First post, by bushwack
- Oldbie
Anyone with the pinout for this thing? 😳 I'd like to change the ACA to ASS or POO.
I can't locate any kind of make on the case and the ACA is just a abbreviation of a local vendor.
What does it change to when you hit the turbo switch?
These are rather easy to figure out.
1+1=10
You could get the pinout of a single standard 7-segment LED and then trace which jumpers on the outer edges are going to which pins on the LEDs in the middle.
wrote:What does it change to when you hit the turbo switch?
Absolutely nothing but the cases turbo light comes on. For some reason the turbo switch is strait wired into the display (orange/black/white). The red/black wire if coming directly from the power supply and the Yellow/white runs from the case turbo light to the display.
I'm thinking this case is much older then 1997 P233 that was in it.
Interesting. It seems like it should support different display settings for turbo on/off. Maybe it's wired to show ACA for both though?
Took it out for a better shot. The top numbers/letters are the same on the top pins as the bottom.
This might help: MHz display panel circuity ???
Have to love trial and error...
A55 😁
1+1=10
