Reply 1140 of 2212, by CrossBow777
- Member
My computing area isn't nearly as impressive as most of you here. I do all my computer gaming retro and modern on my one main computer. I do also own a NIB 800xl as well as a 130xe, TI99-4a, and a Vic-20. But only the 130xe and Vic get pulled out of the closed and hooked up to mess around with from time to time.
I have had this system and case for just over 7 years now. Antec 902 with a now old Intel Z68 chipset main board with a an old Sandy Bridge i5-2500k at the heart of it all. 16gb total ram, 2 - 450gb Sandisk SSDs in Raid O velcroed to the back interior side of the case, an old Intel 320 series 120gb SSD as the boot drive and 2 even older 1TB WD blacks in Raid 0 where all the games are kept. You can see to the right of the case is where I keep my MT-200 and MT-32 modules with the MT-32 on the bottom.
Here you can see the MT-200 and MT-32 modules much better. The PC sits on a large 8ft x 6ft office credenza I was able to keep from my last job. That credenza was originally built in 1984 and is made of solid oak.
