First post, by retro games 100
- l33t
This is a bit strange - I've just tested two Epox EP-8KTA3+PRO boards, and they both freeze very quickly inside the BIOS setup area. Their BIOS chips have the same sticker on them, labelled "E+". I've just tested a 3rd board, with a BIOS sticker labelled "P=", and that works OK. All I did was transfer over all of these working components from that 3rd working board, to the 2 non working boards. The components used were fairly simple - 1 stick of 133mhz RAM, a GeForce MX 440 AGP graphics card, a HDD & DVD-ROM plugged in to the 2 IDE ports, and a T-Bird 1400mhz CPU - I've also tried an Athlon XP 1700+ rated CPU.
Looking at one of the non working boards, I see that some of the caps are domed. The other non working board has definitely had its caps replaced - they look quite impressive.
