What's the solution for this?
First post, by LameBill
I figure, since the directory shows up when I do a dir command, it should show up when dosbox does a mount command, right?
    78.65 KiB
    Screenshot showing strange dosbox mount error.
Reply 1 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
mount works with paths on your real drive. not the mounted one
so to give you the solution type mount without parameters as well and a take a screenshot
Water flows down the stream
Reply 5 of 7, by SimonJ
Ah, What I did was:
Mount C: C:\Dosgames
Mount D: E:\
E:\
Install
Of course, the first three steps may be different for you.
My problem is that it wont install the large or huge pack (keeps telling me theres not enough space).
Now go out there and enjoy an elderscroll classic (As well as the climbing skill).
Great shot! or AIMBOT!
