post up pics of your "computing area"
Reply 1060 of 2213, by Smack2k
I have a CRT for them actually, but its for CGA / EGA (you can see it in the one photo on the left with the back of the monitor facing forward). Its an NEC JC-1401P3A and I dont have two EGA cards for it, nor a way to run both Tandy's from it....I like to have both available for different uses.....
I have other CRT's as well, but table space is limited so they arent used right now.
Reply 1062 of 2213, by Oldtech81
I don't have a lot of room but here is my retro desk:
Specs PC:
AMD K6/2 500
512MB Sdram
60GB SSD using a IDE > Sata adapter.
2 DVD drives
3Dfx voodoo 3 16MB AGP
SB 64pci
3Com 3x905 NIC
19 inch medion monitor
And to the left of the PC a Commodore 64 with an SD2IEC card reader hooked up to an old crt tv.
Might buy a bigger desk so i can combine my modern pc setup with the retro pc setup but for now this will do.
https://www.youtube.com/user/Oldtech81
Reply 1064 of 2213, by Oldtech81
mrau wrote:
whats the system on that thing? i suppose you do not have any exceptional hardware to make it cache all that ram? whats Your framerate ikn q3 or in some dos games?
The system as in the operating system? Windows98SE. Framerate in Unreal Tournament is at around 25fps in 1024x768 16b . I have yet to try quake 3. Dos games run great.
Reply 1065 of 2213, by netfreak
I've got bins full of parts and whatnot in storage, but this is where I do most of my retro computing work.
91.88 KiB
I like computing hardware from the 80s and 90s.
"Paul's Old Crap" retro computing videos
Reply 1067 of 2213, by KSHIRZA1
My retro PC is still being put together - waiting on monitor and some parts to arrive.
Build thread: Topic 5803
IBM Aptiva setup in my game room, my main computer is in my office across the hall...
Game room:
Office:
\\IBM Aptiva 2144 build\
My instagram @kshirza1
Reply 1068 of 2213, by netfreak
oeuvre wrote:
Those are a lotta ol' Macs
Unfortunately I'm at about half the size my collection used to be. Maybe even a bit less. I also either sold or scrapped most of my old PCs as I had 286s, 386s, 486s which disappeared at some point. So little room for my stuff.
Reply 1069 of 2213, by Smack2k
KSHIRZA1 wrote:
My retro PC is still being put together - waiting on monitor and some parts to arrive. Build thread: Topic 5803 […]
Game room:
Office:
That is a REALLY Nice Setup.....Kudos...
Reply 1070 of 2213, by Anaxagoras
Oldtech81 wrote:
I don't have a lot of room but here is my retro desk: […]
Specs PC:
AMD K6/2 500
512MB Sdram
2 DVD drives
SB 64pci
3Com 3x905 NIC
More important than room are the things that are inside in.
IMO, the left speaker is too close to the TV, it can cause magnetism problems in CRT TV/monitors. Maybe you can let the speaker on the floor or attached in the wall, moreover with this you saves space.
My computers
Reply 1071 of 2213, by Anaxagoras
KSHIRZA1 wrote:
Office: https://s9.postimg.org/sq8ooosun/IMG_2855.jpg […]
Office:
I have a question.
What is the aspect ratio of your monitor?
It's very similar to two 4:3 monitor together.
Thank you.
By the way, your setup is grandiose and spectacular!!! Good work
My computers
Reply 1073 of 2213, by RetroGamingNovice
Got my 5750 back up and running again for something to do during a web outage yesterday. Here's a photo of both it and my main machine in action, as well as a spec shot of it.
UPDATE: Got a Xonar DG PCI soundcard, DVI to HDMI adapter, and PS1/2 to USB patch cable coming in, in order to allow output to an HDMI port, give it an internal S/PDIF out, and allow a Dualshock/DS2 to be connected for the controller.
PC hardware: Ryzen 5 4500, 32GB RAM, 1TB SN 570 Linux drive, 500GB 970 EVO Plus Windows drive, 2TB 970 EVO Plus games drive, 1TB 870 EVO extra storage drive, RX 6600 GPU, EndeavourOS/Win10 dual-boot
Reply 1074 of 2213, by KSHIRZA1
KSHIRZA1 wrote:
Anaxagoras wrote:
I have a question. What is the aspect ratio of your monitor? It's very similar to two 4:3 monitor together. Thank you. […]
Office:
I have a question.
Thank you.
Thank you sir, it’s a work in progress.
21:9; The monitor is this...
http://www.newegg.com/Product/Product.aspx?Item=24-236-717
kixs wrote:
System specs:
Caselabs s8s case
Intel 5820k - ek water block
Asus x99 deluxe
Kingston predator ram
Evga 1080ti - ek water block
Samsung 950 pro ssd
Corsair sleeved power supply
Ek vardar pwm fans
Alphcool 240 radiator
Swiftech ddc pump
Aquacomputer glass reservoir
Bitspower 3 piece rotary compression fittings
Primochill soft tubing
Primochill vue liquid
Focusright Scarlett solo sound dac
Beyerdynamics dt770 pro headphones
Audio technica at2020 mic
Ducky shine keyboard
Zowie fk1 mouse
IKEA motorized desk
Dxracer boss chair
Htc vive
Asus swift pg348q monitor
10tb Plex server (on the ground in the pic)
Netgear nighthawk x10
Reply 1075 of 2213, by arncht
i always need more space, so i tried out a monitor arm - for my modern-retro desk.
1.16 MiB
Overdoze of the demoscene
Reply 1076 of 2213, by henryVK
Nice! I assume both monitors are hooked up to one arm??
I have a similar sized desk (i.e. not very big) with a 22" flatscreen and 14" CRT and I'm considering something like this.
Now I wonder if there even is an arm that would support both a CRT and flatscreen...
Reply 1077 of 2213, by arncht
yes, it is a t-shaped one arm solution - they designed for two 27 inch display, but the width is same, like at my 34 uw, and the 20 inch 4:3 display. i missed one thing - the vesa connection is not at the same height. maybe later i will replace with two independed arms with custom height position.
i dont think, you will find a combined lcd-crt solution. i also feel the crt more nostalgic, but finally i chose an lcd for the retro rigs because of the space saving.
Reply 1078 of 2213, by MMaximus
This is really neat. What make and model of arm is it?
Hard Disk Sounds
Reply 1079 of 2213, by arncht
https://www.amazon.de/Fleximounts-D1D-Monitor … z/dp/B01N64KJ9W
