First post, by Ijustdontknow
OK.
So I have no clue about any of this
I have vista. I've downloaded DosBox. I've tried to make it work. This is where i'm at.
I own the the CD for Death Rally.
I've tried to copy the files into a folder and mount it through. which worked.
Except when i finally got into the game, it said that i needed to insert the CD, and it was.
I just want to play and save. that's it. Help please? Thanks
Reply 2 of 8, by Ijustdontknow
I'm not sure which read me you mean. I've gone through a dozen sights to find out how to do it differently. I've tried going through mounting a d and such but when i try to open files through the cd rom (through dosbox) i get either unable to change directory or illegal thing. could you send me a link to this read me. Greatly appreciated by the way. I just wanna play my game...
Reply 4 of 8, by MiniMax
Rank Moderator
Moderator
Read my 60 Seconds Guide to DOSBox (and don't just read it - follow it too).
If that doesn't help, come back with details on how you mounted your C and D drives, how you did the install, how you configured sound, music etc.
Reading the aptly named README file will be a good idea too.
_________________
Reply 5 of 8, by Ijustdontknow
So, i went through the readme several times, as well as the 60 second umongnst other tutorials. No luck. I'm very illiterate in Dos, i was oly 7 or 8 at the time. Here are the attempts and the screenshots along with them.
    47.77 KiB
    when i mount the D cdrom thing, i get limited support instead of installed...problem?
    122.59 KiB
    132 downloads
    the install note file.
    120.5 KiB
    127 downloads
    files on the Death Rally cd
    64.28 KiB
    mounted just through the files copied from the cd to a folder on C drive
    65.85 KiB
    but that gives me this. this is the only attempt that led me somewhere
Reply 6 of 8, by Reckless
When 'MiniMax' says "C: and D: drives" he expects you to know what your drives are 😀
Looks like your D: drive isn't a CD [seems to have a copy of an OS on it (Vista/Windows 7...)]. Look in Windows Explorer and see what devices have a name of CD or DVD (in Windows XP they're shown as a group named "Devices with Removeable Storage" if you look at the computer, under Vista I expect they're named differently but should be similar!).
Once you've worked out what device letter is, substitute the D: for yours and you should be good to go.
Reply 7 of 8, by MiniMax
Rank Moderator
Moderator
I thought that was pretty clear from one of the notes in the guide:
If your real CD-ROM drive is E:, then do a mount D "E:\ -t cdrom".
Should I put it in size 18 font??
_________________
