slow 😉
Water flows down the stream
Reply 72 of 95, by Abrogate
I'm new around here, and I must say this program is a god send. Finally, I can play Alone in the Dark on XP. I noticed you got One Must Fall 2097 working, but it isnt on the compatibility list and it automatically closes when I try to load it... mind telling me how you got it? 😉
edit: nevermind, I didn't quite realize the point of this thread. It's teasers of the next DOSBox, yes? Well, I've been able to play Doom on the Win95 launcher, and I used VDMSound and some other things to get Blood working, but now I'm glad that I can finally play Alone in the Dark.
    39.19 KiB
Reply 73 of 95, by Kain
to play doom get "zdoom" or "jdoom" much cooler and has mouselook (fps/counterstrike/quake)
ASUS A7N8X v1.4
Reply 79 of 95, by J3RK
I just tried Ultima 8 under the 59.99 CVS and it's pretty much working. The only problem is the digital audio lags by a little over half a second. Is there a way to change this? The lag seems to be the same with any frameskip value. I've changed the cycles from 4000 to 18000. 11000 seems to be the best. Over all it's quite nice. Even with frameskip at 0 the game runs at a completely playable rate. If I can get the sound within 100 milliseconds, I won't have any complaints at all. Any ideas? This is indeed a happy day for me. 😀
