First post, by mrkaki
Earlier today I noticed I still have the Shadow Warrior CD, so I installed it, installed the patches and tried running it - everything worked fine but in an unplayable FPS.
So I tried using DOSBOX and almost everything works fine with a very playable FPS, but there's only one problem, a big one: I'm missing the music.
The sound works fine. I emulated the sound driver Sound Blaster Pro 2.0 with the IRQ at 7, 8-bit DMA at 1 and 16-bit DMA at 5.
Can I fix this problem? Ifso, how?
Reply 1 of 8, by MiniMax
Rank Moderator
Moderator
Did you re-install from within DOSBox?
_________________
Reply 3 of 8, by MiniMax
Rank Moderator
Moderator
ALT-F12 I think is the DOSBox "turbo" button (all explained in the README *hint*).
_________________
Reply 4 of 8, by mrkaki
Argh. It always freezed on 27%, so I tried burning the CD in case it was due to scratches, but it's copyrighted so the burner won't allow me.
Now I'm trying to copy the files to the computer and see what happens.
Hey, this disc is 12 years old!
Computer scratched the disc to death. The disc worked a few hours ago, now it doesn't.
I declare the death date of Shadow Warrior the 12th of July, 2009. May it rest in peace.
Reply 8 of 8, by leileilol
Perhaps the disc is so bad, it made Windows XP be stupid and force the access mode for your drive to PIO mode forever? (Crippling your CPU power too much for the 'safest' transfer) Try to force Ultra DMA on your optical drive.
