Sound Blaster 16 Clones
Reply 181 of 414, by appiah4
Intel486dx33 wrote:
What about the Terratec ewx 24/96 24-bit ?
Any good ?
Where is the best place to buy Terratec cards ?
Not a card or chipset I'm familiar with but googling returns absolutely nothing about Sound Blaster compatibility and it also seems to be a mastering sound card that is professionally oriented so I would say it's even worse..
I wish I knew where to find them for a good price, I have several Terratec cards I need in my collection as well.
Reply 182 of 414, by oohms
Those terratec cards use the Via Envy24 chipset.. good windows cards but no dos support whatsoever
DOS/w3.11/w98 | K6-III+ 400ATZ @ 550 | FIC PA2013 | 128mb SDram | Voodoo 3 3000 | Avancelogic ALS100 | Roland SC-55ST
DOS/w98/XP | Core 2 Duo E4600 | Asus P5PE-VM | 512mb DDR400 | Ti4800SE | ForteMedia FM801
Reply 184 of 414, by Kamerat
The original Envy24 has DOS support but only when coupled with an AC97 codec chip which the EWX 24/96 lacks.
YouTube channel
Reply 186 of 414, by badmojo
Intel486dx33 wrote:
What about Media Vision Pro Audio Spectrum 16 cards? Or Turtle beach.
These where really big back in the day ( 1990's )
This thread is about SB16 clones! Stay focussed people!
Reply 187 of 414, by Intel486dx33
I just installed this Diamond Audio ISA Sound card in my Gateway 2000 486dx-33
It is SB-16 compatible. I used this card because this is all I had on hand with a CDROM controller.
Works great and easy to setup.
Works okay, Audio is okay, A little heavy on base and no way to adjust tones.
These where selling for cheap back in 1995/96 about $10 each. at electronics stores.
Comes with a music program that looks like a home stereo.
Buttons function the same as a home stereo.
They later came out with Sound Origins 128-bit card.
with Yamaha XG 128-bit chip.
    84.02 KiB
    35.26 KiB
    115.96 KiB
    165.79 KiB
Reply 188 of 414, by oohms
Looks like you have an ALS007 or ALS100 based card, same as the one discussed on page 5/6 of this thread. These cards are probably some of the best dos sound cards out there in terms of compatibility - just add a wavetable card or external synth
Reply 190 of 414, by oohms
gdjacobs wrote:
Any compatibility issues, like reversed stereo, glitches, etc?
On my ALS100, none yet. No hanging notes (with an external SC-55ST), no single cycle DMA bugs, works in DN3D with both high and low DMA and every other game I have thrown at it. In some games you have to adjust the volume of the music to effects, but the sound quality remains decent
I haven't noticed any reverse stereo issues yet
Reply 192 of 414, by oohms
This is the card i'm using. I know that the LS262 is supposed to be genuine OPL3 but I have several less useful cards with a genuine YMF262 so i thought i would transplant it across anyway. I also upgraded the opamp as the LM324 isn't really good enough for audio
256.49 KiB
ALS100 stock
258.99 KiB
ALS100 with genuine opl3 and upgraded opamp
Reply 193 of 414, by oohms
For those people with ALS100 issues, try different driver versions and make sure that your ATX power supply has a -5v rail. This rail was made optional around the time when ISA motherboards stopped existing and the opamp in this sound card uses the +5v and -5v rails to operate. If you are good at electronics you can add a regulator to get -5v from the -12v rail but you need to know what you're doing
Reply 194 of 414, by gdjacobs
The illegal clones of the YMF262 are usually 99-100% accurate, but I'm curious if the ALS100 has the companion DAC built in or if that's also a clone chip (maybe the 74F244)?
Reply 195 of 414, by oohms
It seems that the digital output of the YMF262 is directly fed into the ALS100
Reply 196 of 414, by Cga.8086
i found the same audioexcel card on the street today and remembered this topic
i was walking and i see on the street a trashed epson pc, completely broken , plastic pieces everywhere, monitor smashed.
and i see the flor and there it was the audioexcel card and a simm memory
the metal bracket was al bent, the pcb is slightly bent..i hope it still works, and one leg of a capacitor is loose
Reply 197 of 414, by tpowell.ca
dvwjr wrote:
All of Creative's Sound Blaster 16 ISA audio adapters do not have Sound Blaster Pro (1 or 2) backwards compatibility. This was a flaw in the initial silicon and was never 'fixed'.
I'm curious, where did this information come from? How do we know that they (Creative Labs) didn't intentionally drop support for the SBPro ?
  • Merlin: MS-4144, AMD5x86-160 32MB, 16GB CF, ZIP100, Orpheus, GUS, S3 VirgeGX 2MB
    Tesla: GA-6BXC, VIA C3 Ezra-T, 256MB, 120GB SATA, YMF744, GUSpnp, Quadro2
    Newton: K6XV3+/66, AMD K6-III+500, 256MB, 32GB SSD, AWE32, Voodoo3
Reply 198 of 414, by gdjacobs
It's certainly a flaw, intentional or not, and it's never been fixed.
Reply 199 of 414, by The Serpent Rider
Am i missing something or ALS100+ actually can't properly emulate SB16? 16-bit mixing has DMA range from 0 to 3, but Duke3D, ROTT and others allow only DMA 5 of higher.
