ok, it is working now. Many thanks! Looks fun now
When Tomb Raider starts the actual game I get the console message:
"Warning: Severe Problem: OpenGL GL_EXT_packed_pixels extension is required for OpenGLide!"
Also when I run Dosbox windowed the screen gets very bright whenever Glide initialises.
Lands of Lore 3 has texture errors, if that is of interest
In the log this is listed:
** OpenGL Information **
Vendor: ATI Technologies Inc.
Renderer: ATI Radeon HD 4850 OpenGL Engine
Version: 2.1 ATI-1.6.6
Extensions: GL_ARB_transpose_matrix GL_ARB_vertex_program GL_ARB_vertex_blend GL_ARB_window_pos GL_ARB_shader_objects GL_ARB_vertex_shader GL_ARB_shading_language_100 GL_EXT_multi_draw_arrays GL_EXT_clip_volume_hint GL_EXT_rescale_normal GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_geometry_shader4 GL_EXT_transform_feedback GL_APPLE_client_storage GL_APPLE_specular_vector GL_APPLE_transform_hint GL_APPLE_packed_pixels GL_APPLE_fence GL_APPLE_vertex_array_object GL_APPLE_vertex_program_evaluators GL_APPLE_element_array GL_APPLE_flush_render GL_APPLE_aux_depth_stencil GL_NV_texgen_reflection GL_NV_light_max_exponent GL_IBM_rasterpos_clip GL_SGIS_generate_mipmap GL_ARB_imaging GL_ARB_point_parameters GL_ARB_texture_env_crossbar GL_ARB_texture_border_clamp GL_ARB_multitexture GL_ARB_texture_env_add GL_ARB_texture_cube_map GL_ARB_texture_env_dot3 GL_ARB_multisample GL_ARB_texture_env_combine GL_ARB_texture_compression GL_ARB_texture_mirrored_repeat GL_ARB_shadow GL_ARB_depth_texture GL_ARB_shadow_ambient GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_occlusion_query GL_ARB_point_sprite GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ARB_pixel_buffer_object GL_ARB_draw_buffers GL_ARB_shader_texture_lod GL_ARB_color_buffer_float GL_ARB_half_float_vertex GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_EXT_compiled_vertex_array GL_EXT_draw_buffers2 GL_EXT_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_texture_rectangle GL_ARB_texture_rectangle GL_EXT_texture_env_add GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_texture_lod_bias GL_EXT_abgr GL_EXT_bgra GL_EXT_stencil_wrap GL_EXT_texture_filter_anisotropic GL_EXT_separate_specular_color GL_EXT_secondary_color GL_EXT_blend_func_separate GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_texture_compression_s3tc GL_EXT_texture_compression_dxt1 GL_EXT_texture_sRGB GL_EXT_blend_equation_separate GL_EXT_texture_mirror_clamp GL_EXT_packed_depth_stencil GL_EXT_bindable_uniform GL_EXT_texture_integer GL_EXT_gpu_shader4 GL_EXT_framebuffer_sRGB GL_APPLE_flush_buffer_range GL_APPLE_ycbcr_422 GL_APPLE_rgb_422 GL_APPLE_vertex_array_range GL_APPLE_texture_range GL_APPLE_float_pixels GL_ATI_texture_float GL_ARB_texture_float GL_ARB_half_float_pixel GL_APPLE_pixel_buffer GL_APPLE_object_purgeable GL_NV_blend_square GL_NV_fog_distance GL_ATI_texture_mirror_once GL_ATI_blend_equation_separate GL_ATI_blend_weighted_minmax GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SGI_color_matrix
OpenGL Extensions:
Severe Problem: OpenGL GL_EXT_packed_pixels extension is required for OpenGLide!Extension GL_EXT_secondary_color is present and ENABLED
Extension GL_ARB_multitexture is present and ENABLED
Extension GL_EXT_fog_coord is present and ENABLED
Extension GL_EXT_texture_env_add is present and ENABLED
Note: OpenGL GL_EXT_texture_env_combine extension is not supported, emulating behavior.
Extension GL_EXT_texture_lod_bias is present and ENABLED
Note: OpenGL GL_SGIS_generate_mipmap extension is supported but disabled by user
Note: OpenGL GL_EXT_paletted_texture extension is not supported, emulating behavior.
Note: OpenGL GL_EXT_vertex_array extension is not supported, emulating behavior.
Extension GL_EXT_blend_func_separate is present and ENABLED
MultiTexture Textures Units = 8
Setting in Use:
Init Full Screen = true
Fog = true
Precision Fix = false
Wrap 565 to 5551 = true
Texture Memory Size = 16 Mb
Frame Buffer Memory Size = 8 Mb
MMX is present
** Glide Calls **
